  4. Power_switch.state - no change state - EzloPlus - Msr v. 21351-a3aef - Synology Docker
22 Posts 2 Posters 6.8k Views 2 Watching
  • N Offline
    N Offline
    Hi, Power Switch and Dimmer don't change state, but seems only for this manifacture that I have:
    Widom Dimmer and Double Switch.
    On Ezlo plus they change correctly state, but in MSR Entities they are always on power_switch.state=false also If I put them ON with a reaction.
    [latest-21351]2021-12-18T15:48:52.612Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:48:52.612Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
        at Entity.setAttribute (/opt/reactor/server/lib/Entity.js:314:19)
        at /opt/reactor/server/lib/EzloController.js:1057:257
        at EzloController._update_entity (/opt/reactor/server/lib/EzloController.js:1001:55)
        at EzloController.ws_message (/opt/reactor/server/lib/EzloController.js:1386:815)
        at WebSocket.<anonymous> (/opt/reactor/server/lib/Controller.js:588:48)
        at WebSocket.emit (node:events:390:28)
        at WebSocket.emit (node:domain:475:12)
        at Receiver.receiverOnMessage (/opt/reactor/node_modules/ws/lib/websocket.js:1008:20)
        at Receiver.emit (node:events:390:28)
    [latest-21351]2021-12-18T15:49:41.720Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:49:41.720Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:50:22.258Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_61475325129e29124dfcd7e6
    [latest-21351]2021-12-18T15:50:22.259Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_61475325129e29124dfcd7e6
    [latest-21351]2021-12-18T15:51:09.464Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:51:09.465Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:51:09.514Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:51:09.515Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:02.630Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:02.631Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:02.680Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:02.681Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:51.736Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:51.736Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:51.764Z <EzloController:ERR> EzloController#ezlo ws_message handler failed: [ReferenceError]ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    [latest-21351]2021-12-18T15:52:51.764Z <EzloController:CRIT> ReferenceError: Capability energy_sensor[electric_meter_kwh] not extended (ezlo>device_6187b203129e2912286888bf
    -Docker on Synology NAS
    -HASS Docker 2026.8.1
    -ZWaveJS-UI 11.22.3
    -Update 16/08/2026
    • N Offline
      N Offline
      At the moment the bulb is on, and this is what I see in Entities
      dimming.level=0
      dimming.step=0.1
      energy_sensor.units=null
      energy_sensor.value=null
      x_ezlo_device.battery_powered=false
      x_ezlo_device.category="dimmable_light"
      x_ezlo_device.manufacturer="Unknown"
      x_ezlo_device.model="Unknown"
      x_ezlo_device.parent=""
      x_ezlo_device.reachable=true
      x_ezlo_device.ready=true
      x_ezlo_device.room="613e2012129e2912114c0938"
      x_ezlo_device.status="idle"
      x_ezlo_device.subcategory="dimmable_in_wall"
      x_ezlo_device.type_id="329_4628_2560"
      x_ezlo_item.dimmer=0
      x_ezlo_item.dimmer_down=0
      x_ezlo_item.dimmer_stop=0
      x_ezlo_item.dimmer_up=0
      x_ezlo_item.electric_meter_kwh=0.492000013589859
      x_ezlo_item.electric_meter_watt=0
      x_ezlo_item.meter_reset=0
      x_ezlo_item.switch=false
      x_ezlo_object.id="6147578c129e29124dfcd814"
      zwave_device.capabilities=null
      zwave_device.failed=false
      zwave_device.manufacturer_info=["Unknown","Unknown",null]
      zwave_device.node_id=41
      zwave_device.version_info=null
      Capabilities: dimming, energy_sensor, power_switch, toggle, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
      Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
      -ZWaveJS-UI 11.22.3
      -Update 16/08/2026
        Thanks for the report and good info. I've posted a blind update 21352. Upgrade your container to that and let's see if those errors go away (spoiler: they should).
        • N Offline
          N Offline
          wrote on last edited by noelab
          Hi, thanks... It is ok for power_switch.state when the bulb is on. This is what I see in entities:
          dimming.level=1
          dimming.step=0.1
          energy_sensor.value=0.5
          power_sensor.units=null
          power_sensor.value=2.48000001907349
          power_switch.state=true
          x_ezlo_item.dimmer=100
          x_ezlo_item.electric_meter_kwh=0.5
          x_ezlo_item.electric_meter_watt=2.48000001907349
          x_ezlo_item.switch=true
          Capabilities: dimming, energy_sensor, power_sensor, power_switch, toggle, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
          but in log, there is stil this problem:
          [latest-21352]2021-12-19T22:26:48.725Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1
          [latest-21352]2021-12-19T22:26:48.808Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1
          [latest-21352]2021-12-19T22:26:48.830Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1
          [latest-21352]2021-12-19T22:27:13.704Z <wsapi:INFO> client "172.18.0.1#3" closed, code=1001, reason=
          [latest-21352]2021-12-19T22:27:14.191Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1
          [latest-21352]2021-12-19T22:27:19.338Z <wsapi:INFO> client "172.18.0.1#1" closed, code=1001, reason=
          [latest-21352]2021-12-19T22:27:19.749Z <wsapi:INFO> wsapi: connection from ::ffff:172.18.0.1
          [latest-21352]2021-12-19T22:27:25.745Z <wsapi:INFO> client "172.18.0.1#2" closed, code=1001, reason=
          [latest-21352]2021-12-19T22:29:32.187Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:32.187Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:32.237Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:32.237Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:32.289Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:32.289Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:32.389Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:32.389Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:44.819Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'KWh' for attribute units of energy_sensor#electric_meter_kwh (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:44.820Z <EzloController:WARN> EzloController#ezlo failed to evaluate expression item.scale ?? 'W' for attribute units of power_sensor#electric_meter_watt (category=switch): [ReferenceError]ReferenceError: Invalid reference to member scale of null
          [latest-21352]2021-12-19T22:29:58.871Z <Rule:5:Rule.js:771> Rule#rule-kthqmgb6 vR4 DLT 01 Bulb ID  requesting eval; entity-changed from Entity#vera>device_726
          -ZWaveJS-UI 11.22.3
          -Update 16/08/2026
            OK. That's almost working as it should. At least it's not getting in the way of the state update. One more time... blind build 21353 is now available.
            • N Offline
              N Offline
              I divide in two posts the log :
              [latest-21353]2021-12-19T23:08:39.981Z <Structure:INFO> Starting controller EzloController#ezlo
              [latest-21353]2021-12-19T23:08:39.995Z <EzloController:INFO> EzloController#ezlo device mapping data loaded; checking...
              [latest-21353]2021-12-19T23:08:39.997Z <EzloController:ERR> EzloController#ezlo implementation data references undefined capability power_sensor#electric_meter_watt
              [latest-21353]2021-12-19T23:08:39.998Z <EzloController:ERR> EzloController#ezlo implementation data references undefined capability energy_sensor#electric_meter_kwh
              [latest-21353]2021-12-19T23:08:39.999Z <EzloController:INFO> EzloController#ezlo performing hub login without cloud authentication (hub.offline.anonymous_access must be enabled)
              [latest-21353]2021-12-19T23:08:40.000Z <Structure:INFO> Starting controller OWMWeatherController#weather
              [latest-21353]2021-12-19T23:08:40.028Z <Structure:INFO> Starting controller SystemController#reactor_system
              [latest-21353]2021-12-19T23:08:40.030Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
              [latest-21353]2021-12-19T23:08:40.058Z <EzloController:INFO> EzloController#ezlo opening hub connection to "90000464" at wss://10.0.4.119:17000
              [latest-21353]2021-12-19T23:08:40.065Z <app:INFO> Structure running; pausing for controllers' initial ready
              [latest-21353]2021-12-19T23:08:40.163Z <VeraController:WARN> VeraController#vera ignoring geotag ([Object]{ "iduser": 1520131, "geotags": [ { "PK_User": 0, "id": 1, "accuracy": 0, "ishome": 1, "notify": 1, "radius": 100, "address": ", "color": "006e45", "latitude": "43.79130238128065", "longitude": "11.251052767038345", "name": "", "status": --null-- } ] }) for user 1520131, user not in user list
              [latest-21353]2021-12-19T23:08:40.203Z <EzloController:INFO> EzloController#ezlo hub websocket connected (wss://10.0.4.119:17000)
              [latest-21353]2021-12-19T23:08:40.204Z <EzloController:INFO> EzloController#ezlo hub websocket connected; inventory hub...
              [latest-21353]2021-12-19T23:08:40.272Z <EzloController:INFO> EzloController#ezlo hub "90000464" is h2.1 (undefined) firmware "2.0.23.1817.1"
              [latest-21353]2021-12-19T23:08:40.315Z <OWMWeatherController:INFO> OWMWeatherController#weather done; 1 locations, 0 failed
              [latest-21353]2021-12-19T23:08:40.317Z <OWMWeatherController:NOTICE> Controller OWMWeatherController#weather is now online.
              [latest-21353]2021-12-19T23:08:40.596Z <VeraController:NOTICE> Controller VeraController#vera is now online.
              [latest-21353]2021-12-19T23:08:41.069Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0982" (Entity#ezlo>device_613e2959129e2912114c0982); has [Array][ "613e2959129e2912114c0983", "basic", "613e2959129e2912114c0984", "battery", "613e2959129e2912114c0985", "tampering_cover_alarm", "613e2959129e2912114c0986", "acceleration_x_axis", "613e2959129e2912114c0987", "acceleration_y_axis", "613e2959129e2912114c0988", "acceleration_z_axis", "613e2959129e2912114c0989", "motion", "613e2959129e2912114c098a", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.071Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0982" (Entity#ezlo>device_613e2959129e2912114c0982); has [Array][ "613e2959129e2912114c0983", "basic", "613e2959129e2912114c0984", "battery", "613e2959129e2912114c0985", "tampering_cover_alarm", "613e2959129e2912114c0986", "acceleration_x_axis", "613e2959129e2912114c0987", "acceleration_y_axis", "613e2959129e2912114c0988", "acceleration_z_axis", "613e2959129e2912114c0989", "motion", "613e2959129e2912114c098a", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.074Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c098d" (Entity#ezlo>device_613e2959129e2912114c098d); has [Array][ "613e2959129e2912114c098e", "temp" ]
              [latest-21353]2021-12-19T23:08:41.074Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c098d" (Entity#ezlo>device_613e2959129e2912114c098d); has [Array][ "613e2959129e2912114c098e", "temp" ]
              [latest-21353]2021-12-19T23:08:41.076Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c098f" (Entity#ezlo>device_613e2959129e2912114c098f); has [Array][ "613e2959129e2912114c0990", "lux" ]
              [latest-21353]2021-12-19T23:08:41.076Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c098f" (Entity#ezlo>device_613e2959129e2912114c098f); has [Array][ "613e2959129e2912114c0990", "lux" ]
              [latest-21353]2021-12-19T23:08:41.078Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
              [latest-21353]2021-12-19T23:08:41.078Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "613e2959129e2912114c0991" (Entity#ezlo>device_613e2959129e2912114c0991); has [Array][ "613e2959129e2912114c0992", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.079Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "613e2959129e2912114c0991" (Entity#ezlo>device_613e2959129e2912114c0991); has [Array][ "613e2959129e2912114c0992", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.094Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d55129e29124dfcd782" (Entity#ezlo>device_61425d55129e29124dfcd782); has [Array][ "61425d55129e29124dfcd783", "basic", "61425d56129e29124dfcd784", "battery", "61425d56129e29124dfcd785", "tampering_cover_alarm", "61425d56129e29124dfcd786", "acceleration_x_axis", "61425d56129e29124dfcd787", "acceleration_y_axis", "61425d56129e29124dfcd788", "acceleration_z_axis", "61425d56129e29124dfcd789", "motion", "61425d56129e29124dfcd78a", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.095Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
              [latest-21353]2021-12-19T23:08:41.096Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78b" (Entity#ezlo>device_61425d56129e29124dfcd78b); has [Array][ "61425d56129e29124dfcd78c", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.096Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78b" (Entity#ezlo>device_61425d56129e29124dfcd78b); has [Array][ "61425d56129e29124dfcd78c", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.097Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78d" (Entity#ezlo>device_61425d56129e29124dfcd78d); has [Array][ "61425d56129e29124dfcd78e", "temp" ]
              [latest-21353]2021-12-19T23:08:41.097Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78d" (Entity#ezlo>device_61425d56129e29124dfcd78d); has [Array][ "61425d56129e29124dfcd78e", "temp" ]
              [latest-21353]2021-12-19T23:08:41.098Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "61425d56129e29124dfcd78f" (Entity#ezlo>device_61425d56129e29124dfcd78f); has [Array][ "61425d56129e29124dfcd790", "lux" ]
              [latest-21353]2021-12-19T23:08:41.099Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "61425d56129e29124dfcd78f" (Entity#ezlo>device_61425d56129e29124dfcd78f); has [Array][ "61425d56129e29124dfcd790", "lux" ]
              [latest-21353]2021-12-19T23:08:41.106Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c693129e29124dfcd7a7" (Entity#ezlo>device_6145c693129e29124dfcd7a7); has [Array][ "6145c693129e29124dfcd7a8", "basic", "6145c693129e29124dfcd7a9", "battery", "6145c693129e29124dfcd7aa", "tampering_cover_alarm", "6145c693129e29124dfcd7ab", "acceleration_x_axis", "6145c693129e29124dfcd7ac", "acceleration_y_axis", "6145c694129e29124dfcd7ad", "acceleration_z_axis", "6145c694129e29124dfcd7ae", "motion", "6145c694129e29124dfcd7af", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.107Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c693129e29124dfcd7a7" (Entity#ezlo>device_6145c693129e29124dfcd7a7); has [Array][ "6145c693129e29124dfcd7a8", "basic", "6145c693129e29124dfcd7a9", "battery", "6145c693129e29124dfcd7aa", "tampering_cover_alarm", "6145c693129e29124dfcd7ab", "acceleration_x_axis", "6145c693129e29124dfcd7ac", "acceleration_y_axis", "6145c694129e29124dfcd7ad", "acceleration_z_axis", "6145c694129e29124dfcd7ae", "motion", "6145c694129e29124dfcd7af", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.108Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b0" (Entity#ezlo>device_6145c694129e29124dfcd7b0); has [Array][ "6145c694129e29124dfcd7b1", "temp" ]
              [latest-21353]2021-12-19T23:08:41.109Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b0" (Entity#ezlo>device_6145c694129e29124dfcd7b0); has [Array][ "6145c694129e29124dfcd7b1", "temp" ]
              [latest-21353]2021-12-19T23:08:41.110Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b2" (Entity#ezlo>device_6145c694129e29124dfcd7b2); has [Array][ "6145c694129e29124dfcd7b3", "lux" ]
              [latest-21353]2021-12-19T23:08:41.111Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b2" (Entity#ezlo>device_6145c694129e29124dfcd7b2); has [Array][ "6145c694129e29124dfcd7b3", "lux" ]
              [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
              [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c694129e29124dfcd7b4" (Entity#ezlo>device_6145c694129e29124dfcd7b4); has [Array][ "6145c694129e29124dfcd7b5", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.112Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c694129e29124dfcd7b4" (Entity#ezlo>device_6145c694129e29124dfcd7b4); has [Array][ "6145c694129e29124dfcd7b5", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.113Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7ba" (Entity#ezlo>device_6145c7ca129e29124dfcd7ba); has [Array][ "6145c7ca129e29124dfcd7bb", "basic", "6145c7ca129e29124dfcd7bc", "battery", "6145c7ca129e29124dfcd7bd", "motion", "6145c7ca129e29124dfcd7be", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.114Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7ba" (Entity#ezlo>device_6145c7ca129e29124dfcd7ba); has [Array][ "6145c7ca129e29124dfcd7bb", "basic", "6145c7ca129e29124dfcd7bc", "battery", "6145c7ca129e29124dfcd7bd", "motion", "6145c7ca129e29124dfcd7be", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.115Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c7ca129e29124dfcd7bf" (Entity#ezlo>device_6145c7ca129e29124dfcd7bf); has [Array][ "6145c7ca129e29124dfcd7c0", "lux" ]
              [latest-21353]2021-12-19T23:08:41.115Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7bf" (Entity#ezlo>device_6145c7ca129e29124dfcd7bf); has [Array][ "6145c7ca129e29124dfcd7c0", "lux" ]
              [latest-21353]2021-12-19T23:08:41.116Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "6145c7ca129e29124dfcd7c1" (Entity#ezlo>device_6145c7ca129e29124dfcd7c1); has [Array][ "6145c7ca129e29124dfcd7c2", "temp" ]
              [latest-21353]2021-12-19T23:08:41.116Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "6145c7ca129e29124dfcd7c1" (Entity#ezlo>device_6145c7ca129e29124dfcd7c1); has [Array][ "6145c7ca129e29124dfcd7c2", "temp" ]
              [latest-21353]2021-12-19T23:08:41.124Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd805" (Entity#ezlo>device_614755cd129e29124dfcd805); has [Array][ "614755cd129e29124dfcd806", "basic", "614755cd129e29124dfcd807", "battery", "614755cd129e29124dfcd808", "tampering_cover_alarm", "614755cd129e29124dfcd809", "acceleration_x_axis", "614755cd129e29124dfcd80a", "acceleration_y_axis", "614755cd129e29124dfcd80b", "acceleration_z_axis", "614755cd129e29124dfcd80c", "motion", "614755cd129e29124dfcd80d", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.125Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd805" (Entity#ezlo>device_614755cd129e29124dfcd805); has [Array][ "614755cd129e29124dfcd806", "basic", "614755cd129e29124dfcd807", "battery", "614755cd129e29124dfcd808", "tampering_cover_alarm", "614755cd129e29124dfcd809", "acceleration_x_axis", "614755cd129e29124dfcd80a", "acceleration_y_axis", "614755cd129e29124dfcd80b", "acceleration_z_axis", "614755cd129e29124dfcd80c", "motion", "614755cd129e29124dfcd80d", "security_threat" ]
              [latest-21353]2021-12-19T23:08:41.126Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755cd129e29124dfcd80e" (Entity#ezlo>device_614755cd129e29124dfcd80e); has [Array][ "614755ce129e29124dfcd80f", "temp" ]
              [latest-21353]2021-12-19T23:08:41.126Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755cd129e29124dfcd80e" (Entity#ezlo>device_614755cd129e29124dfcd80e); has [Array][ "614755ce129e29124dfcd80f", "temp" ]
              [latest-21353]2021-12-19T23:08:41.127Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755ce129e29124dfcd810" (Entity#ezlo>device_614755ce129e29124dfcd810); has [Array][ "614755ce129e29124dfcd811", "lux" ]
              [latest-21353]2021-12-19T23:08:41.127Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755ce129e29124dfcd810" (Entity#ezlo>device_614755ce129e29124dfcd810); has [Array][ "614755ce129e29124dfcd811", "lux" ]
              [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=level_sensor cap value_sensor
              [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "614755ce129e29124dfcd812" (Entity#ezlo>device_614755ce129e29124dfcd812); has [Array][ "614755ce129e29124dfcd813", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.129Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "614755ce129e29124dfcd812" (Entity#ezlo>device_614755ce129e29124dfcd812); has [Array][ "614755ce129e29124dfcd813", "seismic_intensity" ]
              [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.132Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.133Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c30129e29124dfcd83b" (Entity#ezlo>device_614e0c30129e29124dfcd83b); has [Array][ "614e0c30129e29124dfcd83c", "switch", "614e0c30129e29124dfcd83d", "dimmer", "614e0c31129e29124dfcd83e", "dimmer_up", "614e0c31129e29124dfcd83f", "dimmer_down", "614e0c31129e29124dfcd840", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.134Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd841" (Entity#ezlo>device_614e0c31129e29124dfcd841); has [Array][ "614e0c31129e29124dfcd842", "switch", "614e0c31129e29124dfcd843", "dimmer", "614e0c31129e29124dfcd844", "dimmer_up", "614e0c31129e29124dfcd845", "dimmer_down", "614e0c31129e29124dfcd846", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.135Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.136Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd847" (Entity#ezlo>device_614e0c31129e29124dfcd847); has [Array][ "614e0c31129e29124dfcd848", "switch", "614e0c31129e29124dfcd849", "dimmer", "614e0c31129e29124dfcd84a", "dimmer_up", "614e0c31129e29124dfcd84b", "dimmer_down", "614e0c31129e29124dfcd84c", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.137Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.138Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "614e0c31129e29124dfcd84d" (Entity#ezlo>device_614e0c31129e29124dfcd84d); has [Array][ "614e0c31129e29124dfcd84e", "switch", "614e0c32129e29124dfcd84f", "dimmer", "614e0c32129e29124dfcd850", "dimmer_up", "614e0c32129e29124dfcd851", "dimmer_down", "614e0c32129e29124dfcd852", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.145Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.145Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
              [latest-21353]2021-12-19T23:08:41.146Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
              -ZWaveJS-UI 11.22.3
              -Update 16/08/2026
              • N Offline
                N Offline
                [latest-21353]2021-12-19T23:08:41.146Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e30c" (Entity#ezlo>device_61508730129e29124787e30c); has [Array][ "61508730129e29124787e30d", "switch", "61508730129e29124787e30e", "dimmer", "61508730129e29124787e30f", "dimmer_up", "61508730129e29124787e310", "dimmer_down", "61508730129e29124787e311", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.147Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.147Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.148Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.148Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e312" (Entity#ezlo>device_61508730129e29124787e312); has [Array][ "61508730129e29124787e313", "switch", "61508730129e29124787e314", "dimmer", "61508730129e29124787e315", "dimmer_up", "61508730129e29124787e316", "dimmer_down", "61508730129e29124787e317", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.149Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.149Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.150Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.150Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508730129e29124787e318" (Entity#ezlo>device_61508730129e29124787e318); has [Array][ "61508730129e29124787e319", "switch", "61508730129e29124787e31a", "dimmer", "61508730129e29124787e31b", "dimmer_up", "61508730129e29124787e31c", "dimmer_down", "61508731129e29124787e31d", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.151Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.151Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.152Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.152Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61508731129e29124787e31e" (Entity#ezlo>device_61508731129e29124787e31e); has [Array][ "61508731129e29124787e31f", "switch", "61508731129e29124787e320", "dimmer", "61508731129e29124787e321", "dimmer_up", "61508731129e29124787e322", "dimmer_down", "61508731129e29124787e323", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.154Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.155Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522118129e291232d6d9fd" (Entity#ezlo>device_61522118129e291232d6d9fd); has [Array][ "61522118129e291232d6d9fe", "switch", "61522118129e291232d6d9ff", "dimmer", "61522118129e291232d6da00", "dimmer_up", "61522118129e291232d6da01", "dimmer_down", "61522118129e291232d6da02", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.156Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.157Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522118129e291232d6da03" (Entity#ezlo>device_61522118129e291232d6da03); has [Array][ "61522118129e291232d6da04", "switch", "61522118129e291232d6da05", "dimmer", "61522118129e291232d6da06", "dimmer_up", "61522119129e291232d6da07", "dimmer_down", "61522119129e291232d6da08", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.158Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.159Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522119129e291232d6da09" (Entity#ezlo>device_61522119129e291232d6da09); has [Array][ "61522119129e291232d6da0a", "switch", "61522119129e291232d6da0b", "dimmer", "61522119129e291232d6da0c", "dimmer_up", "61522119129e291232d6da0d", "dimmer_down", "61522119129e291232d6da0e", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.161Z <EzloController:WARN> EzloController#ezlo updating red for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating green for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating blue for rgb_color: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.162Z <EzloController:WARN> EzloController#ezlo updating value for color_temperature: item named rgbcolor not found on "61522119129e291232d6da0f" (Entity#ezlo>device_61522119129e291232d6da0f); has [Array][ "61522119129e291232d6da10", "switch", "61522119129e291232d6da11", "dimmer", "61522119129e291232d6da12", "dimmer_up", "61522119129e291232d6da13", "dimmer_down", "61522119129e291232d6da14", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.173Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198168b129e2918c5ce97bc" (Entity#ezlo>device_6198168b129e2918c5ce97bc); has [Array][ "6198168b129e2918c5ce97bd", "dimmer", "6198168b129e2918c5ce97be", "dimmer_up", "6198168b129e2918c5ce97bf", "dimmer_down", "6198168b129e2918c5ce97c0", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.174Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619816bb129e2918c5ce97c1" (Entity#ezlo>device_619816bb129e2918c5ce97c1); has [Array][ "619816bb129e2918c5ce97c2", "dimmer", "619816bb129e2918c5ce97c3", "dimmer_up", "619816bc129e2918c5ce97c4", "dimmer_down", "619816bc129e2918c5ce97c5", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.175Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198173f129e2918c5ce97c6" (Entity#ezlo>device_6198173f129e2918c5ce97c6); has [Array][ "6198173f129e2918c5ce97c7", "dimmer", "6198173f129e2918c5ce97c8", "dimmer_up", "6198173f129e2918c5ce97c9", "dimmer_down", "6198173f129e2918c5ce97ca", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.176Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "61981760129e2918c5ce97cb" (Entity#ezlo>device_61981760129e2918c5ce97cb); has [Array][ "61981760129e2918c5ce97cc", "dimmer", "61981760129e2918c5ce97cd", "dimmer_up", "61981760129e2918c5ce97ce", "dimmer_down", "61981760129e2918c5ce97cf", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.177Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "61981770129e2918c5ce97d0" (Entity#ezlo>device_61981770129e2918c5ce97d0); has [Array][ "61981770129e2918c5ce97d1", "dimmer", "61981770129e2918c5ce97d2", "dimmer_up", "61981770129e2918c5ce97d3", "dimmer_down", "61981770129e2918c5ce97d4", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.178Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198177e129e2918c5ce97d5" (Entity#ezlo>device_6198177e129e2918c5ce97d5); has [Array][ "6198177e129e2918c5ce97d6", "dimmer", "6198177e129e2918c5ce97d7", "dimmer_up", "6198177e129e2918c5ce97d8", "dimmer_down", "6198177e129e2918c5ce97d9", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.179Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198178b129e2918c5ce97da" (Entity#ezlo>device_6198178b129e2918c5ce97da); has [Array][ "6198178b129e2918c5ce97db", "dimmer", "6198178b129e2918c5ce97dc", "dimmer_up", "6198178b129e2918c5ce97dd", "dimmer_down", "6198178b129e2918c5ce97de", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.183Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "6198179b129e2918c5ce97df" (Entity#ezlo>device_6198179b129e2918c5ce97df); has [Array][ "6198179b129e2918c5ce97e0", "dimmer", "6198179b129e2918c5ce97e1", "dimmer_up", "6198179b129e2918c5ce97e2", "dimmer_down", "6198179b129e2918c5ce97e3", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.184Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817a6129e2918c5ce97e4" (Entity#ezlo>device_619817a6129e2918c5ce97e4); has [Array][ "619817a6129e2918c5ce97e5", "dimmer", "619817a7129e2918c5ce97e6", "dimmer_up", "619817a7129e2918c5ce97e7", "dimmer_down", "619817a7129e2918c5ce97e8", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.185Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817b2129e2918c5ce97e9" (Entity#ezlo>device_619817b2129e2918c5ce97e9); has [Array][ "619817b2129e2918c5ce97ea", "dimmer", "619817b3129e2918c5ce97eb", "dimmer_up", "619817b3129e2918c5ce97ec", "dimmer_down", "619817b3129e2918c5ce97ed", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.186Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817c2129e2918c5ce97ee" (Entity#ezlo>device_619817c2129e2918c5ce97ee); has [Array][ "619817c3129e2918c5ce97ef", "dimmer", "619817c3129e2918c5ce97f0", "dimmer_up", "619817c3129e2918c5ce97f1", "dimmer_down", "619817c3129e2918c5ce97f2", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.187Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817d0129e2918c5ce97f3" (Entity#ezlo>device_619817d0129e2918c5ce97f3); has [Array][ "619817d0129e2918c5ce97f4", "dimmer", "619817d0129e2918c5ce97f5", "dimmer_up", "619817d0129e2918c5ce97f6", "dimmer_down", "619817d0129e2918c5ce97f7", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.190Z <EzloController:WARN> EzloController#ezlo updating state for power_switch: item named switch not found on "619817de129e2918c5ce97f8" (Entity#ezlo>device_619817de129e2918c5ce97f8); has [Array][ "619817de129e2918c5ce97f9", "dimmer", "619817de129e2918c5ce97fa", "dimmer_up", "619817de129e2918c5ce97fb", "dimmer_down", "619817de129e2918c5ce97fc", "dimmer_stop" ]
                [latest-21353]2021-12-19T23:08:41.192Z <EzloController:WARN> EzloController#ezlo no implementation mapping for attributes from match category=door_lock cap keypad
                [latest-21353]2021-12-19T23:08:41.196Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903e9129e29123e89442e" (Entity#ezlo>device_619903e9129e29123e89442e); has [Array][ "619903e9129e29123e89442f", "basic", "619903e9129e29123e894430", "battery", "619903e9129e29123e894431", "tampering_cover_alarm", "619903e9129e29123e894432", "battery_maintenance_state", "619903e9129e29123e894433", "dw_state", "619903e9129e29123e894434", "security_threat" ]
                [latest-21353]2021-12-19T23:08:41.198Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "619903e9129e29123e894437" (Entity#ezlo>device_619903e9129e29123e894437); has [Array][ "619903ea129e29123e894438", "heat_alarm", "619903ea129e29123e894439", "security_threat" ]
                [latest-21353]2021-12-19T23:08:41.198Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903e9129e29123e894437" (Entity#ezlo>device_619903e9129e29123e894437); has [Array][ "619903ea129e29123e894438", "heat_alarm", "619903ea129e29123e894439", "security_threat" ]
                [latest-21353]2021-12-19T23:08:41.200Z <EzloController:WARN> EzloController#ezlo updating level for battery_power: item named battery not found on "619903ea129e29123e89443a" (Entity#ezlo>device_619903ea129e29123e89443a); has [Array][ "619903ea129e29123e89443b", "temp" ]
                [latest-21353]2021-12-19T23:08:41.200Z <EzloController:WARN> EzloController#ezlo updating charging for x_ezlo_battery_state: item named battery_charging_state not found on "619903ea129e29123e89443a" (Entity#ezlo>device_619903ea129e29123e89443a); has [Array][ "619903ea129e29123e89443b", "temp" ]
                [latest-21353]2021-12-19T23:08:41.239Z <EzloController:INFO> EzloController#ezlo hub inventory complete/successful; 1034ms
                -ZWaveJS-UI 11.22.3
                -Update 16/08/2026
                  OK. Those are benign, but I'd still like to try and clean them up. There are devices listed that aren't in the previous upload you gave me, so can I ask that you use that upload link previously sent (in DM to you here) and upload the latest [data--see edit below] file from your logs directory? That will tell me what the devices are reporting more clearly.
                  Edit: the file is now called ezlo_inventory.json for the latest version.
                  • N Offline
                    N Offline
                    Hi, the file it is uploaded.
                    -ZWaveJS-UI 11.22.3
                    -Update 16/08/2026
                    • N Offline
                      N Offline
                      If can help, today I added another zwave device "Widom Smart Plug" https://www.widom.it/wp-content/uploads/2019/08/Widom-Smart-Plug_EN_20190404_0.pdf
                      At the moment it is ON and in Entities power.switch_state is FALSE
                      energy_sensor.units="kilo_watt_hour"
                      energy_sensor.value=0.0230000000447035
                      power_sensor.units="watt"
                      power_sensor.value=36.7000007629395
                      x_ezlo_device.category="switch"
                      x_ezlo_device.room="613e2037129e2912114c093e"
                      x_ezlo_device.subcategory="interior_plugin"
                      x_ezlo_device.type_id="329_4628_1792"
                      x_ezlo_item.electric_meter_kwh=0.0230000000447035
                      x_ezlo_item.electric_meter_volt=230.399993896484
                      x_ezlo_item.electric_meter_watt=36.7000007629395
                      x_ezlo_object.id="61c18f96129e291255528096"
                      zwave_device.node_id=60
                      Capabilities: energy_sensor, power_sensor, power_switch, toggle, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                      Actions: power_switch.off, power_switch.on, power_switch.set, toggle.toggle, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
                      -ZWaveJS-UI 11.22.3
                      -Update 16/08/2026
                        OK. If you would please, upload your ezlo_inventory.json file again.
                        I would also note that the switch item (seen in raw form in x_ezlo_item.switch) also says false, so check in the (Vera/Ezlo) mobile app what it reports for state. It's not relevant what state the switch is physically in, only what state the hub thinks its in. If they don't agree, neither will Reactor.
                        • N Offline
                          N Offline
                          Hi, checking Ezlo app and the device is also in OFF state on Dashboard. So the problem is not Reactor but Ezlo.
                          -ZWaveJS-UI 11.22.3
                          -Update 16/08/2026
                            OK. New data maps with no further changes to previous work, so I'm going to go ahead and build. Watch for the update announcement in that topic.
                            • N Offline
                              N Offline
                              Hi and Happy New Year!
                              Trying a new test between MSR capability vs. Ezlo attribute and they show different. At the moment all devices are ON in the room:
                              -ZWaveJS-UI 11.22.3
                              -Update 16/08/2026
                                Any errors in the log? You know you always need to look there whenever things don't seem right, yes?
                                Also, I would do a hard-refresh of the browser and open that page again. I have seen it get out of sync once in a while but I haven't been able to figure out why as yet.
                                • N Offline
                                  N Offline
                                  Updating to the last version, and doing a hard-refresh (F5) on the page, comparing the two images: now there are two devices ON
                                  ![alt text](b4a4f3cc-d2d2-4512-b8b0-eea49f845e70-image.png image url)
                                  I will try to close the brower and to erase data on the browser.
                                  -ZWaveJS-UI 11.22.3
                                  -Update 16/08/2026
                                  • N Offline
                                    N Offline
                                    Now seems ok, no error in the log. It was related to Google Chrome. Thanks!
                                    ![alt text](28e558ac-598b-4063-b0f7-eb96de2f993c-image.png image url)
                                    -ZWaveJS-UI 11.22.3
                                    -Update 16/08/2026
                                      Not so sure... try changing the switch state of one of them (toggle one of them manually), see if both attributes follow... I'm guessing they'll diverge...
                                      • N Offline
                                        N Offline
                                        eheh, I was hoping to go happy to sleep 🙂 Yes, they diverge:
                                        ![alt text](c32f3243-5ef7-48d4-a5e9-ef1b5d72df08-image.png image url)
                                        -ZWaveJS-UI 11.22.3
                                        -Update 16/08/2026
                                        • N Offline
                                          N Offline
                                          what I can notice in "Entities" is that at the moment this device is OFF, but dimmer_level is =1
                                          L Bulb Spot Widom Dimmer
                                          2:16:40 AM
                                          dimming.level=1
                                          dimming.step=0.1
                                          dimming.undefined=0
                                          energy_sensor.undefined="KWh"
                                          energy_sensor.units="KWh"
                                          energy_sensor.value=0.994000017642975
                                          power_sensor.undefined="W"
                                          power_sensor.units="W"
                                          power_sensor.value=7.96000003814697
                                          power_switch.undefined=false
                                          x_ezlo_device.room="613e2024129e2912114c093b"
                                          x_ezlo_item.electric_meter_kwh=0.996999979019165
                                          x_ezlo_object.id="61475325129e29124dfcd7e6"
                                          zwave_device.node_id=38
                                          Capabilities: dimming, energy_sensor, power_sensor, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                                          Actions: dimming.down, dimming.set, dimming.up, power_switch.off, power_switch.on, power_switch.set, x_ezlo_device.device_check, x_ezlo_device.set_item_value, x_ezlo_device.set_name, x_ezlo_device.set_room, x_ezlo_device.status_check, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.reset_meters, zwave_device.set_config, zwave_device.update_neighbors
                                          or this other one, dimmer level diverge from msr to ezlo
                                          K Bulb Domitech
                                          ezlo>device_61423589129e29124dfcd756
                                          2:30:41 AM
                                          dimming.level=0
                                          dimming.step=0.1
                                          dimming.undefined=0.25
                                          power_switch.state=false
                                          power_switch.undefined=true
                                          x_ezlo_device.manufacturer="Domitech"
                                          x_ezlo_device.model="ZE27EU"
                                          x_ezlo_device.room="613e2020129e2912114c093a"
                                          x_ezlo_device.subcategory="dimmable_bulb"
                                          x_ezlo_device.type_id="526_19522_12596"
                                          x_ezlo_item.dimmer=25
                                          x_ezlo_object.id="61423589129e29124dfcd756"
                                          zwave_device.manufacturer_info=["Domitech","ZE27EU",null]
                                          zwave_device.node_id=26
                                          Capabilities: dimming, power_switch, x_ezlo_device, x_ezlo_item, x_ezlo_object, zwave_device
                                          -ZWaveJS-UI 11.22.3
                                          -Update 16/08/2026
                                            146.9k
