  4. [Solved]Global Expression with null value and Auto-Evaluation
Time series documentation
Reset a delay
Reactor Loading Screen Safari
I'm having an issue with MSR's UI being very unresponsive. It started happening a couple days ago and I didn't make any changes that would have caused this except adding some meross lan devices in HA. When I go into an entity action and use the search functionality, it usually will start filtering and then get to a place after a few letters are entered where it will take 30 seconds or more (sometimes minutes) for the UI to show what I am typing. During this time MSR ui is completely unresponsive. I've tried multiple browsers and multiple computers. HA and MSR are both deployed in docker. I have run HTOP on the host and when the problem happens there are no CPU/Memory spikes at all. From a functionality standpoint MSR is working perfectly. This seems to be an UI issue only. Do i need to ditch Docker and run MSR on a Proxmox VM? I have both stand alone Docker and Proxmox environments. I dont mind doing that I just want to be able to use the UI again... Installation method Home Assistant Container Core 2025.7.3 Frontend 20250702.3 nothing crazy in the logs except some openweather map stuff that doesn't make any sense as it is working fine in MSR Any help would be greatly appreciated Reactor latest-25328-b2ed1365 app 25328 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.843Z <app:null> Reactor build latest-25328-b2ed1365 starting on v24.11.1 /usr/local/bin/node [latest-25328]2025-11-30T20:01:53.844Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #161-Ubuntu SMP Tue Jul 22 14:25:40 UTC 2025; locale (undefined) [latest-25328]2025-11-30T20:01:53.844Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-25328]2025-11-30T20:01:53.844Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-25328]2025-11-30T20:01:53.865Z <app:null> Resolved timezone=America/New_York, environment TZ=America/New_York; offset minutes from UTC=-300 [latest-25328]2025-11-30T20:01:53.867Z <default:null> Module i18n v25141 [latest-25328]2025-11-30T20:01:53.867Z <app:null> Configured locale (undefined); selected locale(s) en-US.UTF-8 [latest-25328]2025-11-30T20:01:53.879Z <app:null> Loaded locale en-US for en-US [latest-25328]2025-11-30T20:01:53.879Z <app:null> Local date/time using configured timezone and locale formatting is "11/30/2025, 3:01:53 PM" [latest-25328]2025-11-30T20:01:53.889Z <Structure:null> Module Structure v25326 [latest-25328]2025-11-30T20:01:53.890Z <Capabilities:null> Module Capabilities v24312 [latest-25328]2025-11-30T20:01:53.904Z <Plugin:null> Module Plugin v25141 [latest-25328]2025-11-30T20:01:53.923Z <Timer:null> Module Timer v25279 [latest-25328]2025-11-30T20:01:53.924Z <TimerBroker:null> Module TimerBroker v25314 [latest-25328]2025-11-30T20:01:53.927Z <Entity:null> Module Entity v25251 [latest-25328]2025-11-30T20:01:53.929Z <Controller:null> Module Controller v25253 [latest-25328]2025-11-30T20:01:53.930Z <AlertManager:null> Module AlertManager v25318 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Ruleset v25283 [latest-25328]2025-11-30T20:01:53.937Z <default:null> Module Rulesets v25141 [latest-25328]2025-11-30T20:01:53.942Z <GlobalExpression:null> Module GlobalExpression v25258 [latest-25328]2025-11-30T20:01:53.953Z <Predicate:null> Module Predicate v25328 [latest-25328]2025-11-30T20:01:53.956Z <Rule:null> Module Rule v25323 [latest-25328]2025-11-30T20:01:53.958Z <GlobalReaction:null> Module GlobalReaction v25292 [latest-25328]2025-11-30T20:01:53.959Z <Engine:null> Module Engine v25325 [latest-25328]2025-11-30T20:01:53.964Z <httpapi:null> Module httpapi v25328 [latest-25328]2025-11-30T20:01:53.972Z <wsapi:null> Module wsapi v25328 [latest-25328]2025-11-30T20:01:53.994Z <TaskQueue:null> Module TaskQueue 24138 [latest-25328]2025-11-30T20:01:53.994Z <VeraController:null> Module VeraController v25141 [latest-25328]2025-11-30T20:01:54.179Z <HassController:null> Module HassController v25325 [latest-25328]2025-11-30T20:02:13.797Z <OWMWeatherController:null> Module OWMWeatherController v25268 [latest-25328]2025-11-30T20:02:13.800Z <SystemController:null> Module SystemController v25323 [latest-25328]2025-11-30T20:02:13.807Z <MQTTController:null> Module MQTTController v22092 [latest-25328]2025-11-30T20:02:20.630Z <OWMWeatherController:CRIT> FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxx&lon=-xxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxxxxxxxxx&units=standard&_r=1xxxxxxxxxxxxxxfailed, reason: [-] FetchError: request to https://api.openweathermap.org/data/2.5/weather?lat=xxxxxxxxxxx&lon=-xxxxxxxxxxxxxxxxxx&appid=xxxxxxxxxxxxxxxxxxx&units=standard&_r=xxxxxxxxxxxxxxxfailed, reason: at ClientRequest.<anonymous> (/opt/reactor/node_modules/node-fetch/lib/index.js:1501:11) at ClientRequest.emit (node:events:508:28) at ClientRequest.emit (node:domain:489:12) at emitErrorEvent (node:_http_client:108:11) at TLSSocket.socketErrorListener (node:_http_client:575:5) at TLSSocket.emit (node:events:508:28) at TLSSocket.emit (node:domain:489:12) at emitErrorNT (node:internal/streams/destroy:170:8) at emitErrorCloseNT (node:internal/streams/destroy:129:3) at processTicksAndRejections (node:internal/process/task_queues:89:21
Date/time condition
Device log?
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
16 Posts 4 Posters 1.8k Views 4 Watching
  • V Offline
    V Offline
    Hi, I am not a software developper so I apologise in advance...
    MSR 20002 Docker on Raspberry PI 4
    I am using MSR and global expressions to control my house humidifier. To calculate the target humidity level, the outside temperature is used within a simple formula.
    From time to time and for short period, the outside temperature, coming from a Hass sensor is showing a value "null" which is screwing up my target level. Ideally, I would like to retain the current value when the OutsideTemp is not available (i.e. null)
    Here are my global expressions to perform this:
    OutsideTemp: Simply get the outside temperature (that is the one showing "null" from time to time.
    CurrentHumid: Current house humidity
    CalculatedHumid: This is where the target humidity is calculated. (Used to be 45 + round(OutsideTemp)
    LowHumidity: This is the flag that tell the humidifier to start working.
    CalculatedHumid and LowHumid are use in a rule to update sensor in HASS.
    In addiditon LowHumidity is used in 2 rules to turn the Humidifier on and off.
    At first, I was crashing MSR because CalculatedHumid was auto evaluating constantly. After a couple of attempt I disabled "Auto-Evaluation". From what I can tell, all is working fine which is a bit surprising considering what the documentation says about disabling auto-evaluation.
    2 questions:
    1- Since auto-evaluation is disable, how come the CalculatedHumid is still evaluating when the temperature changes?
    2- Is there a better way to filter out a null value while retaining the previous valid value.
    Using MSR 25139 on Docker, on a Raspberry Pi with Bookworm. Home Assistant 2025.07, Z-Wave JS-UI 10.6.1
      If you just want it to keep the last value when the device is handing back null, you can use the order of operations to your advantage: the assignment to the variable is the last thing that happens in the evaluation, so if you change OutsideTemp like this:
          getEntity( 'hass>sensor_etc' )?.attributes?.temperature_sensor?.value ?? OutsideTemp
      This will do the entity fetch and member accesses (with extra guards), and if the result of that is null, it just returns the current value of OutsideTemp. So as long as the entity fetch clause returns null, the previous temperature value will be saved as the current temperature value.
      Edit: Added an additional guard to the above expression (immediately after the getEntity()'s closing paren).
      • V Offline
        V Offline
        This is a good day. I have learned something again.
        Many thanks for your support.
        • V Offline
          V Offline
          @toggledbits I might have celebrated a bit too soon on that one. After doing the change all seemed fine. Tested the null value and a temperature change and all was working as advertised. After a certain time I am getting an error and the container crashes and cannot be re-started. By looking at the container log, I can see some issues with the file sys_alerts.json. Indeed the file is still in the storage folder but has a size of 0 byte and is complety empty. I replaced the empty file by the original one (I keept a copy of all files of the reactor folder after the original install) and was able to restart the container but it eventually crashed again. I changed the OutsideTemp expression back to what is was and I am back to normal. I am in the process of collecting log info and whatever might be relevant to investigate. It does seemed similar to my original problem where the expression is self trigering and get caught in a loop. I will be in and out this week so it may take some time before I get back to you. In the interim here is a screen capture of the error:
          wmarcolinW toggledbitsT 2 Replies Last reply
            it's a classic situation of stack overflow. you'd probably just set a value (like "unavailable") on startup and a constraint on the rule. That's what I'm doing anyway for a couple of things that send spurious values from time to time.
            • V vezinpi
              @vezinpi
              In the engine group config (reacotr.yaml), add this parameter:
              update_rate_limit: 300
              This solved my problem and did not harm the system at all.
                Can you post all the expressions as you have them now? That's a pretty unusual error message. There's a distinction between evaluation and compilation, and I'm very meticulous about making sure the message reports the right one. The alert shows that the compilation is the problem, which suggests the expression isn't written properly somehow. I need to see what you've got.
                • wmarcolinW wmarcolin
                  @vezinpi
                  @wmarcolin update_rate_limit has no effect on global variable evaluation, FYI. That's a control/config for rule evaluations. Global variables have no equivalent config value, it's really not needed. I think there's (a) a problem with the expression that's causing a compilation error, and (b) a problem handling the compilation error that's causing the loop/stack overflow. Once (b) is fixed we'll be back to "no rate limiting needed here" status.
                  wmarcolinW 1 Reply Last reply
                    @toggledbits ok, understood!
                    • V Offline
                      V Offline
                      Here it is, as requested. Getting the logs, standby...
                      • V Offline
                        V Offline
                        MSR Logs. It is quite long with the middle repeating OutsideTemp so I copied the start and the end. After that it repeats. I did preserved the logs so if you want more let me know.
                        This is how (I think) it started
                        GlobalExpression#CurrentHumid
                        [latest-22002]2022-01-04T17:33:01.558Z Rule:5:813:Rule.js Rule#rule-grpqosf66u Humidifier On requesting eval; expression-state-changed from GlobalExpression#CurrentHumid
                        [latest-22002]2022-01-04T17:33:01.559Z Rule:5:813:Rule.js Rule#rule-grpqoyiumi Humidifier Off requesting eval; expression-state-changed from GlobalExpression#CurrentHumid
                        [latest-22002]2022-01-04T17:33:01.560Z Rule:5:813:Rule.js Rule#rule-kwz0myt1 Low Humidity To Hass requesting eval; data-changed from Data#states:expr-global-CurrentHumid
                        [latest-22002]2022-01-04T17:33:01.561Z Rule:5:1009:Rule.js Rule#rule-kwz0myt1 evaluation in progress; waiting for completion
                        [latest-22002]2022-01-04T17:33:01.562Z Rule:5:813:Rule.js Rule#rule-grpqosf66u Humidifier On requesting eval; data-changed from Data#states:expr-global-CurrentHumid
                        [latest-22002]2022-01-04T17:33:01.563Z Rule:5:1009:Rule.js Rule#rule-grpqosf66u evaluation in progress; waiting for completion
                        [latest-22002]2022-01-04T17:33:01.564Z Rule:5:813:Rule.js Rule#rule-grpqoyiumi Humidifier Off requesting eval; data-changed from Data#states:expr-global-CurrentHumid
                        [latest-22002]2022-01-04T17:33:01.565Z Rule:5:1009:Rule.js Rule#rule-grpqoyiumi evaluation in progress; waiting for completion
                        [latest-22002]2022-01-04T17:33:01.566Z Engine:5:984:Engine.js [Engine]Engine#1 var CurrentHumid changed, evaluating dependent child LowHumidity
                        [latest-22002]2022-01-04T17:33:02.407Z Engine:ERR [Engine]Engine#1: error evaluating expression OutsideTemp: [RangeError]RangeError: Maximum call stack size exceeded
                        [latest-22002]2022-01-04T17:33:02.411Z Engine:ERR [Engine]Engine#1: expression: getEntity( "hass>sensor_ottawa_kanata_orleans_temperature" ).attributes?.temperature_sensor?.value ?? OutsideTemp
                        [latest-22002]2022-01-04T17:33:02.411Z Engine:ERR [Engine]Engine#1: path LowHumidity->CalculatedHumid->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp->OutsideTemp
                        And this is how it ended
                        [latest-22002]2022-01-04T17:33:02.415Z Engine:CRIT RangeError: Maximum call stack size exceeded
                        at /opt/reactor/server/lib/Logger.js:434:21
                        at Logger._emit_streams (/opt/reactor/server/lib/Logger.js:428:57)
                        at Logger._emit_streams (/opt/reactor/server/lib/Logger.js:436:71)
                        at Logger._emit (/opt/reactor/server/lib/Logger.js:423:35)
                        at Logger.err (/opt/reactor/server/lib/Logger.js:452:31)
                        at Engine._eval_expr (/opt/reactor/server/lib/Engine.js:954:57)
                        at Engine._expr_resolve (/opt/reactor/server/lib/Engine.js:1217:38)
                        at _resolve (/opt/reactor/common/lexp.js:1217:35)
                        [latest-22002]2022-01-04T17:33:02.416Z Engine:ERR [Engine]Engine#1: error evaluating expression OutsideTemp: [RangeError]RangeError: Maximum call stack size exceeded
                        [latest-22002]2022-01-04T17:33:02.416Z Engine:ERR [Engine]Engine#1: expression: getEntity( "hass>sensor_ottawa_kanata_orleans_temperature" ).attributes?.temperature_sensor?.value ?? OutsideTemp
                          OK. I'm busy this afternoon, but will look at it later today.
                            OK. I think I have this nailed down. Sorry it took me so long, I was working on an edge case to make sure the system stays in control under the worst of conditions. Is essence, as I suspected, the first issue is that the dependency loop check had an error and wasn't always working. In addition, I've added additional checks for more cases where a loop may evade the first check. Also, the system should remain in control if a loop does sneak by the checks, rather than hanging.
                            Build will be published shortly...
                            V 1 Reply Last reply
                            • V vezinpi
                              @vezinpi I've added one additional guard to the expression in the post linked below. You should make that edit as well during your upgrade.
                              https://smarthome.community/post/11053
                                V Offline
                                V Offline
                                @toggledbits said in Global Expression with null value and Auto-Evaluation:
                                You have nothing to be sorry about. Being aware of a potential issue, evaluating the problem, developping a solution and posting a new version in the same day, is really remarquable and almost unheard of now a day.
                                Thanks you for your dedication.
                                • V Offline
                                  V Offline
                                  Installed the new version yesterday along with the new guard and all is still fine this morning. Considering that it was failing very quickly before, I consider that issue fixed.
                                  • Time series documentation
                                  • Tuya Wifi to Tasmota flashing
                                  • Reset a delay
                                  • Single protocol?
                                  • HDMI oddness
                                  • Oh the joy of pairing
