  4. Condition must occur after -restriction not working
3 Posts 2 Posters 735 Views 2 Watching
    Running MSR 22123 in Docker container and trying to use "condition must occur after" option. Will update to the latest build and log a PR if needed, but wanted to poll first if anyone is using this option successfully?
    I have the following rules:
    Notification activity connected to "Alarm disabled" rule did not trigger. I also did another test with quite simple rules and that didn't work either (FWIIW - when observing that test in "real-time", I didn't see any timer running on the second rule while the first rule was true).
    As said, before going further with debug/logs, nice to know if someone is using this option/restriction (successfully).
      OK. I think I've got this, and fixed in 22179.
        @toggledbits, can confirm that this build fixed the problem
          158.1k
