  4. MSR Interface Remotely?
Bare metal latest-26318. I tried to add the group "ArmedSensors" but it would not show in UI. "ArmedSensors": name: Armed Sensors select: - include_capability: arming filter_expression: entity.attributes.arming.state The log: [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:15:20.412Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Nothing related before or after that I could find. I then copied an existing group to exclude type errors in the new group. "OKforLarm": name: OK för Larm select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state "OKforLarm2": name: "OK för Larm 2" select: - include_capability: door_sensor filter_expression: entity.attributes.door_sensor.state Same error in log. [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group OKforLarm2: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.793Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:ERR> DynamicGroupController#groups error updating dynamic group ArmedSensors: [TypeError] Cannot read properties of undefined (reading 'extendCapability') [-] [latest-26318]2026-11-24T14:18:29.806Z <DynamicGroupController:CRIT> TypeError: Cannot read properties of undefined (reading 'extendCapability') [-] TypeError: Cannot read properties of undefined (reading 'extendCapability') at DynamicGroupController._update_group (/home/homebridge/reactor/server/lib/DynamicGroupController.js:128:18) at DynamicGroupController._update (/home/homebridge/reactor/server/lib/DynamicGroupController.js:483:43) at process.processTicksAndRejections (node:internal/process/task_queues:104:5) at async DynamicGroupController.start (/home/homebridge/reactor/server/lib/DynamicGroupController.js:60:13) at async Promise.allSettled (index 3) Let me know if I missed something or you need more info.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
17 Posts 7 Posters 3.5k Views 6 Watching
    Tarkus
    Is there a way to access MSR interface remotely? I did the whole port forward thing to port 8111 but no luck?
    • MatohlM Offline
      MatohlM Offline
      Matohl
      Yes, I use the VNC Viewer on my RPi. What system is it on?
      • MatohlM Matohl
        Tarkus
        @matohl Android Temux, Nvidia Shield TV box
        • MatohlM Offline
          MatohlM Offline
          Matohl
          Oh, I don't know ...
            Tarkus
            I can probably team view into my home computer I but thought there may be a more direct way.
              Funny you mention this, because for giggles last night I attempted to view MSR in my mobile phone's Chrome browser from within my home network, and pretty much all panels are blank there. So no editing Rules and Expressions from the comfort of my bedroom at midnight, alas.
              ElcidE 1 Reply Last reply
                Yeah, a lot of that is going to be just going through and adding the necessary bootstrap classes for the xs, sm, and md viewports, and then seeing what doesn't make sense even then and getting it adjusted. It'll get there, although I still think editing rules on a phone is going to be only for the most... dedicated. 🙂
                  I can see the scenario where it would help though! If there is a corner scenario in the logic that I didn't think about, its almost certain that that situation hits when i'm out. Result: text with "lights are flashing!" and WAF = 0. 😄
                  I guess dataplicity would work using the same site forwarding as i use for openLuup?
                  • LibraSunL LibraSun
                    ElcidE Offline
                    ElcidE Offline
                    Elcid
                    wrote on last edited by Elcid
                    @librasun Strange that as i use android chrome and firefox browsers and there is no issues viewing MSR.
                    LibraSunL 1 Reply Last reply
                    • ElcidE Elcid
                      @elcid Weird. Here's how my Android (Pixel 4 with latest Chrome Mobile browser) renders a typical MSR page. Notice that it's blank aside from the leftmost section links.
                      Perhaps I should chalk this up to me running MSR inside a Docker container on my NAS, since we know there are other minor differences.
                        Nothing strange about it. Any device that reports a viewport smaller than "md" according to Bootstrap will not have any instructions for how to lay out the content, and no content is a likely response. Once the interface stabilizes, it will be worth the effort to comb through and add the necessary layout tweaks for smaller devices, with appurtenant placement changes, reductions in functionality, etc.
                          Indeed, when I clicked the 3-dot menu in Chrome Mobile, and ticked the "Desktop Site" box, bam... full rendering of MSR on my phone, now! Dunno why I didn't think of that before.
                            @librasun said in MSR Interface Remotely?:
                            Great! I didn't think of that either.
                            I can now access everything on my phone. Before I had the same issue you described and nothing was loaded in the right hand side pane.
                            • ElcidE Offline
                              ElcidE Offline
                              Elcid
                              You can view the left had pain on narrow screen by selecting the page, then press the 3 lines in the left top corner.
                              as in image.
                                FEATURE REQUEST
                                Include a beacon that periodically updates subscription DNS servers like DynDNS, so that users can create their own remote access solutions. Naturally, this would mean having to update API information and enabling keys in the config files.
                                  Rule with an Interval action or pulse output and a HTTP Request reaction.
                                    I failed to mention that I was thinking of this in the context of you potentially creating a paid service whereby MSR users could login remotely without steering those dollars toward established services.
                                    I'm sure that's just a pipe dream but I'm all about potential revenue sources for guys who deserve to reap the reward of their hard labor.
                                      164.5k
