  4. Troubles Running MSR as a Service
11 Posts 3 Posters 1.5k Views 3 Watching
    Successfully got MSR to run on a VM running Ubuntu 22.04 but am running into an issue with getting to run MSR as a service. Here is what my reactor.service file looks like below.
    However when I go to run the service I see this error: reactor.service: Failed at step CHDIR spawning /usr/bin/node: No such file or directory. Checked and the node file exists in this directory. Kinda stuck at this point, probably a simple fix but I am way in over my head 😰
    [Service]
    Type=simple
    User=armans2
    WorkingDirectory=/home/reactor
    Environment=/home/reactor
    Restart=on-failure
    RestartSec=5s
      It may exist in that directory, but possibly as a broken symbolic link. This file (and similar like npm) are often symlinked to a different directory where the real executable file is installed. Can you post the output of ls -ld /usr/bin/node? And if it is a symlink, make sure the location/file it points to exists.
      Also the Environment line is malformed. Refer to the reactor.service-example file in the tools directory.
      PablaP 1 Reply Last reply
        @toggledbits heres the output -rwxr-xr-x 1 root root 81180048 Jul 7 05:05 /usr/bin/node
        I did create a symlink hoping that would work using this command /usr/bin$ sudo ln -s node nodejs
          Not sure where you are going with that symlink. The file should be called node and not nodejs, so don't do that. What happens when you run /usr/bin/node -v on the command line?
            wrote on last edited by Pabla
            v16.16.0 is the resonse
              Good. Then your WorkingDirectory is wrong. So is your Environment line (see my earlier comment, it's malformed). Are you sure the WorkingDirectory should not be /home/armans2/reactor? That would make more sense for the configuration of User.
                @toggledbits Ha that was it, I was playing around with the Environment line cause it wasn't working at first and forgot to revert it back. Now that I have MSR working as a service, will this start on boot, or do I have to configure that?
                  systemctl enable reactor.service
                    @pabla said in Troubles Running MSR as a Service:
                    If you are able to use Docker, life is much much easier...
                      Excellent! Making the move from Vera to HA with MSR and MSR is making it so so much easier!
                        @tunnus Was debating on using Docker, but for now I am running HA OS and MSR on two separate Virtual Machine on my Windows comp just to get things up and running. Will probably migrate my set up to a NUC later
                          148.4k
