  4. Idiot questions. Feel free to ignore.
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
19 Posts 5 Posters 4.2k Views 5 Watching
    @CatmanV2 Check this thread. It goes thru my trials with PULSE to much success.
    https://smarthome.community/topic/816/solved-will-pulse-work-for-retrying-a-ruleset-if-the-device-hasn-t-responded-as-expected/26
      @gwp1 thanks, not sure it's directly applicable but I think it's prompted me to a possible restructure of the logic which may do it in fewer components.
      Nope still can't make it work.
      Cheers
        Cheers
        @catmanv2 Read thru the post - my goal was to have pulse implemented to retry setting my t-stats if they did not accept the first attempt and to continue for a set amount of time until they did.
        I also use it for my washing machine "done" alert - if I don't open the lid, signaling I'm emptying the washer upon completion, it continues up to ten more times announcing for the world to hear (the whole house via Alexa Echo devices) that it needs emptied.
          @gwp1 Oh yes, I understand that. The challenge I have is that when the pulse ends the reset reaction is triggered, which is specifically what I was looking to avoid.
          I currently have a use case where the Server room temperature goes too high (set) and fires a warning reaction. I want it to repeat that warning (pulse does that just fine) but when the temperature drops (reset) it runs another notification. (To say everything is fine)
          If I pulse the output of the set to get the warning to repeat (which it does) then when the pulse ends, the rule is reset and the 'Everything is fine' notification is sent. Which I want to avoid as everything is not fine.
          I can absolutely have two rules both of which 'set' and get around it that way, but I was trying to do it with one.
            @catmanv2 If you use pulse you could create a local expression that is true when temperature is below threshold, otherwise false and in the reset reaction you only send the notification if the expression is true.
              @crille ahhh, now that sounds like a good learning exercise! Thanks 🙂
                And it was. Didn't want to start coding but hey 🙂
                <exit>
                And I assume I can use this for the other idiot question I was going to ask: Can I change the reactions as an ELSE type thing.
                So I'm assuming I can have two groups in the set and reset reactions with mutually exclusive conditions
                  Yes, you can have multiple groups in both set reaction and reset reaction, if conditions is not met in a group but in another group those actions will fire instead.
                    @crille as I have just found out! Thanks 🙂
                    • toggledbitsT Online
                      toggledbitsT Online
                      Also don't forget that there's a "repeat...while" group available in reactions, which seems on reading the original problem statement to be a likely candidate for repeating a command or set commands until they are honored.
                      CatmanV2C CrilleC 2 Replies Last reply
                        @toggledbits thanks, I tried that but couldn't work out how to define the repeat cadence. 😞
                          toggledbitsT Online
                          Use a delay action in the repeat group.
                            @toggledbits said in Idiot questions. Feel free to ignore.:
                            DOH
                            Thanks 🙂
                              I didn't mention that because I had some issues/questions about it that I have not found time to test futher, so this is a heads up. I will try to find time to test more and create a new topic soon. 🙂
                                164.2k
