Hi.
I have a ton of different Ledvance bulbs, pluggs sensors and lights.
So far everything works fine.
Bot there is one thing I want too figure out.
I can link lights with the sensor so the light turns on when I enter the room.
But I want to put a timer on it.
Like 5 min without movement and the light turns of. I just can't figure out how..
I use LVD app.
hello
i am searching for a universal hub that takes my 433 remotes signals and repeats them 433mhz or converts them into bluetooth, wifi, IR, z-wave etc…basically into all the other signals. so my 433mhz remote becomes a universal remote.
it should have an app to configurate, maybe a learning function as well
i belive the homey pro can do that but it costs like 400$ …right?
so is there a cheap “china” product that works like that for at least 433 into IR, bluetooth, wifi
there are so many chinaproducts and i cant figure out which can do which trick !/ this for example https://de.trck.one/redir/clickGate.php?u=Ha2Rd3xX&m=1&p=9yUI69TI8b&t=kLf5673Z&st=&s=&url=https%3A%2F%2Fwww.techpunt.nl%2Fde%2Fhomey-bridge.html%3Fgclid%3DCj0KCQiA9YugBhCZARIsAACXxeJvViv59ieDen9zOXTP1jhc_OisKQxPlCZOJsPGX20nWo7UROROuJcaAix5EALw_wcB&r=https%3A%2F%2Fwww.hardwareluxx.de%2Fcommunity%2Fthreads%2Fbillige-chinaversion-von-homey-pro-gesucht.1333803%2F
i am working with 433mhz intertechno protokoll remotes .
please help
thanks, christoph
Looking for a simple solution that doesn't require running wire (replacing a switch receptacle is fine)
The problem: the only light switch in my garage is not near a door. So have to walk into the garage to turn the lights on.
Ideal Solution: physical remote I can stick on the wall next to the door to toggle a switch. Is there a product that is a toggle switch to replace the basic switch in the receptacle that I can also operate with a remote?
Is anyone actively developing anything on these IoT chips?
In particular, using NodeMCU for Lua programmability?
Just got a development board to play with myself...
After a fruitless search for WiFI pulse utility meter readers (can't believe I couldn't find anything suitable) and also having resolved a while ago not to include any homebrew hardware in my HA configuration, I've decided in the end to try this out, after all.
Having cut my teeth on Lua, thanks to Vera, it seems promising to use it for development, rather than Arduino programming, and the hardware is SO much cheaper, smaller, and neater than a RPi or the like.
Any experiences welcomed!
AK
Shelly i3 is an unbelievably cheap (9,99 EUR/USD) WiFi device that’s part of the fantastic Shelly family. It supports REST API, MQTT and much more.
https://shelly.cloud/knowledge-base/devices/shelly-i3/ 10
It’s just L,N and 3 inputs. No relays, so it’s a scene controller with bonus point to the fact that you can use your own buttons and keep the aesthetics of your house. Bonus points for WAF. It’s very small, so it will fit in your standard wall box easily.
While I built my own Scene Controller Virtual Device and I’m using MQTT for other devices of the family, Shelly can call your HTTP endpoints on button presses and in this case is more than enough.
The buttons support different actions (press, long press, double/triple press) and you can just call a service endpoint, or update a variable:
Go get it if you need a very cheap, very reliable scene controller for your home.
Finally, I’ve found an adequate replacement for my beloved MiniMote four-button remotes (I’ve had nine of them for the last 10 years or so!). I should have realised this earlier, but with four buttons and approximately the same form factor, the Philips Hue remotes are viable replacements…
…however, they are, of course, Zigbee and not Zwave, but this doesn’t matter in my HA environment, which has now completely ditched Zwave and Vera for all lighting and control functions, and replaced them with Hue and Shelly devices. These are all brought together with a Homebridge installation running under Docker on Synology NAS with the Apple Home app as the UI. This gives, of course, both secure remote access and voice control.
The MiniMote buttons I had configured as scene triggers to do whatever I needed, most usually toggling lights. The same functionality is easily achieved within the Home app by appropriate shortcuts.
I’m still using openLuup as a secondary hub which mimics all the various devices using MQTT and the ALTHUE plug-in and logs all device and sensor data using the built-in Historian and viewed through Grafana.
Works for me!
AK
After a long wait for an updated version of the rather crude and unfinished Z-Way integration to HASS, i'm now looking (reluctantly) in to replacing Z-Way with Z-wave JS..
Mind you this is a big existing network, not a new controller stick..
I threw up a docker for z-wave JS UI, and tried to connect it to the UZB stick.. It loads the whole network from the stick, but the driver keeps restarting?
Looking at the logs, I see a lot of Dropping message because the driver is not ready to handle it yet.
It seems like the stick just keeps talking like z-way was still listening? This ends up in the driver crashing repeatedly.. Any ideas to how I can get them talking?
In the code snippet below, you see the driver restarting with the graphic letters, seemingly while the stick is mid-sentence, or because of ACK timeout...
2022-10-02T19:19:59.664Z CNTRLR received additional controller information: Z-Wave API version: 6 (legacy) Z-Wave chip type: ZW050x node type Controller controller role: primary controller is the SIS: true controller supports timers: false nodes in the network: 1, 5, 6, 10, 11, 12, 13, 14, 17, 18, 21, 22, 23, 24, 25, 26, 27, 28, 29, 32, 33, 34, 36, 37, 38, 39, 41, 42, 43, 44, 45, 46, 4 7, 48, 52, 55, 69, 70, 71, 73, 74, 75, 77, 78, 79, 81, 82, 83 2022-10-02T19:19:59.765Z CNTRLR [Node 001] [Manufacturer Specific] manufacturerId: metadata updated 2022-10-02T19:19:59.766Z CNTRLR [Node 001] [Manufacturer Specific] productType: metadata updated 2022-10-02T19:19:59.767Z CNTRLR [Node 001] [Manufacturer Specific] productId: metadata updated 2022-10-02T19:19:59.768Z CNTRLR [Node 001] [+] [Manufacturer Specific] manufacturerId: 277 2022-10-02T19:19:59.769Z CNTRLR [Node 001] [+] [Manufacturer Specific] productType: 1024 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [+] [Manufacturer Specific] productId: 1 2022-10-02T19:19:59.770Z CNTRLR [Node 001] [Version] firmwareVersions: metadata updated 2022-10-02T19:19:59.771Z CNTRLR [Node 001] [+] [Version] firmwareVersions: 5.39 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [Version] sdkVersion: metadata updated 2022-10-02T19:19:59.772Z CNTRLR [Node 001] [+] [Version] sdkVersion: "6.9.0" 2022-10-02T19:19:59.772Z CNTRLR setting serial API timeouts: ack = 1000 ms, byte = 150 ms 2022-10-02T19:19:59.792Z SERIAL » 0x01050006640f97 (7 bytes) 2022-10-02T19:19:59.792Z DRIVER » [REQ] [SetSerialApiTimeouts] payload: 0x640f 2022-10-02T19:19:59.815Z SERIAL « [ACK] (0x06) 2022-10-02T19:19:59.816Z SERIAL « 0x01050106640f96 (7 bytes) 2022-10-02T19:19:59.817Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.177Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:03.178Z DRIVER version 10.2.0 2022-10-02T19:21:03.179Z DRIVER 2022-10-02T19:21:03.179Z DRIVER starting driver... 2022-10-02T19:21:03.199Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:03.212Z DRIVER serial port opened 2022-10-02T19:21:03.213Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:03.229Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.232Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.233Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.234Z SERIAL « 0x01090141d39601020201f3 (11 bytes) 2022-10-02T19:21:03.234Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:03.261Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.268Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.268Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.271Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.271Z DRIVER « [RES] [GetNodeProtocolInfo] payload: 0xd39601020201 2022-10-02T19:21:03.273Z DRIVER « [RES] [GetNodeProtocolInfo] [unexpected] payload: 0xd39601020201 2022-10-02T19:21:03.274Z DRIVER unexpected response, discarding... 2022-10-02T19:21:03.274Z DRIVER loading configuration... 2022-10-02T19:21:03.298Z CONFIG Using external configuration dir /usr/src/app/store/.config-db 2022-10-02T19:21:03.298Z CONFIG version 10.2.0 2022-10-02T19:21:04.284Z DRIVER beginning interview... 2022-10-02T19:21:04.286Z DRIVER added request handler for AddNodeToNetwork (0x4a)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for RemoveNodeFromNetwork (0x4b)... 1 registered 2022-10-02T19:21:04.286Z DRIVER added request handler for ReplaceFailedNode (0x63)... 1 registered 2022-10-02T19:21:04.287Z CNTRLR querying controller IDs... 2022-10-02T19:21:04.484Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:04.485Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:04.487Z SERIAL « 0x0123000400511a9f039900b834787d066515a4b79c45bb3af55ea7f6203006010 (37 bytes) 80120c84d 2022-10-02T19:21:04.489Z SERIAL « [DISCARDED] invalid data 0x9ef4 (2 bytes) 2022-10-02T19:21:04.490Z DRIVER Dropping message because it contains invalid data 2022-10-02T19:21:04.490Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:05.488Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i n 100 ms. 2022-10-02T19:21:05.591Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:05.592Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:06.596Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i n 1100 ms. 2022-10-02T19:21:07.698Z SERIAL » 0x01030020dc (5 bytes) 2022-10-02T19:21:07.699Z DRIVER » [REQ] [GetControllerId] 2022-10-02T19:21:08.717Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200) at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D river.ts:3980:23) at ZWaveController.identify (/usr/src/app/node_modules/zwave-js/src/lib/co ntroller/Controller.ts:713:33) at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js /src/lib/driver/Driver.ts:1207:26) at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive r/Driver.ts:1014:16) 2022-10-02T19:21:08.723Z DRIVER destroying driver instance... 2022-10-02T19:21:08.728Z DRIVER driver instance destroyed 2022-10-02T19:21:08.739Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗ ╚══███╔╝ ██║ ██║ ██╔══██╗ ██║ ██║ ██╔════╝ ██║ ██╔════╝ ███╔╝ ██║ █╗ ██║ ███████║ ██║ ██║ █████╗ █████╗ ██║ ███████╗ ███╔╝ ██║███╗██║ ██╔══██║ ╚██╗ ██╔╝ ██╔══╝ ╚════╝ ██ ██║ ╚════██║ ███████╗ ╚███╔███╔╝ ██║ ██║ ╚████╔╝ ███████╗ ╚█████╔╝ ███████║ ╚══════╝ ╚══╝╚══╝ ╚═╝ ╚═╝ ╚═══╝ ╚══════╝ ╚════╝ ╚══════╝ 2022-10-02T19:21:08.740Z DRIVER version 10.2.0 2022-10-02T19:21:08.740Z DRIVER 2022-10-02T19:21:08.740Z DRIVER starting driver... 2022-10-02T19:21:08.745Z DRIVER opening serial port /dev/zwave 2022-10-02T19:21:08.751Z DRIVER serial port opened 2022-10-02T19:21:08.752Z SERIAL » [NAK] (0x15) 2022-10-02T19:21:08.754Z DRIVER loading configuration... 2022-10-02T19:21:08.755Z SERIAL « 0x01080120c84d9ef40138 (10 bytes) 2022-10-02T19:21:08.757Z SERIAL » [ACK] (0x06) 2022-10-02T19:21:08.758Z DRIVER « [RES] [GetControllerId]Hi,
I have an old analog intercom (Golmar) that has this horrible buzz sound when someone rings my apartment from the buildings front gate. This becomes very annoying at night so I need to make this buzz silent from 10:00pm till 7:00am
I have a "Shelly Plus 1" connected to the intercom. (wire #0 and wire #3 are responsible for closing the circuit for the buzzer).
I have set Webhooks and Scenes, but my wiring does not work. Can anyone tell me what i have done wrong?
Cheers!
Well with all that has been going on with Vera/eZlo, many people are abandoning the Vera hubs and moving on to other solutions, such as Hubitat (my case), HASS, HA, and many other controllers.
In the past, I had already been informed that when the migration was over, my Vera would go to the incinerator, or under the wheel of my car, and of course, I did not comply.
So I wanted to open a debate, for those who have not yet sold their Vera on eBay, are with the equipment idle, what destination could be given?
I see many saying that it has become a laboratory, I don't see much sense, since it is becoming obsolete and without a drive. But it can be a destiny. Has anyone thought about whether it is feasible to change the hub's SO so that it becomes a host for MSR, for example? Or even Home Assistance? I have no knowledge, but it seems to me that processor and memory have to do something like that, already has embedded wifi and network.
Does anyone have any idea if it is possible to give this equipment a destination other than a box?
I just started [uncloud] forum to gather in one central place all smart devices working without the cloud, since this is not information easily available on the Internet.
I thought this might interest some users of this forum and any feedback are welcome.
And let me know if you know more devices that I should add to the list!
- Marco
Good afternoon. Due to the new ezlo not being available in europe yet, I wanted to change the z-wave getway that works with the reactor to add to the home assistant. What advises?
I didn't see an existing Topic for heating-ventilation-air conditioning, so here goes...
Is anyone successfully controlling a "mini split" (i.e. ductless) A/C or heat pump system at home? I will be adding such a system soon to new construction, and wondered if certain brands/models interface better via Z-Wave or WiFi than others in a HA setting.
I know a bunch of these "splits" come with handheld remotes, but having robust Home Automation control (preferably without a dedicated plug-in needed on the Vera side) would be idea.
Happy to hear suggestions. Thanks!
LibraI have a legacy Vera system that in my home and I need to add a few devices to a cottage on my property. The Vera zwave won't see devices that far away. Both the house and cottage are on the same LAN. Can I bridged an Ezlo Plus to my existing Vera plus and if so are there instructions?
Hey guys...
Is it just me or the GE/Jasco switch or very sensible to power outage ?
Almost each time we have a power outage, I need to replace at least 1 switch to replace.
Each time, same behaviour, the blue led is flashing rapidely and nothing works.
Last power outage, I got 3 switches. 95% of our switch and dimmer are GE/Jasco.
About one month ago I got a new electrical meter in the house. The new meter is a "smart" meter equipped with a data port. It is more or less the same type of meter that is used in a number of European countries, e.g. The Netherlands, Belgium, Sweden etc.
Norway has selected a different version with a RJ45 port with another protocol.
The dataport is a serial "P1" port in the form of a RJ12 contact that sends quite a lot of data every 10 seconds:
The data will show both consumption and production if you e.g. have solar panels at home.
My initial though was to use the Tasmota P1 Smart Meter with Mqtt. I tried this and it works, but unfortunately I got some serial data errors every 5-10th message for some reason so I decided to try another solution.
I found a few other alternatives and tested one of them. The upside with this version is that it is adapted to the Swedish data fomat that differs from the Dutch a bit and that it delivers the data in Mqtt form:
The hardware is pretty simple. For the Tasmota variant and most of the other solutions you need a ESP8266, e.g. a Wemos mini and then a transistor and two resistors (image below). The version I use is even simpler since it does not need the transistor.
For a lot of the meters delivered (DSMR 5 versions if I am right) you can power the ESP from the 5V provided in the RJ12 port, very handy.
It is also possible to buy a readymade P1 meter, this one looks quite nice, although I have not tested it.
In order to get a good overview of the data from the meter I have started creating a dashboard in Grafana that gets data from Historian in OpenLuup. It is quite useful to be able to see the load over time per phase etc.
I also managed to grab the hourly prices in json format and display that in the dashboard via some lua code in a scene.
At the moment I have built no logic around this, but it opens up posibilities for sure. In Sweden the electrical tarrifs will change from daily rates to being higher when demand is higher, perhaps then this can be used.
All in all a fun DIY project that provides some useful data out of the electrical meter. 🙂
I am new to this forum. I have been building an Alexa-based smart home for a few years. Overall, works well. I have a curious problem with a smart light. I set up a Kasa smart bulb in a ceiling can fixture. It worked well for at least 2 years. Then it began turning on randomly. Eventually, it began turning off randomly.I swapped out an identical bulb from another fixture and the problem persisted. I just replaced the ceiling fixture with a new one, properly installed, and the problem remained.
I replaced the Kasa bulb with a PlusMinus bulb. I can control it correctly, but the replacement bulb behaves in the same random on/off way.
Any ideas? I am at a loss!
SwitchBot in Openluup (was: Smaller and local alternative to MicroBots)
I have a need to just push a button, since I can't hack the thing at the moment. I know there's MicroBot, but they're bluetooth, requires and hub and are not local.
I'm OK with BT or an additional hub, but I really really want local control.
Anyone? Thanks!
if Microbot.is is what you are talking about... their whole business model is to get clients to rely on their clown servers for a price to actuate a button pusher... not a fan of the concept. Maybe replace the button with a your own button which would have a zwave relay?
@sender said in Smaller and local alternative to MicroBots:
but I use D1 mini and flash with tasmota via "tasmotizer"
I have many of them across the house, mainly to get fancy sensors (distance, humidity, light, pressure, etc), and I integrate them with my own MQTT to luup bridge, plus my virtual plugins.
Anyway, this is an appliance I can't hack at the moment, since it's still under warranty. I've ordered two and will try to integrate via BT. SwitchBot has an open BT API, documented and supported by Home Assistant, so it should be easy to just get the script and replicate it with some luup calls or whatever I'll come with
So, I received my units and start thinkering. So far, one is in place, while I need to build a support for the other.
Code is just a small node js app I built around a node library. Seems to work, and I'll report more in the future. Too bad the official hub has no local apis. I can't understand why smart people don't realize internet is not a available everywhere as in their offices... -
People don't learn fast enough. I have seen this being a larger contributor to the bankruptcy of so many startups.... Great/brilliant ideas, destroyed by cloud dependance and the cost/reliability problems/complexity it involves eventually signifying the end of the project and a lot of products dumped in the garbage or best case, a lot of customer frustration. You can probably send them the feedback to let them know...
So, mission accomplished. I wrote a very basic node app running on my Linux box. I'm using this library because I'm more comfortable with Javascript than Pyton: https://github.com/futomi/node-switchbot
But it's missing the ability to use password protected SwitchBots, so I will probably patch it or move to the Python one, depending on how many spare time I have in the coming weeks.
Node server is very simple:
const http = require('http'); const url = require('url'); const Switchbot = require('node-switchbot'); const requestListener = function (req, res) { const queryObject = url.parse(req.url, true).query; res.writeHead(200); let device = null; if (queryObject == undefined || queryObject.id == undefined) return res.end('Please specify an id'); const switchbot = new Switchbot(); switchbot.discover({ id: queryObject.id, quick: true }).then((device_list) => { if (device_list == undefined || device_list.length == 0) { console.log('#device: notfound'); res.end('no device'); } device = device_list[0]; console.log('#devicefound: ' + device.modelName + ' (' + device.address + ')'); return true; //device.connect(); }).then(() => { console.log('#device:press'); return device.press(); }).then(() => { console.log('#device:waiting'); return switchbot.wait(1000); }).then(() => { console.log('#device:disconnecting'); return device.disconnect(); }).then(() => { console.log('Done.'); res.end('OK!'); }).catch((error) => { console.error(error); res.end('error: ' + error); }); }; const server = http.createServer(requestListener); server.timeout = 5 * 1000; server.listen(5002); console.log('#http:started');
just call http://ip:5002/?id=mac and you're good to go. I just used my virtual device plug-in to have two virtual switches. It's already integrated into Alexa, WAF is high. Another thing removed from my long standing TODO list
Ok, must say. Before I was using tasmota. But since I discovered esphome.io that is now my primary start for automation devices. So easy, so cheap and so reliable!
Easily manageable via home assistant addon... -
@therealdb using esphome and in my case together with homeassistant make mqtt hassle unneeded. It automatically includes the homeassistant api. If the esphome device is part of the same subnet it is auto discovered and entities are auto populated in hass. If not in same subnet need to manually add an esphome integration per device (ip address). Other thing you need to take care of then it is "pinging" devices instead of mdns (all in manual but good to know) for "online status". I have in 1 week around 15 wifi D1 minis as sensors, nextion displays (touchscreen "wallmote quad" but cheaper and better), 4 and 8 relay boards for sprinkler, etc etc. So easy!
Yep, I underestimated those cheap wifi devices, until I started to buy many of them, just for testing. While I prefer Zwave for "serious" work, since I have 3 access points on my home (and one outside), Wifi coverage is really good and their traffic is very low anyway, so I'm somewhat sold, especially for fancy sensors and/or difficult to reach zones for my Zwave mesh.
@therealdb Thanks for the write up. I managed to setup it up with the Bot and is working. Now I just have to figure out how to write a .py and use mqtt to send the battery status over to Home Assistant.
The Switchbot Curtain is available. Do you think this will work as well? Atm, home assistant does not support the curtain.
@therealdb Thanks for the reply. Would you mind writing up commands for open and closing of curtain? I am not familiar with this code.
Someone over there has tried adding the curtain with the switchbot integration, but it does nothing. No response.
