  4. [Solved] Zwave Refresh for a particular attribute
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
zwave-js
10 Posts 2 Posters 2.2k Views 2 Watching
  • V Offline
    V Offline
    My thermostat (CT100 plus) has been very intermittent in updating its operating"State" (idle, heating or cooling), in a timely manner. Update were coming but sometimes 15 min after the fact. The other attributes are updating just fine. It was like that when paired with my vera plus, and it did not improved since it is on the Hass/Zwavejs2MQTT.
    Back on the vera days, my only option was to use polling but that generated alot of traffic( Thermostat have many attributes). So I kept the polling to a minimum and that did not helped very much. Hass Zwavejs integration only allows polling entire device (like vera I think). I then found out that with Zwave2MQTT, we can poll individual attribute rather than the whole device. This reduced the amount of trafic dramatically, almost 15 to 1. I think that it would be a nice addition for MSR. Why refresh the whole device if only one attribute is needed.
    Following is the screen capture of the zwavejs2MQTT interface for doing this. I did not find a way to attach files but I have one zwavejs2mqtt log file for a MSR refresh and one for the MQTT operating state 66 refresh. The funny thing is that a refresh from MSR trigger all values to be updated, except for the "operating state"! (This thermostat has a mind of its own)
    I can add the 2 files if of any interest (One of them is quite long).
    Using MSR 25139 on Docker, on a Raspberry Pi with Bookworm. Home Assistant 2025.07, Z-Wave JS-UI 10.6.1
      Are you on today's 22049 or the first release?
      V 1 Reply Last reply
        V Offline
        V Offline
        @toggledbits Sorry should have mentionned it. 22049 on Raspberry pi OS with Docker.
        I did most of the work on the initial version but did the upgrade before posting. Just double check and cannot see how I can make rule that trigger every 30 or 60 sec that would set a reaction with Zwave_device_refresh on the thermostat "Operating state" only. That what the zwave2mqtt allow you to do to cope with older zwave devices or in my case, device that do not want to play nice. For the people using the standard zwave-js server, they have no option (that I can think of)
        EDIT: As for the "ThermostatOperatingStateCCGet" not being part of the refresh, I just compare the logs between a refresh from MSR and a refresh from ZwaveJS2MQTT and they are identical (beside callback ID and checksum).
          No worries. I noted a bug in the thermostat support when I plugged your data in on my end that would have prevented, at least to my view of it, the operating state from being correct at all. If you have state, even an old one, that bug was fixed, so we're moving on...
          There is polling already, mentioned in the documentation as a "there but don't use it yet" feature. I've just finished (is anything ever finished?) and extended it to include specific command classes that will work with either zwavejs2mqtt or zwave-js-server (and therefore either is fine with Reactor). That will be out in today's build, along with updated docs.
            V Offline
            V Offline
            @toggledbits Just installed version 22050.
            Almost there! When MSR is restarted after changing the poll configuration, the node is poll with the proper command class. However the Interval time is not taken into consideration. I seems that the global poll interval is taken. Also noticed in the log that the next time (for the poll to be executed) is "Local Time". Not sure if that is normal. Here is my config and the logs. (the config file ident get screwed up with the paste but it is fine)
            Hope this help
            Reactor.yaml
            controllers:
              - id: zwavejs
                implementation: ZWaveJSController
                enabled: true
                  source: ws://192.168....
                  auth: >
                    HIt54tjRUlqaUShB...
                  poll_interval: 3600
                  poll_frequency: 20
                  poll_nodes:
                    - entity: Thermostat
                      command_class: Thermostat Operating State
                      interval: 100
            Log: i.e. my TZ is -5
            [zwavejs-22050]2022-02-20T15:46:02.192Z <ZWaveJSController:5:ZWaveJSController.js:1506> ZWaveJSController#zwavejs node 9 eligible for polling
            [zwavejs-22050]2022-02-20T15:46:02.206Z <ZWaveJSController:5:ZWaveJSController.js:1519> ZWaveJSController#zwavejs polling node 9 command class 0x"42" (Thermostat Operating State)
            2022-02-20T15:46:02.212Z CNTRLR » [Node 009] querying thermostat operating state...
            2022-02-20T15:46:02.238Z SERIAL » 0x010e00a9010902420225000000001522                                  (16 bytes)
            2022-02-20T15:46:02.240Z DRIVER » [Node 009] [REQ] [SendDataBridge]
                                              │ source node id:   1
                                              │ transmit options: 0x25
                                              │ route:            0, 0, 0, 0
                                              │ callback id:      21
                                              └─[ThermostatOperatingStateCCGet]
            2022-02-20T15:46:02.250Z SERIAL « [ACK]        (0x06)
            2022-02-20T15:46:02.256Z SERIAL « 0x010401a90152                                                       (6 bytes)
            [zwavejs-22050]2022-02-20T15:46:02.263Z <ZWaveJSController:6:ZWaveJSController.js:710> ZWaveJSController#zwavejs handling controller event statistics updated
            2022-02-20T15:46:02.259Z SERIAL » [ACK]        (0x06)
            2022-02-20T15:46:02.266Z DRIVER « [RES] [SendDataBridge]
                                                was sent: true
            2022-02-20T15:46:02.304Z SERIAL « 0x011d00a91500000502c47f7f7f7f00000305060000030100007f7f7f7f7fe0    (31 bytes)
            2022-02-20T15:46:02.307Z SERIAL » [ACK]        (0x06)
            2022-02-20T15:46:02.311Z DRIVER « [REQ] [SendDataBridge]
                                                callback id:            21
                                                transmit status:        OK, took 50 ms
                                                repeater node IDs:      5, 6
                                                routing attempts:       1
                                                protocol & route speed: Z-Wave, 100 kbit/s
                                                ACK RSSI:               -60 dBm
                                                ACK RSSI on repeaters:  N/A, N/A
                                                ACK channel no.:        0
                                                TX channel no.:         0
            [zwavejs-22050]2022-02-20T15:46:02.325Z <ZWaveJSController:5:ZWaveJSController.js:652> ZWaveJSController#zwavejs handling node event statistics updated entity Entity#zwavejs>9-0
            [zwavejs-22050]2022-02-20T15:46:02.328Z <ZWaveJSController:6:ZWaveJSController.js:702> ZWaveJSController#zwavejs received statistics for Entity#zwavejs>9-0: [Object]{ "commandsTX": 3, "commandsRX": 3, "commandsDroppedRX": 0, "commandsDroppedTX": 0, "timeoutResponse": 0 }
            2022-02-20T15:46:02.428Z SERIAL « 0x010c00a80001090342030000c2d3                                      (14 bytes)
            2022-02-20T15:46:02.430Z CNTRLR   [Node 009] [~] [Thermostat Operating State] state: 0 => 0         [Endpoint 0]
            [zwavejs-22050]2022-02-20T15:46:02.438Z <ZWaveJSController:5:ZWaveJSController.js:652> ZWaveJSController#zwavejs handling node event value updated entity Entity#zwavejs>9-0
            [zwavejs-22050]2022-02-20T15:46:02.441Z <ZWaveJSController:5:ZWaveJSController.js:788> ZWaveJSController#zwavejs update value [Object]{ "source": "node", "event": "value updated", "nodeId": 9, "args": { "commandClassName": "Thermostat Operating State", "commandClass": 66, "endpoint": 0, "property": "state", "newValue": 0, "prevValue": 0, "propertyName": "state" } }
            [zwavejs-22050]2022-02-20T15:46:02.443Z <ZWaveJSController:5:ZWaveJSController.js:800> ZWaveJSController#zwavejs updating attributes for node 9 value "0:66:state:"=0: [Array][ "hvac_control.state", "hvac_heating_unit.state", "hvac_cooling_unit.state" ]
            [zwavejs-22050]2022-02-20T15:46:02.448Z <ZWaveJSController:5:ZWaveJSController.js:817> ZWaveJSController#zwavejs setting Entity#zwavejs>9-0.x_zwave_values.Thermostat_Operating_State_state to 0
            2022-02-20T15:46:02.438Z SERIAL » [ACK]        (0x06)
            2022-02-20T15:46:02.441Z DRIVER « [Node 009] [REQ] [BridgeApplicationCommand]
                                              │ RSSI: -62 dBm
                                              └─[ThermostatOperatingStateCCReport]
                                                  state: Idle
            **[zwavejs-22050]2022-02-20T15:46:02.454Z <ZWaveJSController:5:ZWaveJSController.js:1525> ZWaveJSController#zwavejs poll Entity#zwavejs>9-0 succeeded, next at 1645375562452<****2/20/2022, 11:46:02 AM****>**
            [zwavejs-22050]2022-02-20T15:46:02.510Z <ZWaveJSController:6:ZWaveJSController.js:710> ZWaveJSController#zwavejs handling controller event statistics updated
            [zwavejs-22050]2022-02-20T15:46:02.575Z <ZWaveJSController:5:ZWaveJSController.js:652> ZWaveJSController#zwavejs handling node event statistics updated entity Entity#zwavejs>9-0
            [zwavejs-22050]2022-02-20T15:46:02.576Z <ZWaveJSController:6:ZWaveJSController.js:702> ZWaveJSController#zwavejs received statistics for Entity#zwavejs>9-0: [Object]{ "commandsTX": 3, "commandsRX": 4, "commandsDroppedRX": 0, "commandsDroppedTX": 0, "timeoutResponse": 0 }
            • V vezinpi
              Hope this help
              Reactor.yaml
              controllers:
                - id: zwavejs
                  enabled: true
                    auth: >
                      HIt54tjRUlqaUShB...
                    poll_interval: 3600
                    poll_frequency: 20
                    poll_nodes:
                        interval: 100
                                                │ source node id:   1
                                                │ route:            0, 0, 0, 0
                                                │ callback id:      21
                                                  was sent: true
                                                  callback id:            21
                                                  routing attempts:       1
                                                  ACK RSSI:               -60 dBm
                                                  ACK channel no.:        0
                                                  TX channel no.:         0
                                                │ RSSI: -62 dBm
                                                    state: Idle
              @vezinpi Got it. Fix in next release.
              It would be helpful if you enclosed config and log stuff in "block code" formatting. To do that, put three backticks (```) one their own line before and after the pasted stuff. If you don't do that, the formatting gets corrupted, and when looking at YAML, that's particularly misleading; you can see that for yourself in your post, I'm sure. Example, before and after formatting:
              this is a code block --
              this line is indented, can you tell?
              put the backticks on their own line
              before AND after the code block.
              You make it look like this while editing:
              That ends up looking like this in the final post:
              I see some non-US keyboard layouts don't have the backtick on a key, but a handy alternative is to select the text/code/config block and hit the button below in this site's post editing tools, or hit the tool first and then paste-replace the default contents:
                V Offline
                V Offline
                @toggledbits said in Zwave Refresh for a particular attribute:
                I have been looking for that for a long time. I am not really a "Forum" type of person. Lot's to learn, thanks for letting me know and your patience.
                  No worries! For most forum use, it's not the kind of thing one needs to know. When things get technical as we do here, it's a big help, though. Thanks for updating, too. The updated post is lovely! 🙂
                  • V Offline
                    V Offline
                    Gave it a try again. It was working as advertised initially but if the zwavejs2mqtt server is restarted/updated then the polling does not resume. It will only resume when MSR is restarted.
                    • V Offline
                      V Offline
                      Fixed by version 22052. 💪
