  4. MSR ZEN32 weird behavior
3 Posts 2 Posters 1.2k Views 2 Watching
    RogerO
    Hi Patrick,
    Running HASS 2022.5.3
    MSR zwavejs-22126-834c3e9
    Seeing weird behavior in MSR with regards to my Zen32's. Not sure how to capture info that might be relevent but will describe what I am seeing.
    In the example below I pressed scene 001 4 times. It flashed and changed the primary value to "4". The remaining buttons were previously showing the PV as "double" I pushed each button one time and they flashed and displayed the PV as 4.
    In the zwavejs2mqtt debug screen that sequence looks like this.
    2022-05-10 09:38:44.078 INFO ZWAVE: Node 45: value notification: 91-0-scene-001 5
    2022-05-10T16:38:44.081Z CNTRLR « [Node 045] received CentralScene notification {
    "nodeId": 45,
    "ccId": "Central Scene",
    "ccCommand": "0x03",
    "payload": "0x898501"
    2022-05-10 09:38:45.982 INFO ZWAVE: Node 45: value notification: 91-0-scene-002 0
    2022-05-10T16:38:45.984Z CNTRLR « [Node 045] received CentralScene notification {
    "nodeId": 45,
    "payload": "0x8a8002"
    2022-05-10 09:38:47.807 INFO ZWAVE: Node 45: value notification: 91-0-scene-003 0
    2022-05-10T16:38:47.810Z CNTRLR « [Node 045] received CentralScene notification {
    "nodeId": 45,
    "payload": "0x8b8003"
    2022-05-10 09:38:48.858 INFO ZWAVE: Node 45: value notification: 91-0-scene-004 0
    2022-05-10T16:38:48.861Z CNTRLR « [Node 045] received CentralScene notification {
    "nodeId": 45,
    "payload": "0x8c8004"
    Let me know what other info you would like me to supply.
    I have played around with a bunch of other key stroke combo's and it looks like buttons 2-5 display what ever button 1 is set to.
    Have tested this on 4 different ZEN32's and it is same on all.
    • toggledbitsT Online
      toggledbitsT Online
      I think I've got that. Update to build 22130 (the most recent zwavejs, just posted).
        RogerO
        Thanks, Fixed it.
          147.6k
