  4. MSR for Scene Controllers
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
10 Posts 2 Posters 1.2k Views 2 Watching
    I still have some code running on my Vera that I want to port and it's related to scene controllers.
    I'm mostly using Fibaro's switch/roller shutter and on the Vera side I'm getting sl_CentralScene/sl_CentralSceneAttr, but it seems too fast to be intercepted by MSR.
    What's anyone using? Thanks.
      @therealdb said in MSR for Scene Controllers:
      I doubt that's the case. I think a lot of people are using those variables, myself included. Can you be (a lot) more descriptive about what you are doing and observing? Also versions and hubs?
        VeraPlus. It could be that it was 5am when I tried it, but it was working well. I'll try again. Latest version, of course. I fear fibaro fgs are too quickly changing these variables, but I'll try again.
          Yeah, but as soon as the variable changes, Luup should be returning from the long poll request with the modified state variable and value. Does the device change these variables rapidly, or is your code on the Vera doing it?
            @toggledbits code on vera is watching and turning on/off other lights. I removed this code and worked with reactions only. I'll try again later this week and report back. It's probably me doing too many things together and a busy week at work is not the best way to accomplish this task. Thanks for the patience and support.
              So, "later this week" has become "let's wait two months to find some spare time" 😄
              I've finally traced the problem (and ported quite everything else), and that's because a couple of devices are only updating sl_CentralScene /sl_CentralSceneAttr, so watching for the regular scene controller capability has no effect. I've since migrated the old code to MSR rule sets and I'm happy now, since there's no code runing on the Vera itself, besides a couple of callbacks to filter wrong values and a notification to know when luup is restarted.
                This has genesis in Z-Wave, because they have two different mechanisms (basically old and new ways) for signaling activity on scene controllers. I guess Vera tried to adapt to that, and they got close, but I think any offset from complete is forgivable here because it's just dang hard. Z-Wave isn't the standard many think it is, and there's a lot of "free play" in how manufacturers interpret and implement the spec. It's part of what has made ZWaveJSController a heavy lift.
                  @toggledbits yeah, I’m still struggling with repeated events, but I’ll eventually win 😬
                    Scene controllers (or more specifically, their buttons) are usually handled with two conditions: one to check the state variable containing the button press for the right number (1 for button 1, 2 for button 2, 77 for triple-click on button 9, etc.), and a second (in an AND group with the first) to check a timestamp that updates (using the changes operator) when the button is pressed. This varies from device to device. I recommend using the detail panel for the scene controller entity (Entities page, click right arrow on device) to monitor what changes when the same button is pressed repeatedly, and you'll soon discover what you need to be testing in the conditions.
                      @toggledbits I’ve found an old post with plain reactor and the same problem. So, while getting the buttons is doable, if the same scene happens again, it will not update (while with luup variable_watch you’ll be notified anyway). I’m trying a couple of different approaches, but setting the variables to something different will stop the report until a luup reload. We’ll see.
                      • Next Release?
