  4. Best strategy to get the difference between pulses in MSR
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 713 Views 2 Watching
    So, I have a rule set that it's triggered when a local variable changes. Since it's tied to my solar production, it could change very frequently, so I've just added a reset delay to calm it down, but it's not working as intended.
    What I really need is a way to, let's say, define a percentage and define a variable to understand if the new value has changed +/- 10% before going true.
    I've tried a couple of ways, but I'm posting here anyway, in case anyone has found a better way to tackle this. Thanks!
      There are a couple of things previously discussed, so I won't deep-dive here. But consider the simple case of just keeping the last reference value for the attribute in a local expression (e.g. oldval), getting the new value for the attribute (into newval), and having a third expression to compute the percent difference (abs((newval-oldval)/oldval*100)). A single condition then just tests the computed percentage, and if exceeds whatever threshold, set oldval to newval and do whatever else needs to be done.
      The expression language also contains functions for collecting series data and doing basic maths on the series, with the intention of computing rolling averages and things like that. Those examples comes from Vera Reactor, where people controlled things like bathroom fans using humidity sensors, and wanted to look for sharp changes in humidity seen during showering/bathing (just looking at ambient humidity doesn't work because "normal" is different based on the season or even the day's weather).
        Ok, I’ve used the first approach after my initial post and it’s working. I’m intrigued by the other parts and I’ll take a look later today to the docs, since I want to apply this logic to my logic for the solar excess. Thanks.
          163.0k
