x_hass.domain="fan"
x_hass.source="esphome"
x_hass_attr.percentage=50
x_hass_attr.preset_mode=""
x_hass_attr.preset_modes=[]
primary_attribute_value: |
d = false;
d
Edit: Solved in latest-26221.
Bare-metal latest-26193
I have this group:
"OKforLarm":
name: OK för Larm
- include_controller: vera
Hey @toggledbits
New Status Panels - Controllers rename them?
Posters
738
Views
Watching
Seems its coming from my reactor.yaml file. Maybe I can just change that name in there.
I know it doesn't like you changing the id: last time I tried that it broke everything.
controllers: - id: vera enabled: true implementation: VeraController name: A sample Vera or openLuup system config: source: 'http://192.168.0.12:3480' dump_entity: #device_341: trueEDIT:
That seems to have worked:
@cw-kid kid is correct. You can change the
namefield to get something more agreeable.
