  4. Rule for devices battery level ?
43 Posts 6 Posters 16.1k Views 7 Watching
    Perfect! Thank you. I think I see what's going on. New build coming later today...
    @toggledbits thanks Patrick! Works nicely
      How do I change my rule for devices with low batteries to use a dynamic array instead of the static manual array I am using currently ?
      battery_device_list:
      IanI 1 Reply Last reply
        IanI Offline
        IanI Offline
        Ian
        @cw-kid
        The first expression produces an array that includes all battery powered entities across all controllers.
        The second restricts the results to a specific controller.
          Ian thank you. I thought it would be the battery_power capability, but I didn't know how to write that in an expression. I will try it now.
            #36
            I think this may work then, I just need to edit my existing rule:
            matchEntities ({controller: 'vera', capability: ['battery_power']})
            EDITED rule:
              EDITED rule:
              @cw-kid You could also do all that in one expression if you prefer and are not using the other ones for anything else.
              join(
                each id in matchEntities( { controller: 'vera', capability: 'battery_power' } ): do
                  device=getEntity( id ),
                  device.attributes.battery_power.level > 0.1 ? null : device.name + " at " + device.attributes.battery_power.level * 100 + " percent"
                done, ", " )
                join(
                  done, ", " )
                @crille
                Great thank you, I will consider that.
                  #39
                  Just a point here: why limit matchEntities() to one controller? Would you not perhaps want an alert for a device on any controller that has a low battery level?
                  Also, don't forget about the format() function, which is meant for things like this...
                      device.attributes.battery_power.level > 0.1 ? null : format( "{} at {:.1%}", device.name, device.attributes.battery_power.level )
                  Oh, and in my home, any battery-operated device would be long dead if it was reporting 10% (0.1). Most of mine seem to start to malfunction below 50%.
                    @toggledbits I'm trying to understand the pros and cons of using this vs the new DynamicGroupController, could you give a short summation?
                    wmarcolinW 1 Reply Last reply
                      Hi @crille !
                      In this post we are having this discussion about Dynamic, I am having a hard time getting it to work, but it will be very good, the concept is great and this will make it much easier.
                      https://smarthome.community/topic/793/multidimensional-array/17?_=1638031443562&loggedin=true
                      • wmarcolinW wmarcolin
                        Hi @crille !
                        @wmarcolin Yes, but the goal seems to be the same so what's the pros of doing it in the DynamicGroupController? More efficient, more dynamic, less complex etc, than a global expression like the one above?
                        I'm all up for new improved ways of doing things just need an explanation of why 🙂
                          @crille
                          In my opinion, everything you put in: more efficient, more dynamic, less complex. Below is a screenshot of how I do it today, and it would be replaced only by the format expression already directly inside a message as per telegram.
                          I will also use it to easily know all the devices that will be tripped in the house, see the other post for what I am adding after the battery. Besides this, unifying devices that for example are triggered by a contact or movement and have different expressions, will help unify and set up the alarm trigger management.
                            149.8k
