  4. Summer Time : fonction interval
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
10 Posts 3 Posters 1.2k Views 2 Watching
  • C Offline
    C Offline
    christian_fabre
    Version reactor 22028.
    We changed the time this weekend: summer time.
    The interval function doesn't seem to take this change into account
    C 1 Reply Last reply
    • C christian_fabre
      C Offline
      C Offline
      christian_fabre
      wrote on last edited by christian_fabre
      • C christian_fabre
        @christian_fabre If I'm understanding this correctly, your expectation is that the triggers would update with the time change?
        You don't state what version of MSR you're using currently - version 22080 has a new DST (Daylight Saving Time) toggle in it. From the release notes:
        SystemController: A dst (boolean) attribute has been added to the reactor_system>sun (Sun Information) entity; it will be true when Daylight Saving Time is in effect, false otherwise.
        *Hubitat C-7 2.4.3.177
        Core 2026.1.1
        MSR: latest-26011-c621bbc7
        • C christian_fabre
          @christian_fabre The intent of the Interval condition is to fire on a regular, periodic basis. Adjusting the period for DST changes so it fires at particular times of day is not consistent with its intended regularity/periodicity. From the perspective of actual time in computing terms, DST is only a change to the representation of time. The passage of seconds (or any fraction thereof) is a continuous function within the system, unaffected by DST, and that extends into Reactor. That, too, is why the condition refers to its base as "relative to" and not "at time".
          Doing something every 7th day is more often handled with Weekday conditions (January 1, 2021 being a Friday for reference), coupled (by AND) with a Date/Time condition (after operator) to trigger at (or as soon as possible after, if the system is rebooting at that moment, for example) a particular time (8pm in your case).
          • C Offline
            C Offline
            christian_fabre
            Thank you for your answers.
            I modified as you suggest and it seems more coherent to me.
            On the other hand, I also have 2 recurrences every 2 weeks, in turn:
            Wednesday 1--> Action1,
            Wednesday 2--> Action2,
            Wednesday 3--> Action1,
            Wednesday 4--> Action2,
            etc...
            I don't see how to do...
              For that you could still use an Interval, in an AND group with a Date/Time condition using the after operator at your desired time of day. On the Interval condition, set the relative time to midnight and the delay reset option to stretch the pulse out for the full day, 86400 seconds. So the Interval, when triggered (at midnight), will stay true all day, and the AND'd Date/Time condition will take care of triggering at the right time.
              That method could be applied to any interval of n>1 days universally, including that weekly in your original post. I gave you a special-case solution for weekly intervals above, but this would be the more general solution.
              • C Offline
                C Offline
                christian_fabre
                tthank you.
                I had thought about it but I didn't want to use the interval function anymore.
                Could we also have a choice of week number?
                  Tell me how you would use week number.
                  • C Offline
                    C Offline
                    christian_fabre
                    the previous example: for a recurrence of 2 weeks:
                    even week number and Date/Time condition --> Action 1
                    odd week number and Date/Time condition --> Action 2
                      Keep going. Tell me what your trip through the UI would look like in configuring such a thing.
