  4. MQTTController map different values from same topic?
Scheduled Pinned Locked Moved Unsolved Multi-System Reactor
5 Posts 3 Posters 1.4k Views 3 Watching
    I have multiple sensors connected to via Bluetooth to a Tasmota device.
    All sensors report their values in the SENSOR topic, how do I map those to individual entities?
      This would be done the same way as mapping any other topic to an entity. I'm... not sure what the question is.
        ArcherS
        @Crille I do not use the MSR (yet! 🙂 ), but I do have a Tasmota device reporting three Xiaomi Mi BLE devices to OpenLuup over Mqtt.
        They report the following:
        {"Time":"2021-11-24T16:00:25","ATC-6d5d44":{"Temperature":20.6,"Humidity":48.0,"DewPoint":9.2,"Battery":76,"RSSI":-89},"ATC-9446bf":{"Temperature":19.6,"Humidity":52.0,"DewPoint":9.5,"Battery":42,"RSSI":-84},"ATC-f159bf":{"Temperature":19.6,"Humidity":55.0,"DewPoint":10.3,"Battery":45,"RSSI":-84},"TempUnit":"C"}
        on the following topic:
        tele/TasmotaBLE/SENSOR
        The message contains all three devices each under their name.
        Not sure how about the syntax in MSR but in e.g. Home Assistant you write something in this direction in the config.yaml to retrieve the temperature for one device.
          - platform: mqtt
            state_topic: "tele/TasmotaCO2Ax/SENSOR"
            value_template: "{{value_json['ATC-6d5d44'].Temperature}}"
            device_class: temperature
            unit_of_measurement: "°C"
          There are templates documented for Tasmota devices reporting temperature, humidity, and battery. Any of them can be used as a model for dewpoint if that's needed. You set source in the entity configuration to pick which sensor (e.g. source: ATC-6d5d44 or source: ATC-9446bf), like this:
                  temp_sensor_1:
                     name: "Tasmota XXXX sensor 1"
                     topic: "tasmota_FFFFFF"
                     uses_template: tasmota_temperature_humidity
                     source: ATC-9d5d44
                  temp_sensor_2:
                     name: "Tasmota XXXX sensor 2"
                     source: ATC-9446bf
          etc...
            The issue is that the sensors do not report at the same time, one publish contains one or two devices and when source id is not found it's setting null values.
            Lets say I use source LYWSD03aa6def
            17:19:25.359 MQT: tele/Växthuset/SENSOR = {"Time":"2021-11-24T17:19:25","LYWSD03aa6def":{"mac":"a4c138aa6def","Temperature":7.0,"Humidity":98.0,"DewPoint":6.7,"Battery":24,"RSSI":-71},"Flora6cabfa":{"mac":"c47c8d6cabfa","Temperature":7.8,"Illuminance":265,"Moisture":20,"Fertility":85,"RSSI":-86}}
            17:19:26.372 MQT: tele/Växthuset/SENSOR = {"Time":"2021-11-24T17:19:26","Flora6cab88":{"mac":"c47c8d6cab88","Temperature":8.6,"Illuminance":167,"Moisture":0,"Fertility":0,"RSSI":-81}}
            17:19:37.399 MQT: tele/Växthuset/SENSOR = {"Time":"2021-11-24T17:19:37","Switch1":"ON","Switch2":"ON","ENERGY":{"TotalStartTime":"2021-05-04T07:45:50","Total":0.000,"Yesterday":0.000,"Today":0.000,"Period":[ 0, 0],"Power":[ 0, 0],"ApparentPower":[ 0, 0],"ReactivePower":[ 0, 0],"Factor":[0.00,0.00],"Frequency": 0,"Voltage": 0,"Current":[0.000,0.000]},"ESP32":{"Temperature":40.0},"TempUnit":"C"}
            It maps the temperature and humidity on the first tele but applies null on the next ones.
            Also, what to put in init?
              148.3k
