  4. Moving MSR to Docker
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
5 Posts 3 Posters 790 Views 3 Watching
  • Black CatB Offline
    Black CatB Offline
    Black Cat
    I've decided to start a long needed rationalisation (harmonisation)of my resources and began by installing Docker on a fresh RPi4 with SSD.
    Hopefully this will evolve into a more complete HA System combining various systems that I have , ie Vera, Homeseer, Shelly and use different Containers such as InfluxDB, Granfana, Node-red, MQTT etc.
    The starting point has been to integrate a Vera Edge and Vera Lite into MSR.
    I've been able to connect them via Node-red in Docker however no matter what I try MSR refuses to connect to both.
    It does a dummy spit and refuses to load the second unit usually by refusing to reconnect.
    I have had this working previously on the very first MSR in the dim distant past so I know it should work but after 4 days of trying different configs just in case it was a typo I've struck a dead end and need expert help 🙂
    controllers:
    • id: vera
      enabled: true
      implementation: VeraController
      source: 'http://10.0.0.1:3480'
    • id: test
      enabled: true
      source: 'http://10.0.0.61:3480'
    Using both causes MSR to freeze, either one by itself works.
    What have I missed?
    aka Zedrally
    • Black CatB Black Cat
      controllers:
      • id: vera
        enabled: true
      • id: test
        enabled: true
      What have I missed?
      @black-cat I'm looking at your code format. I don't see the indent for source under config:
      I could be horribly off-base, of course, and it may simply be how it's presenting in your post but mine looks like:
      It's two spaces in from config:
      *Hubitat C-7 2.4.3.177
      Core 2026.1.1
      MSR: latest-26011-c621bbc7
        Black CatB Offline
        Black Cat
        It indents correctly, just the way the it copied over.
        I'm planning on reinstalling this over the weekend there must be 'hidden" characters that somehow have been transposed.
        Better to start with a clean sheet.
        aka Zedrally
          Don't go scorched-earth before you do the basic troubleshooting steps, like disabling the working controller instance and starting up with just the one you think is failing, and looking at the logs. Oh, and did I mention that you should always look at the logs? Also, there's a troubleshooting section in the documentation, with a subsection on startup problems.
          Does anyone know what "freezes" means in this context? That should be more descriptive.
          Please review the posting guidelines. There is probably a lot of information you can be giving us right from the start.
            Black CatB Offline
            Black Cat
            In this case "scorched earth" worked.
            Unfortunately, I did it before I read your reply so we will never know the exact reason why adding the second controller returned a 404 error.
            Now onto MQTT and other temptations such as Fronius to InfluxBD but those are off topic for this thread. Thanks again.
            aka Zedrally
              332
            • Self test
            • Possible feature request 2?
