  4. [Solved] suninfo.sun_angle usage: showing -218.7 mid-day
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
12 Posts 3 Posters 1.1k Views 4 Watching
    I just stumbled across this last evening in the manual and it piqued my interest in possibly using this to trigger from/by:
    "Sun Information" entity (capability suninfo, canonical ID reactor_system>sun) with data about today's sunrise/sunset, day length (in hours), solar noon (transit) time, and current sun angle (-90 at sunrise, 0 at solar noon, 90 at sunset).
    I immediately added the entity to a dummy/test ruleset last night and see that the value currently shown for suninfo.sun_angle hasn't budged from "-218.7", even though it's now mid-day (expectation being something between "-90" and "90" being the current value.
    I read and reread the manual and don't see where there's any config required for this entity - am I missing something? Has anyone else made use of this?
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
      @gwp1 I've tried it just right not out of curiosity and it's showing -228.3 for me (and it's 20:15 here in Italy, so it should have been 90).
        Can you both report the results of http://your-reactor-host-ip:8111/diag/sun please? VIA PM TO ME
          Based on what @gwp1 sent, it looks correct, but like it's not updating (stale data). I'm going with that for now. Fixed for next build.
            This did it, @toggledbits - thanks very much for the prompt turnaround! This will lead to some interesting blinds automation, methinks....
            Core 2026.1.1
              It’s fixed for me as well.
                Seems odd but this stopped refreshing stopped matching my location last night at 22:49 ET. The difference, however, this time is that the results of the URL are what's not refreshing. @toggledbits I've sent you the results of the URL from this morning.
                Currently it is updating but the sun angle doesn't match the location of the MSR host location setting. All other data seems to match. Lat/Long, date/time, etc.
                Core 2026.1.1
                  @gwp1 I'm going to respond to your second PM here, because I think it's useful public info...
                  The only thing that would change in the sun data on multiple requests is the sun angle, and that is changed in your two (DM) examples. The timing of astro events and the length of the day remain the same all day (i.e. sunset happens at the same time on 12/11 whether you ask at 9am or 3pm), so don't expect any change from those parts. And this is a feature; it's a Very Good Thing that these computed times are stable.
                  The sun angle, having single-decimal-digit resolution as presented, would for this time of year at your location not be expected to change more than once every 20 seconds. That is, the sun traverses an arc of 180 degrees in about 10 hours (again, at your location), or 36000 seconds, so a degree every 200 seconds, or 1/10th of a degree every 20 seconds. It may be a little more, allowing for round-off and precision limits.
                    @toggledbits Totally understand.
                    And I'm an idiot who apparently cannot do maths this morning.
                    The expectation per the docs is -90 = sunrise, 0 = solar noon, 90 = sunset. The sun_angle is showing as a negative number currently, WHICH IT SHOULD BECAUSE IT'S NOT NOON YET. <smh>
                    Sincere apologies for wasting your time. I just installed smart blinds last evening and am very anxious to see if sun_angle will be a solid means by which to angle the blinds as the sun shifts across the back of the house - kinda let my excitement/curiosity run away with me.
                    Core 2026.1.1
                      All good. I anticipated this kind of application, and it makes me realize that you probably would want azimuth as well, because the effect of the sun on your windows is a function not only of its height relative to the horizon, but its angle left-right relative to the plane of your windows. That may be a bit more than you are thinking, but I think eventually you'd come to that conclusion, because the sun does change its position in the sky laterally as well as in elevation (the former is just more gradual over the course of months, while the latter is a daily traversal). So, azimuth coming next... 🙂
                        @toggledbits Spot on, that's exactly what happens here with dramatic impact, esp on my home office. Sadly, the blinds in there are too small to automate at this time (by a mere 1 1/2", too.) The back of the house, however - totally fair game for automation.
                        Core 2026.1.1
                          OK. In playing with this a bit more, I'm going to make suninfo.sun_angle go away (eventually; after a deprecation period), and it's replacement will be a soon-to-come suninfo.elevation. The elevation is the true angle of the sun above the horizon. Unless you live on the equator, the sun is not really at 0 degrees at solar noon, as sun_angle indicates. For example, right now for me in the Atlanta area at this time, solar noon gives me an elevation of just 33.5 degrees (summer solstice about 80 degrees). I think the true elevation will be a better metric for solar energy calculations, and in combination with azimuth, you should easily be able to compute ray angles/exposure to solar panels and good things like that.
                          The other things I'm fixing is that our friends in Prudhoe Bay and Tromsø are getting incorrect day lengths, etc., right now because the sun never rises at this time of year. The sunrise/sunset times are null as expected, but the day length is 24 when, IMO, it should be zero, and the sun_angle is null which is again not as useful as having a real elevation.
                            3.5k
                            3.1k
                            446
                          • Self test
