  4. Anybody Installed MSR on unRaid Docker
11 Posts 4 Posters 2.4k Views 4 Watching
  • ? Offline
    ? Offline
    A Former User
    Greetings,
    I'm not a Docker expert hence the choice of using unRaid but I would like to install MSR in a Docker and I'm looking for details on the settings used as I have not installed one manually yet.
    I have installed MSR on Windows Server 2019 but I'm receiving (3 vulnerabilities (1 low, 2 high)) error messages with 'npm' and the audit fix breaks it ('npm').
    Thanks for any help you can provide.
    David
    3 1 Reply Last reply
      On the Windows side, try doing npm i --no-save --omit dev... it looks like a couple of the development dependencies are the cause of the audit warnings.
      • ? Offline
        ? Offline
        A Former User
        I ran that and now the Reactor Windows Service Terminates unexpectedly.
        *** I was able to install MSR in a Docker on unRaid so the details below are for your reference only as I plan on uninstalling Reactor in Windows. ***
        Event Log Shows - ''Child process [7664 - C:\Program Files\nodejs\node.exe C:\reactor\node_modules\node-windows\lib\wrapper.js --file C:\reactor\app.js --scriptoptions= --log "Reactor wrapper" --grow 0.25 --wait 1 --maxrestarts 3 --abortonerror n --stopparentfirst undefined] finished with 1''
        ''C:\reactor>npm i --no-save --omit dev
        npm WARN EBADENGINE Unsupported engine {
        npm WARN EBADENGINE package: 'jsdoc@0.0.0',
        npm WARN EBADENGINE required: { node: '~v0.4.10' },
        npm WARN EBADENGINE current: { node: 'v16.13.1', npm: '8.1.2' }
        npm WARN EBADENGINE }
        removed 5 packages, and audited 90 packages in 1s
        12 packages are looking for funding
        run npm fund for details
        1 high severity vulnerability
        To address all issues (including breaking changes), run:
        npm audit fix --force
        Run npm audit for details.''
        • ? Offline
          ? Offline
          A Former User
          If anyone else is running Dockers on unRaid and wants instructions for Installing Reactor, see below.
          Installing Multi-system Reactor in a unRaid Docker Notes. 01/22/22
          unRaid Version 6.9.2
          Preparation:
          Based on Generic Notes from:
          Installation - Reactor - Multi-Hub Automation
          Typically for Generic (modify with username below):
          docker run --name reactor -d --restart on-failure -p 8111:8111
          -v /home/username/reactor:/var/reactor
          --mount type=bind,src=/etc/localtime,target=/etc/localtime
          toggledbits/reactor:latest-generic-amd64
          Create a Share called "reactor" and use "Prefer Cache" if cache drive is available.
          Under SMB settings - Export = Yes so that you can edit config files. Set security per your needs.
          Go to the Docker tab click Add Container and click Advanced View for additional settings.
          Enter:
          Name = reactor
          Overview = Reactor (Multi-system, aka MSR) is an automation engine for multiple home automation systems. It allows you to develop automations that respond to and control devices across platforms. For example, you could have a motion sensor on a Hubitat controller used as a trigger for set of lights, some of which are connected through a VeraPlus and some through HomeAssistant.
          Please see https://reactor.toggledbits.com/docs for more information.
          Repository = toggledbits/reactor:latest-generic-amd64
          For Latest otherwise choose a specific version
          Docker Hub URL = https://hub.docker.com/r/toggledbits/reactor
          No icon path has been found
          WebUI = http://[IP]:[PORT:8111]/
          CPU Pinning as you see fit.
          Network Type = Bridge
          Console shell command = Shell
          WebGUI = http://[IP]:[PORT:8111]/
          Extra Parameters = --restart=on-failure
          Click Add another Path, Port, Variable, Label or Device.
          Choose Path -
          Name = data
          Container Path = /var/reactor
          Host Path = /mnt/user/reactor (previous share path)
          Access = Read/Write
          Display = Always
          Required = No
          Password Mask = No
          Choose Port -
          Name = Host Port 1
          Container Port = 8111
          Host Port = 8111
          Default Value = 8111
          Type = TCP
          Description will auto populate with "Container Port: 8111" once Saved
          Display = Yes
          Required = Yes
          Password Mask = No
          Save
          Choose Variable -
          Name Key 1
          Key = UMASK
          Val and Default = 100
          Display = Yes
          Required = No
          Password Mask = No
          Save and repeat adding Variables for below:
          Key 2: Container Variable: PUID = 99
          Key 3: Container Variable: PGID = 100
          Click Apply
          Script should look similar to:
          root@localhost:# /usr/local/emhttp/plugins/dynamix.docker.manager/scripts/docker create --name='reactor' --net='bridge' -e TZ="America/Chicago" -e HOST_OS="Unraid" -e 'UMASK'='000' -e 'PUID'='99' -e 'PGID'='100' -p '8111:8111/tcp' -v '/mnt/user/reactor/':'/var/reactor':'rw' --restart=on-failure 'toggledbits/reactor:latest-generic-amd64'
          The command finished successfully!
          Notes:
          • The docker manager script will add the Time Zone based on unRaid's config.
          • If variables (uid/gid <> 99/100) then you must run the "New Permissions" script under Tools
            and select the User Share reactor otherwise the Reactor files will be R/O except for the Docker container.
          • WebUI Access = "http://[your NAS IP]:8111"
          • Follow the reactor configuration documentation for your Hub(s).
          Regards
            If you're getting an error mentioning jsdoc when using npm with --omit dev, I'm wondering if you are trying to install the latest version (22021) or something older?
            • ? Offline
              ? Offline
              A Former User
              It was the latest version (22021). It was running fine but doing "npm audit fix --force" and the command you requested broke it.
              To get it running again I reinstalled node.js and ran the Reactor setup scripts but I didn't like having the audit issues so I'm off of Windows now, deleted the Service and moved to a Docker.
              Thanks for your quick replies but you can pass on my Windows install issue.
              • ? A Former User
                @droy said in Anybody Installed MSR on unRaid Docker:
                This broke my bare metal install on Ubuntu as well. Downgraded and did npm update -- no-save and then upgraded and ran npm i --omit dev then MSR started fine but the vulnerability warning is present. Don't know how to get all packages up to date and have MSR running...
                Edit: Definitely not trying to hijack, just a FYI. Will do more troubleshooting tomorrow and report in an appropriate topic.
                  Make sure you also remove any lockfile (package-lock.json) created by any previous attempts at the command without --no-save --omit dev as well.
                  I've got one of them resolved. Working on the other.
                  • ? A Former User
                    Greetings,
                    David
                    3 Offline
                    3 Offline
                    Yes - I have been running my MSR in my unRAID docker for a long time now. Great details you have noted above @droy. And since a picture is worth a thousand words, I thought I would share my docker setup/UI view. This is the basic view. The only thing I have added within the advance view was an Icon URL. I also run my Reactor on it's own IP and not my unRAID, hence the br0 Network Type.
                    For my Icon URL: I put the following https://smarthome.community/assets/uploads/profile/9-profileavatar.png
                    I suppose if @toggledbits changes his profile icon, my Reactor Docker icon will update too.
                    ? 1 Reply Last reply
                    • 3 3rdStng
                      ? Offline
                      ? Offline
                      A Former User
                      @3rdstng Thanks for the feedback and link to an icon. I'll save that off and put it local.
                      One note - I try to avoid “privileged” mode for containers. It allows it to run containers with (almost) all the capabilities of their host machine, regarding kernel features and device access.
                      Regards
                      • ? A Former User
                        Regards
                        3 Offline
                        3 Offline
                        Yeah. I don't remember why I set it that way. I'll disable it and see if anything breaks.
                          133.2k
