  4. MQTT interface... time for some testing. Where are my experts?
55 Posts 6 Posters 25.1k Views 6 Watching
  • X Offline
    X Offline
    xAPPO
    Thankyou - that's worked. I had assumed the appropriate version of node was part of the Docker container.
    So pleased to have found this as I use HA, MQTT, Hubitat extensively plus OpenHAB and Homey to a lesser extent so glad you are intending to support those two eventually.
      It is part of the container, but you are not running in the container. That is a possibility, though, and I tried it, it seems to work, so an alternative to installing (or upgrading) nodejs outside of the container seems to be:
      docker exec -it reactor /bin/sh
      cd /var/reactor/ext/MQTTController
      ./install.sh
      exit
      I'll add this to the installation docs for MQTTController.
      X 1 Reply Last reply
        ./install.sh
        exit
        X Offline
        X Offline
        xAPPO
        wrote on last edited by xAPPO
        #29
        All working well. However in the topic structure for echoed devices (from Hubitat anyway) the <entity-id> is used. Is it possible to instead or even better as well as, include the entity-name ?
        reactor/<mqtt-id>/<ctrl-id>/<entity-id>/state/<capability-name>
        perhaps
        reactor/<mqtt-id>/<ctrl-id>/<entity-name>/<entity-id>/state/<capability-name>
          The entity name can be changed or duplicated and is not an appropriate unique identifier for a device.
          • X Offline
            X Offline
            xAPPO
            Topic hierarchy segments don't have to be unique - in fact I would say most aren't. Keeping the <entity-id> then within the hierarchy would ensure the topic remains unique. Having no easily human identifiable topic is not helpful to other integrations.
            • X xAPPO
              @xappo OK. And what about receiving messages for inbound action requests? Same entity-name/entity-id construction? If you know the correct entity ID to form that message, what value is the name? If you don't know the ID and only use the name, how do you specify that, and what if the name isn't unique then? And what if the name and ID conflict, or an entity can be found for one but not the other (i.e. they don't match)? I'm not opposed to what you're proposing, but I want you to help me think through the consequences of it.
              @xappo said in MQTT interface... time for some testing. Where are my experts?:
              I think that's a bit of a reach. The whole MQTT environment is so unstructured and freeform, with so many inconsistencies between players, that things like unique IDs (or MAC addresses or other cryptic and "hard to read" identifiers) are a regular occurrence, and anybody who uses MQTT a lot is used to it.
              • X Offline
                X Offline
                xAPPO
                #33
                The incoming action request message to a topic must be complete with all segments as you can't wildcard a publish command. So the <entity-id> will always be unique and present there. You could should you wish subscribe to the topic from your code ignoring any <entity-name> segment with a + wildcard as you don't process it. So that should work fine.
                Human readability.. I agree it's a bit of a reach but my whole system is MQTT based with over 10K topics and 1K+ devices - remembering what they all are and linking to or from those topics from other controllers requires some hints as to what those devices are. Later examination of logic requires understanding what devices are related. Having to refer back to Reactor config each time to identify a device isn't practical (or user friendly).
                  Good stuff. Let me see what I can cook up.
                    #35
                    OK. Version 22008 of MQTTController is up on the downloads site (under extras).
                    New configuration key that you can put in the echo section: set entity_identifier to combined and the telemetry topics will include the entity name; it adds another level to the topic as you suggested. This has no effect on received messages for entity actions; those still require the ID (but it's a secret/undocumented feature--you can give it the name instead of an ID and it will work if the name is unique), and the structure of the topic is the same (i.e. same number of levels, not changed). Online docs are updated as well.
                    • X Offline
                      X Offline
                      xAPPO
                      #36
                      This is working well - thank you for the prompt update.
                      For me having the <entity-name> before <entity-id> in the topic hierarchy would have been more informative as you can then see a list of names rather than numbers in expanded topics with say MQTT explorer rather than having to drill down in each one, but I totally understand why it is so much easier in terms of your existing implementation to position it afterwards and this is very workable too.
                      Thank you again.
                      Kevin
                        No worries. Version 22009 now. You can now set entity_identifier to id/name (as a synonym for combined) or name/id. I'll fix up the documentation later.
                        • X Offline
                          X Offline
                          xAPPO
                          It's like having my own on site developer team 🙂 Many thanks for that
                          • X Offline
                            X Offline
                            xAPPO
                            #39
                            I notice in the MQTT code you subscribe to the root level with a wildcard which means you receive every payload update. On my (untypical) broker this will produce 10’s of message per second. The good thing is Reactor seems to handle it but obviously it’s resource wasteful. Did you do this with a view to implementing discovery across the broker perhaps?
                            Currently it might seem better to just pull the necessary topics from the MQTTController section of reactor.yaml even though this may result in lots of individual subscribes?
                            Also just to mention I’ve got my first CBusController half written. It discovers and creates entities for all the 100+ lights I have on my Schneider C-Bus lighting but needs some refining. Learning as I go. Having the MQTT code as an example has been invaluable to me.
                            Would you be up to releasing the Hubitat and HomeAssistant controller code as examples? I think that would help people in authoring new controllers, as might a minimal code template that does nothing really.
                              When I started writing MQTTController I didn't quite know where it was going to end up or how it was going to get there. It moved a lot from its starting point. I can definitely "tune up" the subscriptions, but discovery is in the mix (it captures certain discovery messages to debug currently but doesn't do much else with them -- still under consideration).
                              Did you find the probably dated but maybe marginally helpful docs here? https://reactor.toggledbits.com/docs/Building-Controllers/
                              I've been really busy this week, and suffered a long Internet outage that just recovered a couple of hours ago, but when I'm caught up I'll quickly update some key points and concepts in there.
                              HubitatController and HassController are very complex pieces of machinery that I don't think would make good examples. Now that I have a few done, one of my tasks is go back and boil out some of the work into common methods or helper classes. I have a lot of work to do on the server API side.
                                X Offline
                                X Offline
                                xAPPO
                                @toggledbits said in MQTT interface... time for some testing. Where are my experts?:
                                Yes I did .. a quick Q - how do I delete an entity ?
                                The bit I'm adding currently is
                                If the process may be protracted and lengthy, the Promise should resolve earlier and the entities by published as discovered.
                                and trying to avoid having to loop through them all on restarts to see if they already exist. This is an aspect that you must have encountered with Hubitat and Hass.
                                Making good progress and enjoying it .. great application.
                                • X xAPPO
                                  controller.removeEntity( entity ) -- pass the entity, not just the ID.
                                  Define restarts in this context. If you mean restart of Reactor, no entities exist in the version you are running when Reactor starts up. That's about to change, though... entity persistence is coming. If you mean when the connection to the hub is re-established, that's entirely implementation-dependent for your Controller subclass. My subclasses generally reinventory everything, because you don't know how long the hub has been unavailable, and what may have happened to it while it was down.
                                  I just posted a ton of updates to the doc.
                                    RogerO
                                    I am trying to install this in Docker and getting the following error:
                                    $ docker exec -it reactorjs /bin/sh cd /home/pi/reactor/ext/MQTTController ./install.sh exit
                                    /bin/sh: can't open 'cd': No such file or directory
                                    Not enough of a linux gut to know what the issue is. Anyone have any hints?
                                    Roger
                                      #44
                                      You're reading the wrong direction, I think. See the docs.
                                      Edit 2: OK, getting in sync here again... you've given the wrong pathname to cd. Give it what the documentation says. You're working inside the container -- gotta follow its rules.
                                        RogerO
                                        This is the part I used from the instructions:
                                        "docker exec -it <container-name> /bin/sh cd /var/reactor/ext/MQTTController ./install.sh exit"
                                        Results:
                                        pi@RedBMWDeb:/home $ docker exec -it reactorjs /bin/sh cd /var/reactor/ext/MQTTController ./install.sh exit
                                        Then I tried to determine why the command wouldn't run and determined that maybe the path was wrong on my machine so ran the one in the previous message pointing to the path where MQTTController files were.
                                        pi@RedBMWDeb:~/reactor/ext/MQTTController $ ls
                                        0-README.txt COPYRIGHT MQTTController.js
                                        buildstamp install.sh mqtt_devices.yaml
                                        CHANGELOG.md mqtt_capabilities.yaml package.json
                                          It looks like you're trying to do all of those commands on one line. That's not right. You do them one at a time.
                                            159.8k
