  4. [solved] Ordering of global expressions
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
22 Posts 4 Posters 7.4k Views 4 Watching
    Just noticed that when trying to reorder some expressions, e.g. move the most recent one from the bottom of the list to the first, this new order didn't "stick".
    At first yes, but when visiting some other menus (obviously saving before that) and then coming back, the moved item was in its original position (in the end of the list).
    I currently have 29 global expressions (which may or may not have some relevance to this problem). Using build 21281 on linux.
    Can log a PR with logs, if this seems hard to reproduce.
      Anyone noticed the same?
        So far, I haven't been able to reproduce this. It would not be a logs thing, because it's on the UI (the logs only log the server activity, and don't often provide much help in troubleshooting UI/interaction issues). You might open the JavaScript console in your browser (and which browser would that be?) and see if the browser is showing any errors there.
          @toggledbits using Chrome (94.0.4606.81) on macOS (Big Sur). Saw two errors that happened already before editing the order of expressions. Tested with build 21286
            Neither of those errors is relevant. The first isn't even from any part of the UI, looks like browser internal, and the second is from inside the Bootstrap package and also not relevant. Is this from after edit but before save? If so, do the save and see if anything is logged by the save operation.
              @toggledbits before edit & after save 🙂
                Wait... wut? That makes no sense. Let's try this again. Open the JavaScript console. Go into the Global Expressions editor. Move something to another position, then hit Save. Then report if any errors were logged.
                  I'm getting a slightly different effect with Expressions, under latest-21292-ac02d68, namely when I visit my list of existing Globals and drag one to the top of the list, then click SAVE and go visit elsewhere in the UI... upon returning to Expressions, that item now appears at the very bottom of the list. I haven't watched for browser errors in the monitor yet, just wanted to report this anomaly.
                  UPDATE: More generally, even if I drag an existing expression anywhere in the ordered list, and click SAVE, the topmost item seems always to hop to the bottom of the list. Grabbed these screen shots to illustrate:
                  BEFORE (after dragging 'sun' to the 2nd position from top)
                  exp_before.png AFTER (following SAVE, leaving 'Expressions' then returning)
                  At that point, 'Timestamp' had been bumped to the bottom of the list.
                  tunnusT wmarcolinW 2 Replies Last reply
                  • LibraSunL LibraSun
                    @librasun this is exactly the same behaviour I’m experiencing
                    @toggledbits did another test with console open, no errors
                      OK. @LibraSun 's description was a bit more concise, so I was able to find that issue. Next build tomorrow.
                      tunnusT 2 Replies Last reply
                        @toggledbits I’m good at finding bugs, but bad at explaining them 😂
                          @tunnus Sometimes it takes teamwork to get things through my thick skull, too. 😆
                            @librasun looks like you have some interesting expressions, like this one at the timestamp 😊
                            Can you share the full screen for us to look at? And of course use good ideas 😁
                            And your last comment is very good, we can find each other, but to reproduce and explain is another story 🤨
                              Just a note, @LibraSun 's timeStamp expression was necessary before the addition of strftime() to the function catalog.
                              Link to Docs
                              wmarcolinW 1 Reply Last reply
                                Link to Docs
                                @toggledbits said in Ordering of global expressions:
                                strftime()
                                Master sorry for the ignorance of your apprentice, can't this strftime() function be used this way?
                                I am getting an error.
                                • wmarcolinW wmarcolin
                                  strftime()
                                  @wmarcolin Grasshopper, the arguments for strftime() are described in the reading thus:
                                  strftime( format_string [, time ] ) — Formats time to a human-readable form controlled by format_string. If time is not given or null, the current time is used.
                                  It should be clear from this that the first argument is to be a string containing the formatting codes. A string is a sequence of characters enclosed in quotes. You are missing the quotes.
                                        Yeah, most of my more intricate Globals originated from the Before Times, and would not be applicable today. Anything worth sharing I created long ago as workarounds, for which Patrick probably has since added features to accommodate.
                                          @toggledbits just to confirm/check, that this fix (on ordering of expressions) is included in 21294?
                                            163.1k
