  4. Global Expression – Reference Error
13 Posts 2 Posters 3.1k Views 2 Watching
    Have you looked at the entity contents for groups>dgc_entrance_open? That's what it's complaining about.
    I had not looked at it as an entity, but when comparing it now with others of similar group function, I see no difference in structure that might help understand the error.
      You should have a file in the storage/entities/groups directory called dgc_entrance_open. Can you please post its contents?
      wmarcolinW 1 Reply Last reply
        @toggledbits 🙂
            "id": "dgc_entrance_open",
            "type": "Group",
            "name": "DGC Entrance Open",
            "source_id": null,
            "_lastupdate": 1651610485346,
            "deadsince": false,
            "can_rename": true,
            "can_delete": true,
            "primary_attribute": "sys_group.empty",
            "_attributes": {
                "sys_group": {
                    "members": [],
                    "empty": true
            "actions": {},
            "capabilities": {
                "sys_group": {
                    "attributes": {
                        "members": {
                            "type": "array",
                            "default": []
                        "empty": {
                            "type": "bool",
                            "default": true
                    "actions": {}
            "notify_member_changed": true,
            "serialize_version": 2
        Thaks.
          OK, and let's be clear... does this happen on every restart, and only on this global variable? You have cleared the alert and restarted and verified that the alert returns?
            Every time I perform a restart, the error appears, and always and only in this variable.
            I clear the message, restart the variable and everything is fine. If I restart the MSR again, then the whole error scenario comes back.
              ATTENTION: I have just installed the new version 22123, a new installation procedure, and the error does not happen.
              I have tested restarting the MSR by Service and Tools > Restart.
              We can close this discussion.
                OK, but just to be safe, please do the following:
                1. Stop your Reactor service.
                2. Remove the reactor.log file from the logs subdirectory.
                3. Restart Reactor.
                4. Post the log file.
                I want to have a look from the start onward. Thanks!
                  3. Restart Reactor.
                  @toggledbits thank you for all your attention.
                  I tried to post the log here, but it exceeds the number of characters.
                  Can you indicate another place to send the file?
                    I'll send you a link via PM.
                      Got it. Looks good. Perfectly clean. There was an incidental issue where the DGC was delaying releasing notifications on a group if the group filtered out all of its entities. You might have noticed different behavior had a door been open at the time Reactor restarted vs what appears to be the more common condition that all were closed (thus empty group displaying the bug). Onward!
                          156.5k
