  4. Recently Changed Entities doesn't update on 22021
7 Posts 5 Posters 1.5k Views 5 Watching
  • X Offline
    X Offline
    xAPPO
    wrote on last edited by xAPPO
    The recently changed entities no longer updates when added to the status page. It does display some initial entries. Other widgets do update as do Entities. (Docker)
      Same here, not updating "live" as before, but refreshes when page is reloaded.
      Bare metal Linux, latest-22021-f83a39c
      F 1 Reply Last reply
        I have the same setup (22021-f83a39c), and it's the same issue here.
          I think this is trickling down, so to speak - this morning my API calls for weather were not refreshing the Global Expressions. I initially thought it was display-related only but automations based around the Global Expressions were misfiring or not firing because the data stored was stale. I've scoured the logs and nothing stands out to me, it looks like everything was polling the API normally (no errors). I have pulled the logs if needed, obviously too large to put here.
          Alas, I found this thread after rolling back to 22004 so I wasn't able to verify that I was also seeing exactly what the above posters are seeing.
            @gwp1 that's likely unrelated to the issue in this thread, needs to go in separate thread, and should be embellished to meet the posting guidelines.
              @toggledbits Been hammering away at the system this morning and I think my experience with the APIs was a red herring. I'm currently on 22021 and monitoring closely (hard to do since wx conditions are very stable atm.)
              I can, however, cast another vote for the topic in this thread - the Recently Changed Entities only updates when switching views.
                I already have the Recently Changed Entities issue fixed. I'm not going to release until later today. There is another issue working on this release, and I have some experimental work ready for you all to look at as well.
                  149.7k
