  4. [SOLVED] Release 21360 refuses connections after deployment
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
Reset a delay
Reactor Loading Screen Safari
19 Posts 4 Posters 1.4k Views 4 Watching
    ERR_CONNECTION_REFUSED after updating to reactor-latest-21360-5e68cde.tar.gz when attempting to connect to the UI via browser. SSH still works so I downgraded back a version and all good.
    Just to rule out anything weird I redeployed and same end result. Back running on the prior version noted in signature. Odd.
    Anyone else have this happen over the last 17 hours?
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
    • wmarcolinW Offline
      Yes same problem, I have already opened Mantis 285 reporting the error in the override, or in a new installation. I went back to 21353.
        Same here. I think @toggledbits is already informed.
          Connection to the UI can be delayed by a slow-starting (or faulting) controller connection. That times out in 60 seconds. So it would be useful to wait a minute or two and then see if you can connect to the UI.
          Either way... logs. Where are the logs? Did anybody look at the logs?
            OK. I have logs from @therealdb that got me what I need, stay tuned...
              @toggledbits In all fairness I did glance thru them but nothing leapt out at me, primarily because I failed to timestamp when I did my deployments. Thanks @therealdb for providing the needful!
              Core 2026.1.1
                @gwp1 I'm going to add a startup troubleshooting section to the docs, but one of the other places you can look for messages is in your system's log file in /var/log. systemd will log things there as it tries to start the daemon. Synology docker users (and I imagine other NAS platforms have similar) can go into the "Details" for the container and find a Logs tab that has similar information (and command line users may find info in docker logs <container-name>).
                Anyway, I've got it, rolling the respin now...
                  OK. 21360 has been respun. Please download new archives or containers as appropriate to your environment and try again.
                    @toggledbits Confirmed issue is resolved. Thank you, sir!
                    Core 2026.1.1
                      @gwp1 said in [SOLVED] Release 21360 refuses connections after deployment:
                      Thank you, sir!
                      For breaking your system? Oh my... <embarrassed>
                      wmarcolinW 1 Reply Last reply
                        Can you all tell me what versions of nodejs you have running?
                          @toggledbits v14.15.4
                          Core 2026.1.1
                            Thank you, sir!
                            @toggledbits hi!
                            In parts 🙂
                            1. NODE v17.0.1 and NPM 8.1.2;
                            2. New installation, follows with error I believe because of the lack of the directories that I informed in the ticket (Mantis 285) and you can see the error in the screen below;
                            1. Installation 21360 overwriting version 21353, working and I see that the Dynamic Groups theme works, sys_group.members information already loaded.
                            You mention above that in the case of Synology docker there would be another place to look for a problem log. For Windows v10 Bare Metal, is there the same facility? Could you inform it to make it easier to track?
                              Looks like you missed step 2 of the install process for Windows service. See the docs.
                                Please excuse me, you are absolutely right, it went unobserved, sorry.
                                One suggestion, in the same way that in all other commands (like step 3) you put the action with a stripe and the copy icon which makes it much easier, could you do this for step 2 in the document?
                                  Yes, that would lay out much better, I agree. It will be so.
                                    @toggledbits hi!
                                    A configuration doubt from the manual, in this setting:
                                    set NODE_PATH=C:\Users\Example\Documents\Reactor
                                    Isn't it supposed to indicate the directory where the node library is located?
                                    set NODE_PATH=C:\Users\Example\Documents\Reactor%(#ff0000)[\node_modules]
                                    • wmarcolinW wmarcolin
                                      @toggledbits hi!
                                      @wmarcolin said in [SOLVED] Release 21360 refuses connections after deployment:
                                      No, and doing so will make some components of Reactor not work.
                                        @toggledbits ok, thanks!
                                        • Possible feature request 2?
                                          82.1k
                                        • Copying a global reaction
