  4. Reactor as tab in Hass sidebar
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
6 Posts 2 Posters 785 Views 2 Watching
  • W wokwon
    So, following:
    cd \path\to\reactor
    node tools\install_reactor_windows_service.js -u .
    del /s /f node_modules
    npm rm -g node-windows
    npm uninstall node-windows
    npm uninstall -g node-windows
    npm install -g node-windows@1.0.0-beta.6
    npm link node-windows
    ...extract the Reactor.zip over the old directory...
    node tools\install_reactor_windows_service.js -i .
    I'm now running fine with Reactor (Multi-hub) stable-22136.
    Thank you @toggledbits for your support and amazing product.
    Bonus is the SSL now works too (CertifytheWeb with LetsEncrypt will renew it and drop the key files in the correct location). That means I can have Reactor as a tab in the Hass sidebar (previously https Hass --> http reactor would not work).
    Ractor.yaml:
    99a5f802-c3e4-4bfa-9a29-975de1da4d28-image.png CertifyTheWeb:
    621270ab-242f-47c4-a7ee-d547ce9eb4cf-image.png Browser:
    MatohlM Offline
    MatohlM Offline
    Matohl
    panel_iframe in configuration.yaml. If you access MSR with HTTP it works in HA with HTTP to Reactor and HTTPS to HTTPS obviously.
    configuration.yaml
    # ============ SIDEBAR ============
    panel_iframe:
      reactor:
        title: "Reactor"
        url: "http://192.168.0.23:8111/reactor/sv-SE/"
    MatohlM G 2 Replies Last reply
    • MatohlM Matohl
      configuration.yaml
      panel_iframe:
        reactor:
          title: "Reactor"
      MatohlM Offline
      MatohlM Offline
      Matohl
      • MatohlM Matohl
        configuration.yaml
        panel_iframe:
          reactor:
            title: "Reactor"
        @matohl Thank you for this.
        *Hubitat C-7 2.4.3.177
        Core 2026.1.1
        MSR: latest-26011-c621bbc7
          Quick question: how to add an icon next to it?
          Core 2026.1.1
          MatohlM 1 Reply Last reply
            MatohlM Offline
            MatohlM Offline
            Matohl
            @gwp1
            panel_iframe:
              reactor:
                title: "Reactor"
                icon: 'mdi:wrench'
            • MatohlM Matohl
              @gwp1
              panel_iframe:
                reactor:
                  title: "Reactor"
                  icon: 'mdi:wrench'
              @matohl Yessir - figured that out way too late into the night to reply 😉 Also used this to add my two Hubitats to the mix.
              Core 2026.1.1
                253
                3.6k
                3.2k
                763
