x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
services:
reactor:
container_name: reactor
environment:
TZ: GB
restart: "always"
expose:
- 8111
ports:
- 8111:8111
volumes:
tmpfs: /tmp
Power_switch.state - no change state - EzloPlus - Msr v. 21351-a3aef - Synology Docker
The real give-away there is the
power_switch.undefinedattribute in the list. I can reproduce the issue. I won't be able to roll a fix tonight, but I'll have something out tomorrow. -
Hi, it seems working ok. Thanks! If you need more infos to test, just tell me how I can produce them.
L Bulb FibaroDimmer2 ezlo>device_61425874129e29124dfcd75e 0.65 7:30:07 PM dimming.level=0.65 dimming.step=0.1 energy_sensor.units="KWh" energy_sensor.value=11.3400001525879 power_sensor.units="W" power_sensor.value=6.90000009536743 power_switch.state=true x_ezlo_device.battery_powered=false x_ezlo_device.category="dimmable_light" x_ezlo_device.manufacturer="Fibaro" x_ezlo_device.model="FGD-212" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="613e2024129e2912114c093b" x_ezlo_device.status="idle" x_ezlo_device.subcategory="dimmable_in_wall" x_ezlo_device.type_id="271_258_4096" x_ezlo_item.dimmer=65 x_ezlo_item.dimmer_down=0 x_ezlo_item.dimmer_stop=0 x_ezlo_item.dimmer_up=0 x_ezlo_item.electric_meter_kwh=11.3400001525879 x_ezlo_item.electric_meter_watt=6.90000009536743 x_ezlo_item.hw_state="hardware_failure" x_ezlo_item.load_error_state="unknown" x_ezlo_item.meter_reset=0 x_ezlo_item.over_current_state="unknown" x_ezlo_item.over_load_state="unknown" x_ezlo_item.power_surge_state="no_surge" x_ezlo_item.switch=true x_ezlo_item.voltage_drop_drift_state="unknown" x_ezlo_object.id="61425874129e29124dfcd75e" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Fibaro","FGD-212",null] zwave_device.node_id=27 zwave_device.version_info=null Capabilities: dimming, energy_sensor, power_sensor, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighborsanother
K Bulb Domitech ezlo>device_61423589129e29124dfcd756 0.65 7:35:42 PM dimming.level=0.65 dimming.step=0.1 power_switch.state=true x_ezlo_device.battery_powered=false x_ezlo_device.category="dimmable_light" x_ezlo_device.manufacturer="Domitech" x_ezlo_device.model="ZE27EU" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="613e2020129e2912114c093a" x_ezlo_device.status="idle" x_ezlo_device.subcategory="dimmable_bulb" x_ezlo_device.type_id="526_19522_12596" x_ezlo_item.dimmer=65 x_ezlo_item.dimmer_down=0 x_ezlo_item.dimmer_stop=0 x_ezlo_item.dimmer_up=0 x_ezlo_item.switch=true x_ezlo_object.id="61423589129e29124dfcd756" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Domitech","ZE27EU",null] zwave_device.node_id=26 zwave_device.version_info=null Capabilities: dimming, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighborsanother
H Bulb Widom dimmer ezlo>device_6147578c129e29124dfcd814 1 7:36:56 PM dimming.level=1 dimming.step=0.1 energy_sensor.units="KWh" energy_sensor.value=0.651000022888184 power_sensor.units="W" power_sensor.value=2.47000002861023 power_switch.state=true x_ezlo_device.battery_powered=false x_ezlo_device.category="dimmable_light" x_ezlo_device.manufacturer="Unknown" x_ezlo_device.model="Unknown" x_ezlo_device.parent="" x_ezlo_device.reachable=true x_ezlo_device.ready=true x_ezlo_device.room="613e2012129e2912114c0938" x_ezlo_device.status="idle" x_ezlo_device.subcategory="dimmable_in_wall" x_ezlo_device.type_id="329_4628_2560" x_ezlo_item.dimmer=100 x_ezlo_item.dimmer_down=0 x_ezlo_item.dimmer_stop=0 x_ezlo_item.dimmer_up=0 x_ezlo_item.electric_meter_kwh=0.651000022888184 x_ezlo_item.electric_meter_watt=2.47000002861023 x_ezlo_item.meter_reset=0 x_ezlo_item.switch=true x_ezlo_object.id="6147578c129e29124dfcd814" zwave_device.capabilities=null zwave_device.failed=false zwave_device.manufacturer_info=["Unknown","Unknown",null] zwave_device.node_id=41 zwave_device.version_info=null Capabilities: dimming, energy_sensor, power_sensor, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors -
