Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Replacing SiteSensor Plugin (Vera) with MSR
@toggledbits QQ on the OWM built-in: is there a means by which to render it inactive until I need to call it? The way I work my Site Sensors is the one for OWM stays deactivated until the one for Ambient throws
null
at which point the OWM turns on, carrying the load until Ambient throws real data back out there again (at which time OWM shuts back off.)This saves wasted calls to the API for OWM.
@tunnus That would work if I were creating the OWM like I've created the Ambient expressions and ruleset. But @toggledbits has OWM built-in, controlled by reactor.yaml config file. The frequency of calls to the API is configured there in minutes and it creates an entity in the Entities list. As I understand it, the entity is always refreshed data-wise by the frequency of the calls set in reactor.yaml.
@gwp1 said in Replacing SiteSensor Plugin (Vera) with MSR:
No. Controllers can only be switched on and off via configuration.
@gwp1I got this all working, Ambient's API and OWM's API all dumping to global expressions.
ambient_api
ambient_temp
ambient_windspeed
ambient_windgust
ambient_solarradiationopenwxmap_api
openwxmap_temp
openwxmap_windspeed
openwxmap_windgustEverything is glorious. I've planned for when the Ambient API drops (they were having big ol' issues today and into the evening now) it returns a NULL and I flip my HVAC control over to OWM API.
Except... Reactor gets very angry.
Now it's entirely possible this is on me - so let's review:
HVAC has three master rulesets, Cooling, Heating, and Neutral. You'll notice I've broken out the rules into Ambient vs OWM.The triggers for OWM include a "when Ambient returns NULL" clause, if you will.
These are my two "Site Sensors" in MSR:
This, too, works as intended with OWM sitting idle until Ambient goes "null" and then OWM starts making API calls and populating the global expressions with data.
In real world usage today/this evening the switch happens flawlessly. Where the angry Reactor comes in is after the switch happens. My confusion is around why any ruleset referencing the Ambient data (via global expressions) as a trigger suddenly has all the compile errors, throttling because update rates exceed 60/minute, etc. My expectation is that the "null" will blank the triggers in the ruleset and, since the ruleset is not triggered, it will go dormant until triggered again.
Where have I lost my way?
I don't recommend using
if
statements. There are coalescing operators to make the deferencing through the structures easier and tidier whennull
is a possibility. See the documentationAlso your API Sensor OpenWxMap would be better without the Interval condition and applying pulse output mode (condition options) on the null test.
As for the throttling, I would comb through all of your rules and reactions to see if you have any left-over Set Variable or other actions that would change the value of any of the subject variables. Something seems to be competing with what you've shown here.
@toggledbits I'm not understanding Pulse vs Interval. That trigger is intended to be how often it queries the API (yes, five minutes is aggressive - I'll pull that back once this is all working.)
There's nothing writing to those variables as they never existed prior to just a day or two ago when I reopened this project of migrating off of Vera's Site Sensors.
Now, there are a slew of rulesets READING from those. That's where my confusion lies, also. In my mind, if it reads the data and it doesn't match the trigger criteria it should just stop until the data changes again, no?
For instance, the Fountain ruleset is complaining. But it's only set to read from Ambient API values - it should be done until there's Ambient data.
It's just an alternate way of doing things. I'm not a fan of Interval conditions, and view them as a necessary evil, so I try to remove their use whenever alternate functionality accomplishes the same.
The big problem you have here overall is that, currently, global variables changing does not drive rule evaluations. I think this came up in the other thread. Just because your Ambient fetch rule is updating
ambient_api
does not mean thatambient_temp
is being updated in that same instant (that depends on how you are setting it, which you haven't shown us), and just becauseambient_temp
changes (no matter how you set it) doesn't mean that "Fountain via Ambient API" suddenly wakes up and checks it. This may simply be a current limitation of global variables as implemented that needs to be reviewed.Another issue I see here is simply one of structure. If you've got "Fountain via Ambient" and "Fountain via OpenWxMap", then I assert you're making your life harder. It would be better to have a
current_temp
rule that itself decides if it is going to use Ambient or OpenWxMap, and the "Fountain" rule (singular) has no idea where that data came from and doesn't care.current_temp = isnull( ambient_api?.whatever?[0] ) ? openwxapi?.whatever?[0].temperature : ambient_api.whatever[0].temperature
Also, even if everything operated to your assumptions, you have a race condition. There's an instant while the first OpenWxMap fetch is occurring that the query data from a previous query of hours, days, weeks, or months ago may be used, and that may cause reactions you don't intend until the OpenWxMap fetch succeeds and the data is updated. This is a side-effect of your goal of avoiding continuous OWM calls. There are workarounds, but the issue is moot at this point because the entire thing doesn't work like you think it does.
The implementation decision to not have global variables drive rule evaluation occurred early on. There were issues that prevented it, but since then, the rule evaluation algorithm has changed substantially. I'd need to study and test if this can be changed to work well under the new order. I agree it would be "better" (work more like expected) if rules could respond to global variable changes, but there are many opportunities for logic loops and other issues in doing that, so figuring that out and how to maintain control of the system and give the user meaningful feedback about such errors may not be a small task. (So I'm saying, I won't fix it today. Tomorrow's not looking good either.)
@toggledbits Firstly, there is no "Fountain via OWM" as it's missing one of the metrics I use to drive that stupid thing.
Secondly - yes, if global variables do not drive rule evaluations then this whole idea is moot. I was hoping to pull Site Sensors out of Vera at long last. It appears, at least taking the path I did, that this is not viable.
Regarding how I have
ambient_api
set:That populates the rest of the global expressions:
I need to think thru this some more if Global Expressions will not work as triggers. Has to be a way to present those datapoints as triggers like I've done with the Vera Site Sensors.
Give me a couple of days to see what I can noodle out on this. So far, things are looking like they're going the right direction, but sometimes you get >80% of the way before realizing you've painted yourself into a corner and need to take a different approach. Stay tuned!
Preaching to the choir. As you're well aware from my previous escapades, I do tend to make things much more complicated than they need to be. I don't want you compromising your product, though, just because I am going down the wrong path. Steer me back!
I would very much love to have shared elements like the outdoor temp, wind speed, and solar radiation something I can just point to. I've finally done that with HVAC, having only one master set and then pointing to them with the HVAC Ambient and HVAC OWN rulesets. Consolidation is king!
@toggledbits Better?
@tunnus I'm back knocking on this again. lol
I've enabled the OWM controller via
reactor.yaml
and this will be the dumbest question of the day, @toggledbits, but where do I see the results from it? Are new Entities created or should they appear underOWM Weather
?I know I'm gonna feel like an idiot at the answer but I can take it lol
Yeah, it creates new entities. In the Entities list, you can filter by controller. Do that. It should pop right out at you. If you want to get even more specific, filter on the
wx
capability, which is used by the entities that the controller publishes, and these are the entities you will want to use in rules.
