  4. MSR Interface Remotely?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
17 Posts 7 Posters 2.1k Views 6 Watching
    Tarkus
    Is there a way to access MSR interface remotely? I did the whole port forward thing to port 8111 but no luck?
    • MatohlM Offline
      MatohlM Offline
      Matohl
      Yes, I use the VNC Viewer on my RPi. What system is it on?
      • MatohlM Matohl
        Tarkus
        @matohl Android Temux, Nvidia Shield TV box
        • MatohlM Offline
          MatohlM Offline
          Matohl
          Oh, I don't know ...
            Tarkus
            I can probably team view into my home computer I but thought there may be a more direct way.
              Funny you mention this, because for giggles last night I attempted to view MSR in my mobile phone's Chrome browser from within my home network, and pretty much all panels are blank there. So no editing Rules and Expressions from the comfort of my bedroom at midnight, alas.
              ElcidE 1 Reply Last reply
              • toggledbitsT Online
                toggledbitsT Online
                Yeah, a lot of that is going to be just going through and adding the necessary bootstrap classes for the xs, sm, and md viewports, and then seeing what doesn't make sense even then and getting it adjusted. It'll get there, although I still think editing rules on a phone is going to be only for the most... dedicated. 🙂
                  I can see the scenario where it would help though! If there is a corner scenario in the logic that I didn't think about, its almost certain that that situation hits when i'm out. Result: text with "lights are flashing!" and WAF = 0. 😄
                  I guess dataplicity would work using the same site forwarding as i use for openLuup?
                    wrote on last edited by Elcid
                    @librasun Strange that as i use android chrome and firefox browsers and there is no issues viewing MSR.
                    LibraSunL 1 Reply Last reply
                    • ElcidE Elcid
                      @elcid Weird. Here's how my Android (Pixel 4 with latest Chrome Mobile browser) renders a typical MSR page. Notice that it's blank aside from the leftmost section links.
                      Perhaps I should chalk this up to me running MSR inside a Docker container on my NAS, since we know there are other minor differences.
                        toggledbitsT Online
                        Nothing strange about it. Any device that reports a viewport smaller than "md" according to Bootstrap will not have any instructions for how to lay out the content, and no content is a likely response. Once the interface stabilizes, it will be worth the effort to comb through and add the necessary layout tweaks for smaller devices, with appurtenant placement changes, reductions in functionality, etc.
                          Indeed, when I clicked the 3-dot menu in Chrome Mobile, and ticked the "Desktop Site" box, bam... full rendering of MSR on my phone, now! Dunno why I didn't think of that before.
                            @librasun said in MSR Interface Remotely?:
                            Great! I didn't think of that either.
                            I can now access everything on my phone. Before I had the same issue you described and nothing was loaded in the right hand side pane.
                              You can view the left had pain on narrow screen by selecting the page, then press the 3 lines in the left top corner.
                              as in image.
                                FEATURE REQUEST
                                Include a beacon that periodically updates subscription DNS servers like DynDNS, so that users can create their own remote access solutions. Naturally, this would mean having to update API information and enabling keys in the config files.
                                  toggledbitsT Online
                                  Rule with an Interval action or pulse output and a HTTP Request reaction.
                                    I failed to mention that I was thinking of this in the context of you potentially creating a paid service whereby MSR users could login remotely without steering those dollars toward established services.
                                    I'm sure that's just a pipe dream but I'm all about potential revenue sources for guys who deserve to reap the reward of their hard labor.
                                      3.5k
                                      3.1k
                                      458
                                    • Self test
