  4. Help with HTTP Request to Ezlo hub to get temp
11 Posts 3 Posters 1.9k Views 3 Watching
    Ticking the option Ignore self-signed/invalid SSL certificates seems to have got rid of the error now and there is now data in the local expression.
    So now I just need to figure out how to extract the temp value from that data, as I want to send it to a virtual temp sensor on my Vera Plus hub.
      @cw-kid is there a reason you are not just taking the value from the Reactor entity?
        @toggledbits said in Help with HTTP Request to Ezlo hub to get temp:
        Very good question and I should of done it that way LOL.
        For some reason I just had using their HTTP API in my mind.
        OK let me try it that way instead using the Entity.
        I am just struggling at the moment trying to create a virtual temperature sensor on my Vera Plus.
        Doing this as Home Remote does not support Ezlo hubs and I wanted this temp sensor in my dashboard app, so it has to be a device coming from the Vera Plus hub, but its actually paired to the Ezlo Plus hub as its a Zigbee device etc.
        Its a shame Rene's Vera -> Ezlo bridge plugin didn't work both ways Ezlo -> Vera also.
          OK I am stuck, I assume I need some expression code? to look at the "Bathroom Temperature" Entity / Device on the Ezlo Plus to extract the current temp value in to the local expression data.
          Once I have that I can then have an Action to Set Variable and send that value to the virtual temp sensor on the Vera Plus.
          Maybe something like:
          getEntity( 'ezlo_plus>device_61f0bbc0123e4312a1900a1b' ).attributes.temperature_sensor.value
          EDIT:
          That seems to work but its a long number
          EDIT2:
          Running the rules action it has sent data to the virtual device on Vera
          However on the main device view I see no value shown.
          Maybe something wrong with my virtual device on the Vera hub or it didn't like to display the long number.
          EDIT3:
          I was using the wrong service on the Set Variable Action it should of been:
          urn:upnp-org:serviceId:TemperatureSensor1
          I now see the data on the device in Vera, however I still need to round down the long number in the local expression some how.
          Also looks bad in Home Remote:
            How about round() https://reactor.toggledbits.com/docs/Expressions-%26-Variables/#arithmetic-functions
              @crille
              Hi Crille
              I was just looking in to that
              Not sure how to round however so it would show something like 16.5 rather than just 16.
                Got it:
                round(BathroomTemp,1)
                So now instead I have to send the value of the expression called "BathroomTempRound" to the virtual device in Vera.
                Which works:
                  @crille
                  Hi Crille
                  @cw-kid Yes, but you don't need to create a new one, just do it like round(getEntity...sensor.value, 1) in your first expression.
                    @crille
                    Got it, that's even better and working also now.
                      I created a How to Guide on the Vera forum, mainly so I don't forget how to do this and others may find it useful also.
                      Feb 10, 2022
                      Example MSR rule to bridge back a device from an Ezlo hub to a Vera hub for Home Remote dashboard
                      I setup this rule today in MSR and a virtual Humidity Sensor on my Vera Plus. I have a real Humidity sensor device (Zigbee) paired to my Ezlo Plus. But as Home Remote dashboard app does not support Ezlo hubs and I wanted a tile showing the Humidity value, the device has to come from the Vera hub...
                        254
                        150.7k
