I need a handful of victims volunteers to help test previews of the next build of Reactor. A long-standing request was for "a simple login mechanism," but in practice, adding user authentication and competent access control turned out to be a pretty big project with a lot of big changes on both server and client sides. It's a bit more than I'm comfortable testing myself and springing out to everyone at once, so I'd like to work with a small group to put it through "sea trials."
Major changes/features include:
User authentication with hashed password storage; User group configuration with application restriction (admin, dashboard, API); Detailed control over API access, with user- and token-based authentication/authorization; Improvements to the HTTPS service; Improvements to UI coordination with the core for Rules and Reactions.If this sounds like something you'd like to help with, drop me a reply here in this thread or privately.
Hi @toggledbits,
I don't know if I'm the only one, so I'm reporting here first instead of opening a bug.
Basically, with the latest 2-3 updates of Reactor and MQTTController, after a restart previous statuses are lost (for both Virtual and MQTT entities), until they're restored.
It's particularly annoying for Virtual Entities, because I have to set them all over again (I've coded some defaults at startup if the values are empty, but sometimes these are not the correct values before the update).
Not easy to reproduce, and logs are gone, but the first time I tought it was me hallucinating, the second one didn't bother too much, after the third I realized it's something not coming from me.
the behavior could be seen in this screenshot:
Any hint is appreciated.
I'm slowly migrating all my stuff to MQTT under MSR, so I have a central place to integrate everything (and, in a not-so-distant future, to remove virtual devices from my Vera and leave it running zwave only).
Anyway, here's my reactor-mqtt-contrib package:
Simply download yaml files (everything or just the ones you need) and you're good to go.
I have mapped my most useful devices, but I'll add others soon. Feel free to ask for specific templates, since I've worked a lot in the last weeks to understand and operate them.
The templates are supporting both init and query, so you have always up-to-date devices at startup, and the ability to poll them. Online status is supported as well, so you can get disconnected devices with a simple expression.
Many-many thanks to @toggledbits for its dedication, support, and patience with me and my requests 🙂
Good morning,
So Home Assistant decided to change the default weather home format that I've been using for the past year and a half. I had two Global Expressions set up to pull the high and low temp forecast for the day. Now it's pulling null values.
In the dev tools, it now uses a new service (Weather. get forecasts), plural, where the old Weather.get forecast is depreciated and now longer functions.
It shows a templow field, and a temperature field, which I presume is the forecast high.
When I head back over to MSR, I'm having a hard time finding those values in the Entities tab.
wx.asoftime=null wx.ceiling=null wx.ceiling_unit=null wx.cloud_cover=null wx.condition_code=null wx.description="partlycloudy" wx.feels_like=null wx.humidity=57 wx.humidity_unit="%" wx.icon=null wx.location=null wx.precipitation_1hr=null wx.precipitation_24hr=null wx.precipitation_other=null wx.precipitation_type=null wx.precipitation_unit="in" wx.pressure=30 wx.pressure_unit="inHg" wx.temperature=55 wx.temperature_unit="°F" wx.visibility=null wx.visibility_unit="mi" wx.wind_compass=210.3 wx.wind_conditions=null wx.wind_direction="SSW" wx.wind_gust=null wx.wind_speed=6.28 wx.wind_speed_unit="mph" x_hass.domain="weather" x_hass.entity_id="weather.forecast_home" x_hass.services=["weather"] x_hass.state="partlycloudy" x_hass_attr.attribution="Weather forecast from met.no, delivered by the Norwegian Meteorological Institute." x_hass_attr.cloud_coverage=85.9 x_hass_attr.dew_point=40 x_hass_attr.friendly_name="New Windsor Weather" x_hass_attr.humidity=57 x_hass_attr.precipitation_unit="in" x_hass_attr.pressure=30 x_hass_attr.pressure_unit="inHg" x_hass_attr.supported_features=3 x_hass_attr.temperature=55 x_hass_attr.temperature_unit="°F" x_hass_attr.visibility_unit="mi" x_hass_attr.wind_bearing=210.3 x_hass_attr.wind_speed=6.28 x_hass_attr.wind_speed_unit="mph"There is a x_hass_attr.temperature, but that appears to be the current temperature, not the high that I found on the dev tools screenshot.
Any ideas?
Running:
Core
2024.4.3
Supervisor
2024.04.0
Operating System
12.2
Frontend
20240404.2
MSR: latest-24057-e9add9f5
Home Assistant up to version 2021.8.6 supported; the online version of the manual will now state the current supported versions; Fix an error in OWMWeatherController that could cause it to stop updating; Unify the approach to entity filtering on all hub interface classes (controllers); this works for device entities only; it may be extended to other entities later; Improve error detail in messages for EzloController during auth phase; Add isRuleSet() and isRuleEnabled() functions to expressions extensions; Implement set action for lock and passage capabilities (makes them more easily scriptable in some cases); Fix a place in the UI where 24-hour time was not being displayed.Hey Patrick, I recently have been noticing that MSR has been acting up ie. it's been needing restarts and has been slow. I began trouble shooting by looking at the logs and have noticed the following errors for a lot of entities. I thought maybe a simple reboot of RPi was needed and I kept seeing the same errors in the system logs. I am oddly enough not seeing these same errors in the MSR logs. Where things started getting weird is whenever I rebooted MSR it wouldn't come back online .I would have to restart the RPi then it would come back online. I just restarted MSR again to capture logs and it restarted fine, so I guess its good for now? I think this is more or so a corrupted SD card issue rather a MSR issue but well being troubleshooting from here. The SD card is about 1-2 years old.
Apologies if this post is everywhere, I cannot consistently recreate any oddities that are happening, that's what is leading me to believe my SD is going bad.
PS: If anyone knows how to diagnose a corrupt SD card please chime in.
MSR latest-24057-e9add9f5
Home Assistant 2024.4.3
Raspberry Pi 3b+
I've rebooted the RPi I've restarted MSR after double-checking the time on the RPi. Used a completely different browser to eliminate any caching concerns. Double-checked MSR reactor.yamla5f23151-d691-4343-8499-8e77a55528e5-image.png
For the standard capabilities MSR sends both a value record and a units record to InfluxDB. The latter I would like not to send as they are not really any use for me and it will reduce the number of records send to my InfluxDB.
Is there a quick way to do this with a filter_entities line like: *>units?
Or do I have to update all capabilities to read like this:
power_sensor:
attributes:
value: true
Cheers Rene
I'm trying to replicate this
into a MQTT entity where I could set a number with a min and max value.
I can't find a standard capability that fits or any documentation on local MQTT capabilities and the only post on the forum mentioning local MQTT capabilities is this post, is it even possible in current release?
My trial and error work in local_mqtt_capabilities.yaml isn't much to show as it's just a copy of mqtt_capabilities.yaml with changed names and then I got stuck.
Any guidance, examples, documentation, future feature request or denial would be much appreciated, thanks!
Reactor 24057-e9add9f5 bare metal
MQTTController 24050
Hi guys,
Any tips are appreciated.
NOTES FROM TROUBLESHOOTING:
'rgb_color.set_rgb' works successfully, which seems strange. You'd think they would both be affected I've tried a couple different formats, like adding quotes, adding/removing spaces between the RGB values, nothing has fixed it.EXAMPLES:
DETAILS:
Bulb is LZW42 by Inovelli MSR version: stable-23242-5ee8e1d4HA DETAILS
Core 2024.2.5 Supervisor 2024.02.1 Operating System 12.0Hi,
Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
Noticed right away last night at closing time that the open/close had become inverted with the update to v23326.
Installing latest-24052-d039d560 and I did a dumb thing: moving too quickly, I deleted package.json instead of package-lock.json because the latter didn't exist.
Ran the installer script - but in the wrong directory so I moved package.json manually.
Everything has come back EXCEPT for my MQTT Cloud OwnTracks entities. They're erroring because of this:
(Don't heckle my folder structure - it's run this way for three years)
reactor.yaml is fine, all MQTT configs exactly as they should be.
The folder mqtt_templates is present:
The file it says is "unreadable" is present and hasn't changed (today's date is the Changed date because I did a quick nonsense edit to see that it was not corrupted in some way).
The logs show:
[latest-24052]2024-02-22T01:04:40.320Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_cfg, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_mfg_spec, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.321Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_device_ver, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.322Z <ZWaveJSController:WARN> zwavejs_capabilities defines x_zwave_values, which is not consistent with the recommended naming [latest-24052]2024-02-22T01:04:40.323Z <Controller:INFO> ZWaveJSController#zwavejs loaded zwavejs capabilities ver 23194 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.338Z <Controller:INFO> ZWaveJSController#zwavejs loaded implementation data ver 23254 rev 1 format 1 [latest-24052]2024-02-22T01:04:40.339Z <Structure:INFO> Starting controller SystemController#reactor_system [latest-24052]2024-02-22T01:04:40.345Z <Controller:NOTICE> Controller SystemController#reactor_system is now online. [latest-24052]2024-02-22T01:04:40.572Z <HassController:INFO> HassController#hass device mapping data loaded; checking... [latest-24052]2024-02-22T01:04:40.574Z <HassController:WARN> HassController: implementation of capability battery_maintenance does not provide attribute state [latest-24052]2024-02-22T01:04:40.577Z <HassController:WARN> HassController: implementation of capability input_select.selector does not provide attribute values [latest-24052]2024-02-22T01:04:40.586Z <MQTTController:ERR> MQTTController#mqtt can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.595Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 3) [latest-24052]2024-02-22T01:04:40.597Z <MQTTController:ERR> MQTTController#mqtt2 can't read/load templates from /home/reactor/Documents/reactor/config/mqtt_templates/owntracks_sensor.yaml: [Error] Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] [latest-24052]2024-02-22T01:04:40.603Z <MQTTController:CRIT> Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. [-] Error: Function yaml.safeLoad is removed in js-yaml 4. Use yaml.load instead, which is now safe by default. at Object.safeLoad (/home/reactor/Documents/reactor/node_modules/js-yaml/index.js:10:11) at MQTTController._load_implementation (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:807:38) at async MQTTController.start (/home/reactor/Documents/reactor/ext/MQTTController/MQTTController.js:95:13) at async Promise.allSettled (index 4) [latest-24052]2024-02-22T01:04:40.608Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.1.198:8123/api/websocket [latest-24052]2024-02-22T01:04:40.616Z <MQTTController:INFO> MQTTController#mqtt instance topic ident is mqtt [latest-24052]2024-02-22T01:04:40.617Z <Controller:INFO> MQTTController#mqtt 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.619Z <MQTTController:NOTICE> MQTTController#mqtt connecting to broker at mqtt://192.168.1.198:1883/ [latest-24052]2024-02-22T01:04:40.691Z <MQTTController:INFO> MQTTController#mqtt2 instance topic ident is mqtt2 [latest-24052]2024-02-22T01:04:40.692Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14p uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.697Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone8 uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.726Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jay uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.730Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14jen uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.735Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14addie uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.768Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_iphone14bella uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.773Z <MQTTController:ERR> MQTTController#mqtt2 entity owntracks_androidaa uses_template=owntracks_sensor, template not defined [latest-24052]2024-02-22T01:04:40.777Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_androidaa no longer available, marking BinarySensor#mqtt2>owntracks_androidaa for removal [latest-24052]2024-02-22T01:04:40.781Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14addie no longer available, marking BinarySensor#mqtt2>owntracks_iphone14addie for removal [latest-24052]2024-02-22T01:04:40.786Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14bella no longer available, marking BinarySensor#mqtt2>owntracks_iphone14bella for removal [latest-24052]2024-02-22T01:04:40.790Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jay no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jay for removal [latest-24052]2024-02-22T01:04:40.794Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14jen no longer available, marking BinarySensor#mqtt2>owntracks_iphone14jen for removal [latest-24052]2024-02-22T01:04:40.798Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone14p no longer available, marking BinarySensor#mqtt2>owntracks_iphone14p for removal [latest-24052]2024-02-22T01:04:40.802Z <MQTTController:NOTICE> MQTTController#mqtt2 device owntracks_iphone8 no longer available, marking BinarySensor#mqtt2>owntracks_iphone8 for removal [latest-24052]2024-02-22T01:04:40.807Z <Controller:INFO> MQTTController#mqtt2 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.808Z <MQTTController:NOTICE> MQTTController#mqtt2 connecting to broker at mqtts://7ef71f0117fe40d28c2df12205c4a0d0.s2.eu.hivemq.cloud:8883 [latest-24052]2024-02-22T01:04:40.816Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Driving Flag - 2 (virt1) [latest-24052]2024-02-22T01:04:40.826Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Far Away Flag - 2 (virt2) [latest-24052]2024-02-22T01:04:40.827Z <VirtualEntityController:INFO> VirtualEntityController#virtual configuring virtual Garage Door Momentary Contact vSwitch (virt3) [latest-24052]2024-02-22T01:04:40.828Z <Controller:INFO> VirtualEntityController#virtual 0 dead entities older than 86400000s purged [latest-24052]2024-02-22T01:04:40.829Z <ZWaveJSController:INFO> ZWaveJSController#zwavejs connecting to ws://192.168.1.198:3000 [latest-24052]2024-02-22T01:04:40.836Z <Controller:NOTICE> Controller VirtualEntityController#virtual is now online. [latest-24052]2024-02-22T01:04:40.839Z <app:NOTICE> Starting HTTP server and API... [latest-24052]2024-02-22T01:04:40.845Z <httpapi:NOTICE> httpapi: starting HTTP service on port 8111 [latest-24052]2024-02-22T01:04:40.854Z <app:NOTICE> Starting Reaction Engine... [latest-24052]2024-02-22T01:04:40.856Z <Engine:INFO> Reaction Engine starting [latest-24052]2024-02-22T01:04:40.857Z <Engine:INFO> Checking rule sets... [latest-24052]2024-02-22T01:04:40.880Z <Engine:INFO> Checking rules... [latest-24052]2024-02-22T01:04:41.421Z <Engine:INFO> Data check complete; no corrections. [latest-24052]2024-02-22T01:04:41.571Z <Rule:NOTICE> Driving Flag (rule-l97r2umw in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.572Z <Rule:NOTICE> Driving Flag - Far Away (rule-l97r814k in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> DST (rule-l118lzpd in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.573Z <Rule:NOTICE> HVAC Cooling Master (Local APIs) (rule-ktinsq18 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating before Alarm times (rule-l7hirm3d in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.574Z <Rule:NOTICE> HVAC Heating Master (Local APIs) (rule-ktio3vc1 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> HVAC Neutral Master (rule-ktint8c3 in Shared Rules) starting [latest-24052]2024-02-22T01:04:41.575Z <Rule:NOTICE> It's Raining (rule-lfs6r1lq in Shared Rules) starting [latest-24I'm flummoxed.
I was using this method here by @therealdb to run Lua Code from MSR on my Vera Plus but it seems to have stopped working now.
Its the one where you uploaded a file called VeraScenes.lua to your Vera hub and then you could call functions of that file to run particular bits of Lua code from an MSR reaction etc.
This was working well for a long time but I noticed today its not working now.
Looking in the MSR log after I ran a reaction in one of my rules I just saw this:
[latest-23338]2024-02-19T18:41:35.650Z <Engine:INFO> Enqueueing "Front Cam Motion Detection ON or OFF Old Method<RESET>" (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.653Z <Engine:5:Engine.js:1466> [Engine]Engine#1 enqueued reaction rule-klten9w9:R as 22989 [latest-23338]2024-02-19T18:41:35.654Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.655Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 0, "status": 0, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise] } [latest-23338]2024-02-19T18:41:35.657Z <Engine:NOTICE> Starting reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) [latest-23338]2024-02-19T18:41:35.659Z <Engine:5:Engine.js:1701> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform [Object]{ "entity": "vera>system", "action": "x_vera_sys.runlua", "args": { "lua": "VeraScenes.FrontCamMotionDetectionOff()" } } [latest-23338]2024-02-19T18:41:35.660Z <Engine:5:Engine.js:1577> _process_reaction_queue() task returned, new status 3; task 22989, history 1629572 [latest-23338]2024-02-19T18:41:35.663Z <Engine:5:Engine.js:1624> _process_reaction_queue ending with 1 in queue; none delayed/ready; waiting [latest-23338]2024-02-19T18:41:35.671Z <VeraController:ERR> [VeraController:performOnEntity] action request failed [latest-23338]2024-02-19T18:41:35.672Z <VeraController:CRIT> Error: Request failed: 401 Error [-] Error: Request failed: 401 Error at /home/stuart/reactor/server/lib/Controller.js:886:37 at process.processTicksAndRejections (node:internal/process/task_queues:95:5) [latest-23338]2024-02-19T18:41:35.673Z <Engine:ERR> [Engine]Engine#1 reaction rule-klten9w9:R step 1 perform x_vera_sys.runlua failed: [Error] Request failed: 401 Error [-] [latest-23338]2024-02-19T18:41:35.673Z <Engine:INFO> [Engine]Engine#1 action args: [Object]{ "lua": "VeraScenes.FrontCamMotionDetectionOff()" } [latest-23338]2024-02-19T18:41:35.674Z <Engine:5:Engine.js:1624> _process_reaction_queue() wake-up! [latest-23338]2024-02-19T18:41:35.675Z <Engine:5:Engine.js:1563> _process_reaction_queue() running task 22989: [Object]{ "tid": 22989, "id": "rule-klten9w9:R", "rule": "rule-klten9w9", "__reaction": [RuleReaction#rule-klten9w9:R], "next_step": 2, "status": 1, "ts": 1708368095651, "parent": --null--, "__resolve": --function--, "__reject": --function--, "__promise": [object Promise], "attempts": 0, "history_id": 1629572 } [latest-23338]2024-02-19T18:41:35.676Z <Engine:INFO> Resuming reaction Front Cam Motion Detection ON or OFF Old Method<RESET> (rule-klten9w9:R) from step 2 [latest-23338]2024-02-19T18:41:35.678Z <Engine:5:Engine.js:1753> [Engine]Engine#1 reaction rule-klten9w9:R step 3 notify Telegram with [Object]{ "message": "Front Garden CAM Motion Detection Off", "profile": "default" } [latest-23338]2024-02-19T18:41:35.685Z <Engine:INFO> Front Cam Motion Detection ON or OFF Old Method<RESET> all actions completed. [Was anyone else using this method to have Lua code run on your Vera hub being called via an MSR reaction ? Does it still work for you?
Hello all, I am trying to create a timer in home assistant that will run for the amount of seconds left in the day. To do so, my plan is to create an expression in MSR where I subtract the seconds elapsed in the day from 86400. From there I will run a service command to start the timer for the seconds I calculated in the expression. I have tried using the time () function in MSR but cannot figure out a way to just get the time elapsed today and in seconds.
I really like these new widgets in MSR status page! Still, at least for the history-widgets, a filtering capability would be helpful. I have quite a many rules running with short intervals and they are clogging these lists making it harder to see "more interesting" ones...
Can file a request in Mantis, if there's wider support for the idea?
[SOLVED] Random ghosting of lights when Away
What happens when you do "power_switch.on" from the Entities list?
@toggledbits sanity check: shouldn't this equate 00:00:30 - 00:01:30 for cycling time? (Testing purposes.)
It just took 00:12:00 to cycle and I've been staring at this 'til I'm cross-eyed.
Good eye! I realized that after taking the screen shot, was too lazy at that moment to reshoot it, so I left it suspecting that it would be a while before someone caught on. You beat my estimate! I'll amend the post text to highlight the discrepancy in situ, but yes, what you see there are my "test" values, and you should set them according to whatever timing you wish.
Edit: Mystery intensifies. It turns out my memory was incorrect, and I did go back and fix the screen shot. Capture below is what I am seeing in my post:
Notice the green "modified" bar on the left as well. So, I have no idea where that image you have is living right now, where you saw it. Is it possible we can see two different versions of the same post? That would be... unhelpful...
@toggledbits This is on me for not being clear: the screenshot in my reply was of MY system - I wanted someone else's eyes on it as I've stared at it so long any obvious error will be lost to me at this point.
If mine IS correct then this takes me back around to wondering what I've broken elsewhere in this that the cycler isn't kicking at no more than 1 1/2 minutes but, rather, taking 12 minutes.
@gwp1 said in Random ghosting of lights when Away:
Weird. From your screenshot, I definitely would have expected a Delay time of 00:30 to 01:30, not twelve minutes! And you're certain none of your Trigger conditions have a "Delay" or "Latch" or really long "Pulse" condition?
FYI, in case it matters, where you increment your Cycle Timer by 1, if you don't want that number to grow indefinitely large over time, consider:
${{ (cycler_stim + 1) % 100 }}
@gwp1 Agreed. Smart approach! I should have notated on my example that the
operator stands formodulo
which in MSR (as with most modern programming languages) yields the "remainder" after division by the whole number on the right side.Thus, this would have the effect of keeping your
cycler_stim
variable from ever growing past 99. Hardly important; you may even prefer it the way it current behaves, growing by1
indefinitely (which acts as a sort of historical counter). -
@librasun said in Random ghosting of lights when Away:
Careful here... this will produce a 0 after 100 iterations and stop cycling, because
cycler_stim==0
is used as "not cycling/deactivated". -
@toggledbits Good catch. I wasn't going down this path any time soon - but - as I said, I poke at things I'm new at and prob would have at some point.
@gwp1 I was playing with this a bit more. Timing-wise it works fine for me but I did notice occasionally it would stall. This seems to be a race condition between the way the Set reaction's group executes vs the reevaluation of the Cycler rule. The purpose of the group is to stop cycling when deactivated, so we can do this differently and get rid of the race:
New "Deactivated":
And then remove the Group from "Cycler" and do the "Set Variable" directly:
Detail of the problem/race: Groups in Reactions are queued as sub-reactions of the parent reaction. The parent blocks in the execution queue while the child group runs, and when the child group finishes, the parent is allowed to resume. But these are, in effect, two different threads of execution. As originally offered, the child thread can finish and the parent, having nothing more to do (since the child is the last thing), signals completion and is removed from the queue. The problem comes from the "Set Variable" requesting a re-evaluation inside the subgroup. Once the subgroup thread stops, it is likely, but not guaranteed, that the parent reaction will get control next; when it doesn't, it's the evaluation that occurs, and when this happens, it sees cycler_stim has changed and is non-zero, and tries to queue the Set reaction. But a reaction can only be queued once: if a reaction is already executing, it will not be queued again. So, the evaluation succeeds as expected, but can't queue the next run of Set reaction because the prior run, which is effectively at its end but hasn't declared itself finished yet, is still on the queue. So the new Set doesn't get queued because the old one is there. The old one, with nothing more to do, finally gets to execute again and declares itself finished, and at that point, no reactions are queued and the process stalls.
The fix: By making the stop of the Cycler Set reaction explicit, we ensure that it stops when needed and is removed from the queue. By removing the "Set Variable" from the group (and removing the group entirely), its update of cycler_stim is done in the main reaction thread, which finishes before the re-evaluation is allowed to begin, thus allowing the re-evaluation to queue the Set reaction again as it must.
It's worth noting that this is a side-effect of writing a rule and reaction that attempts to perpetuate itself, to run in an effectively infinite loop. In that, it works against some internal design choices meant to prevent such behaviors that might otherwise be "runaway" in normal circumstances.
One of the most tantalizing, yet ultimately frustrating, aspects of MSR is its potential use for "looping" of this exact type. I think by now we've all taken a stab at it (I know I have), but many of those attempts run into a wall which I call "chicken or the egg".
That is, on the one hand, you have to somehow "bootstrap" a looping Rule so that its Trigger conditions get it going ... but on the other hand, those conditions must not simply remain "true" or else the Rule will not loop at all. So the user is forced down one or more alleyways involving "pulse" or "interval" or revolving variable values, or -- as in this above example -- externally launching and un-launching the Rule from another rule. Whichever method you choose (I've tried them all, lol), there are potential stumbling blocks along the way.
Few, if any, users can "see" all of those prospective hazards ahead of time. MSR in some instances is designed to push back against looping: Do it too quickly, and throttling kicks in. Do it without careful synchronization, and child processes get tripped up (as has happened here). Do it with callous disregard for memory-hogging subroutines and you can bog the system down to a halt.
Ask me how I know.
By now, I think I've made every possible mistake one can make in MSR -- always my own fault -- and nearly every time I've botched a "looping Rule" I have had to fight the impulse to ask @toggledbits for a formalized "Loop" action within reactions. Like, "Why can't we have a DO..WHILE crutch here?"
Then I think, no, it's best we don't. Because (a) we're talking about a fairly advanced construct here, that (b) probably does not belong in the hands of beginning users, and (c) looping by its very nature stands at odds with an engine designed to carry out deterministic procedures in a synchronous, queued fashion.
NOTE: It's not coincidental that a Reaction's ability to directly re-run itself was removed early on in the development of MSR!
I know I'm waxing philosophical here. And I'm sure we'll all carry on crafting custom loops of one type or another -- from the simplest
each
/in
enumerator withperformAction()
buried inside, to grandioseRule A
►Rule B
behemoths. For me, the fun of it will forever be the question of "How?" -
@librasun And to think all this waxing philosophical is due to my silly ask to ghost lights in the house
Thank you both for you wisdom and infinite patience!
Thank you @toggledbits for not just providing a path but explaining the path so I (and others) can learn -- really appreciated.
@toggledbits IT LIVES!! Set to 00:00:05 - 00:00:10 for testing and lights are cycling randomly as expected.
