  4. Trying to setup InfluxDB breaks my MSR install
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
15 Posts 2 Posters 1.6k Views 2 Watching
    I've just done a clean install of Bullseye OS on my Raspberry Pi and I am trying to setup MSR with InfluxDB.
    I have managed to get the old VeraFlux plugin working OK with the new InfluxDB installation on the Pi, so think I have the InfluxDB installation correct and working.
    However ideally I'd like to use MSR instead. I created a "reactor" database and created a username and password.
    In the reactor config file I added this at the end of it
    plugins:
    - id: influx
      name: InfluxDB 1.x Feed
      enabled: true
      implementation: InfluxFeed
        influx_url: http://192.168.0.36:8086
        influx_database: reactor
        influx_username: myuser
        influx_password: "mypassword"  # note use of quotes
    However when I restart MSR it doesn't come back up again. If I comment out all of that plugins section in the config file and restart the box, then MSR loads OK again. So I must be doing something wrong?
    Influx running on the Pi is version 1.8.10.
    MSR is running on a different Linux Debian box.
    Not sure how to update to InfluxDB 2.0, maybe I should do that?
    I looked in the log file and searched for "Influx" but nothing was found.
    • toggledbitsT Online
      toggledbitsT Online
      Check that you don't have tabs instead of spaces in your indenting. You can check /var/log/syslog for additional startup errors.
      Also did you run the install script?
      Edit: just noticed that config and all below are not correctly indented.
        Thanks, I think I fixed the indents now but its still the same MSR web page doesn't load. I will have a look in the syslog then.
          Did I run the install script? No I haven't.
          Is it a separate install now for the InfluxDB plugin? And how do you do it?
          The help page just says
          "At the moment, InfluxFeed is included in all Reactor distributions. In a future release, it will be a separately-installed component"
            MSR is starting now, I think my reactor.yaml config file was a bit out of date. I just copied the whole plugins section from the dist-config reactor.yaml file version and pasted it in to mine and then edited it. Now MSR is starting up again OK.
            I've just connected Grafana to the "reactor" DB source on InfluxDB OK. But as yet no measurements are appearing yet for some reason. I'm not sure if MSR is actually outputting data or how to check it, other than trying to do a query in Grafana.
            Only thing I wasn't sure about was this:
            influx_org - Organization ID (required)
            influx_org: "<your-influx-organization>"
              Maybe the plugin isn't actually installed then. I see this in the MSR log:
              [latest-22004]2022-01-19T17:07:24.636Z <app:ERR> Trapped unhandled Promise rejection: [Error]Error: Cannot find module '@influxdata/influxdb-client'
              Require stack:
              - /home/stuart/reactor/server/lib/InfluxFeed.js
              [latest-22004]2022-01-19T17:07:24.637Z <app:ERR> Please refer to the console log for trace
              [latest-22004]2022-01-19T17:07:24.762Z <app:ERR> Trapped unhandled Promise rejection: [Error]Error: Cannot find module '@influxdata/influxdb-client'
              Require stack:
              [latest-22004]2022-01-19T17:07:24.762Z <app:ERR> Please refer to the console log for trace
              [latest-22004]2022-01-19T17:07:24.818Z <app:ERR> Trapped unhandled Promise rejection: [Error]Error: Cannot find module '@influxdata/influxdb-client'
              Require stack:
              [latest-22004]2022-01-19T17:07:24.818Z <app:ERR> Please refer to the console log for trace
              [latest-22004]2022-01-19T17:07:24.865Z <app:ERR> Trapped unhandled Promise rejection: [Error]Error: Cannot find module '@influxdata/influxdb-client'
              Require stack:
              [latest-22004]2022-01-19T17:07:24.867Z <app:ERR> Please refer to the console log for trace
                toggledbitsT Online
                I meant the Reactor install script for RPi. Missing packages are usually a failure to complete the install. See the docs.
                  @toggledbits said in Trying to setup InfluxDB breaks my MSR install:
                  MSR isn't running on the Pi. Its running on a bare metal Linux Debian box, version is 22004-6d6c6b7.
                  InfluxDB is running on a Pi however.
                    toggledbitsT Online
                    OK, but the point is the same. The error message suggests that the install steps on the Debian side weren't done, and one step in particular, step 6. The dependencies for Reactor haven't been installed, or may be very out of date (there have been several releases where I've recommended running npm to update them).
                      Thank you, that was the bit I wasn't sure how to do.
                      It seems to be working now and populating stuff in Grafana from the "Reactor" DB.
                      Is that all the device capabilities available in that screen shot? For example could we add a Light Level Sensor (LUX) in to a graph ? I tired binary_sensor but could not see any LUX sensors under "name" or under "entity" and looking for the Vera device ID number I wanted.
                      I able to do that using the old VeraFlux plugin earlier. But I want to ditch that plugin now and just use MSR ideally.
                      Thank you.
                        Thank you.
                        toggledbitsT Online
                        toggledbitsT Online
                        @cw-kid said in Trying to setup InfluxDB breaks my MSR install:
                        The docs describe how to select capabilities for export. The section after also describes how to restrict which entities are exported, if that's an additional thing you may want to do.
                          OK sorry I will read the help doc again. I just assumed it would export everything to the database out of the box.
                            toggledbitsT Online
                            No worries. I just don't want to rehash, and if the docs end up not being adequate, I want to know that, too. The abbreviated default list of capabilities is to avoid the "sipping from a firehose" effect... as I think you've seen on the Recently Changed Entities list on the Status page, device changes are many and frequent, especially from Vera hubs (much of it caused by polling and the resultant updating of polling state/control variables that most people don't care about).
                              OK that works these values are coming from MSR now via Vera Plus hub
                              I added this in to the reactor.yaml file
                                    select_capabilities:
                                      light_sensor: true
                              I will have a play about with it all, as I have forgotten how to use Grafana properly and its changed a bit since last time I used it.
                                toggledbitsT Online
                                FYI only/anecdotally: I am using both 1.8 with Grafana and 2.0 with it's native graphing. Grafana is subtly prettier, for sure, but I'm not sure it outweighs the convenience of having one less piece of software to install. The only thing I haven't verified for 2.0's graphing is that you can do equations/functions as additional traces. I do that on my temp+humidity graphs in Grafana to compute the dew point; it didn't jump out at me how to do it in 2.0's native graphing, so I owe that a few minutes at some point, but at the moment, I'm trying to button up a ton of work to roll out in a new (MSR) release.
                                  3.5k
                                  3.1k
                                  480
                                • Self test
