  4. Vera plugin devices just appear in MSR?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
6 Posts 5 Posters 923 Views 5 Watching
    We have a newish dev on the Vera forum making a few new plugins, which is good to see as we have hardly any 3rd party devs left any more.
    He's created a nice little plugin here, that pulls down your current WAN IP in to a plugin device in the Vera UI7 gui.
    I was under the impression that Vera plugin device support had to be explicitly added by the MSR dev ?
    However it seems that this particular plugin has just bounced in to my Vera Edge Entities list after a Reboot of MSR and is showing this output, so appears to be just working.
    x_vera_device.configured=false
    x_vera_device.device_number=162
    x_vera_device.device_type="urn:nodecentral-net:device:ExternalIP:1"
    x_vera_device.failed=null
    x_vera_device.mapped_by="*"
    x_vera_device.mapped_class="generic_device"
    x_vera_device.parent_device=0
    x_vera_device.room_id="0"
    x_vera_svc_micasaverde_com_HaDevice1.Configured="0"
    x_vera_svc_nodecentral_net_ExternalIP1.Current External IP="xx.xx.xx.xx"
    x_vera_svc_nodecentral_net_ExternalIP1.Icon="0"
    x_vera_svc_nodecentral_net_ExternalIP1.Last Changed="1641612887"
    x_vera_svc_nodecentral_net_ExternalIP1.Last Changed HR="1641612887"
    x_vera_svc_nodecentral_net_ExternalIP1.Last Checked="1641612887"
    x_vera_svc_nodecentral_net_ExternalIP1.Last Checked HR="1641612887"
    x_vera_svc_nodecentral_net_ExternalIP1.PluginStatus="Plugin variables being set up 2/2"
    x_vera_svc_nodecentral_net_ExternalIP1.PluginVersion="0.2"
    x_vera_svc_nodecentral_net_ExternalIP1.Previous External IP="0.0.0.0"
    Capabilities: x_vera_device, x_vera_svc_micasaverde_com_HaDevice1, x_vera_svc_nodecentral_net_ExternalIP1
    Actions: x_vera_device.set_variable, x_vera_svc_micasaverde_com_HaDevice1.AllowPairing, x_vera_svc_micasaverde_com_HaDevice1.Poll, x_vera_svc_micasaverde_com_HaDevice1.Reconfigure, x_vera_svc_micasaverde_com_HaDevice1.Remove, x_vera_svc_micasaverde_com_HaDevice1.SetPollFrequency, x_vera_svc_micasaverde_com_HaDevice1.StressTest, x_vera_svc_micasaverde_com_HaDevice1.ToggleState, x_vera_svc_nodecentral_net_ExternalIP1.refreshExternalIP
    parkercP G 2 Replies Last reply
      parkercP Offline
      parkercP Offline
      parkerc
      @cw-kid said in Vera plugin devices just appear in MSR?:
      That makes me feel young 🙂
        @cw-kid It's been my experience that anything I add on Vera would follow the integration path at the next reboot of MSR ( I could be mistaken, my Vera was taken completely offline a couple months ago ).
        *Hubitat C-7 2.5.0.126
        Core 2026.4.4
        MSR: latest-26120-d2e50474
          every variable on you Vera is available in MSR. I have custom one I'm using to save intermediate status, and it's working very well since day 1. they're pushed to MQTT as well.
            @gwp1 said in Vera plugin devices just appear in MSR?:
            This is correct. All plugins in Luup are represented by at least one device. Any such device will make an appearance when Reactor next restarts (currently).
            What may or may not require further integration depends entirely on the nature of the plugin and the device it creates. Plugins like AutoVirtualThermostat and Switchboard use standard devices, so they are known types that are already mapping into Reactor's standard capabilities and typically don't require any additional work to be basically functional.
            Plugins that implement only new services and behaviors not known to standard Luup devices may require some additional work, usually done only in data files, to describe those capabilities of the plugin and map them into standard Reactor capabilities. Reactor recognizes, for example, the Harmony plugin, and can provide special capabilities, attributes, and actions for that plugin's master device when present.
            VeraController also knows how to publish all of the state variables on a device as extended attributes, and it can ask Luup what a device's available actions are and provide extended actions, without any additional intelligence in either code or data from Reactor. So even without standard device use, and without special data mapping, pretty much any plugin or device will have its states and actions accessible in Reactor.
            So, no, it is not the case that every plugin has to be specifically integrated.
              OK thanks guys for the information appreciate it.
                99.4k
              • Next Release?
