  4. [MSR] Ideas to consolidate logic for solar heating
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
hvacmsrsolar
3 Posts 2 Posters 610 Views 2 Watching
    So, right now I have two different rules doing this thing, but I want to consolidate into one, because I want to leave everything super organized for the future me.
    One thing I'm doing with solar is to monitor production, and when a threshold is met, I'll start my HVAC system to heat the house (and, in the summer, to cool it). This is working good, because I'm waiting for another rule to run and then I'm doing my things (setting a flag, turning on a thermostat, so the heater can start its magic).
    Then, I have another rule that's turning the thermostat off, if at sunset-30m it's still ON. It's better to run the HVAC for a given amount of time, because after the water is at temperature, we're using less energy anyway.
    So, I want to combine the rules into one, when the set action is the first, and the reset action is the second rule, but I'm finding some difficult and I'd been more than happy to get some help/ideas from you, my friends.
    Keep in mind that I need to ensure that after the HVAC is turned on, I'll wait for the sunset-30m to turn it off. Any hints are appreciated, since I'm struggling to visualize the right solution to this problem. Thanks!
      If I'm understanding your scenario right an AND Sunrise/Sunset between sunrise to sunset-30 in the trigger would run the reset reaction, where you put the actions from your second rule, at sunset-30 as the trigger condition will go false. But it will also turn the HVAC off if the threshold is no longer met, I don't know if that is what you want?
        @crille I want to turn on if the condition is met, and turn off at sunset - 30 regardless, but not before if initial condition is met (this is controlled by a sustained condition that trip a virtual sensor to prevent bouncing). Thanks.
          169
          98.3k
        • Next Release?
          1.0k
