  4. TTS in MSR?
TTS in MSR?
33 Posts 12 Posters 17.8k Views 12 Watching
  • F Fanan
    @toggledbits said in TTS in MSR?:
    You can add the notify service to the entity (have you done this?)
    @toggledbits No, I haven't used the notify service. I might give it a try later this week. If you (or anyone else) figure it out, please share!
    B Offline
    B Offline
    Buxton
    @fanan Per this topic https://smarthome.community/topic/744/sending-a-service-request-to-home-assistant?_=1638829172919 I couldn't get Alexa tts to work in MSR, but I do have it working in openLuup with the following code that sits inside a simple plugin:
    myEchoDevice = "alexa_media_".. myEchoDevice
    myEchoMessage = table.concat(myEchoMessage)
    local request_body = json.encode {message = myEchoMessage, data = {["type"] = "announce",method = "all"}}
    local response_body = {}
    local theURL = 'http://'..HomeAssistantIP..':'..HomeAssistantPort..'/api/services/notify/'..myEchoDevice
    r, c, h = http.request {
       url = theURL,
       method = "POST",
       headers = {
       ["Content-Type"]   = "application/json",
       ["Authorization"] = "Bearer ".. HomeAssistantToken,
       ["Content-Length"] = request_body:len()
    source = ltn12.source.string(request_body),
    sink   = ltn12.sink.table(response_body)
    The variable "myEchoDevice" is the exact name of the specific echo device (or device group) as presented in the Amazon Alexa app. I typically broadcast to all my devices via a group, intercom style, so I catch the message wherever I am in my home. The variable "HomeAssistantToken" needs to be created in HA. "myEchoMessage "is a lua table in the above code, but you could just as easily capture the message as a string, and then trim the string prior to sending it to the HTTP post request.
    • F Fanan
      @fanan OK. So it turns out that this has (much) more to do with the way the Alexa Media Player service works than anything. You can simply use the call_service action on the controller's system object to call the notify.alexa_media service (or its variants, more on that below). If you do it through the system entity, you don't need to make exceptions in your local configuration to add the service -- you can run a service against any entity from the system entity, and if it's not supported, the (Hass) entity will either ignore it or log an error, but nobody dies, missiles do not launch, gravity still works, the sun continues to rise and set, etc.
      Above are two different versions of the service call that do about the same thing. I'll work backwards because that's the way I figured it out...
      The green-circled "short" version of the service name requires that you specify the target in the service data. The service data is a structure as shown (always). Also see the docs for the component for more info about this service and its data. The target field must be specified when using this short form of the service name, and its value is an array of HomeAssistant entity IDs (not Reactor entity IDs) for the players (Dots and Echos) that will speak the phrase. The data substructure must be given as shown.
      The red-circled variant uses a longer service name that includes the Amazon device's name. Apparently the component creates a set of aliased services, each with the device name appended to the base service name. I find this annoying, because I have over a dozen Dots/Echos, so and it creates a bunch of data pollution. But, it's there, and it's usable. When you use a "long" service name, you don't need to specify target in the data, but it's otherwise the same, as shown.
      therealdbT F T 3 Replies Last reply
        @toggledbits Speaking of that, is there a way to easily compose re-usable actions, so I could just pass the arguments (message and device) and call the same function? I'll use for the very same purpose, since I have a couple of endpoints doing notifications/TTS. Thanks!
          @toggledbits That's great news! My only problem is that my Hass entity don't have any actions... :
          1580fec2-cbbb-45a3-b434-c4fe00eeb03d-image.png I don't know how you activated the x_hass_system.call_service?
          Do I have to change anything in my reactor.yaml?
            - id: hass
              enabled: true
              name: Home Assistant
                source: 'wss://f_______'
                access_token: "eyJ0eXAi_______________________________________________________________________________________________________________________________2-nLoI369-iYcJf9z_3sviSiWA"
                # ignore_cert - If true, suppresses certificate validation when using wss:// (Websocket
                #               with SSL/TLS) and thus allows a self-signed certificate to be used on
                #               the Hass system.
                #ignore_cert: false
                # dump_all_states - This is for troubleshooting. Do not enable unless asked.
                #dump_all_states: false
                log_events: false
          • F Fanan
              - id: hass
                enabled: true
                  #               the Hass system.
                  #ignore_cert: false
                  log_events: false
            #24
            @fanan That's not the system entity. It's probably named "Home Assistant" based on your configuration, and you can also filter by the sys_system capability.
            F 1 Reply Last reply
              @toggledbits Ahh..! I see it now. Thanks! I'm struggeling with the indentation, but I guess it will come around after a few tries... 🙂
              The best of all is as you so well put it: "...and if it's not supported, the (Hass) entity will either ignore it or log an error, but nobody dies, missiles do not launch, gravity still works, the sun continues to rise and set, etc."
              Even Shakespeare him self would be impressed!
              • F Fanan marked this topic as a question on
              • F Fanan has marked this topic as solved on
              • W Offline
                W Offline
                whyfseeguy
                What did I do wrong?
                The service works in HA scripts but not in Reactor
                • W whyfseeguy
                  @whyfseeguy said in TTS in MSR?:
                  Well, you didn't post what the action logged. Did you look?
                  Off the top of my head looking at it, you've wrapped data in data. I think you just need it to be:
                      "entity_id": "media_player.media_room_tv",
                      "message": "hello there"
                  • W Offline
                    W Offline
                    whyfseeguy
                    It is working now with your recipe. I had too many "data" in data field. I was following the examples above and got confused.
                      This thread has been super helpful. I have a few questions that are somewhat related:
                      1. Similar to @therealdb 's request. Is there a way to call this from the Alexa entity vs. a "call service" from the controller entity? I tried adding the TTS service but it's still not showing up under the entity. (see below - ignore multiple entries - was trying a few formats of the name)
                      2. In the service call, is there a way to make the announcement at a certain volume? Even better if it could snap back. You can see I'm setting the volume, delaying, and then announcing but was wondering if someone has a more elegant solution.
                      I realize this isn't all an MSR issue (much more HASS) but thought there are good minds here that may be able to help. Thanks.
                      • T tbully
                        Here's everything from the entity page:
                        av_repeat.repeat_mode="unknown"
                        av_repeat.shuffle=null
                        av_transport.album_art=null
                        av_transport.current_album=null
                        av_transport.current_artist=null
                        av_transport.current_title=null
                        av_transport.current_track=null
                        av_transport.state="standby"
                        muting.state=false
                        power_switch.state=true
                        volume.level=0.15
                        x_hass.domain="media_player"
                        x_hass.entity_id="media_player.office_echo"
                        x_hass.services=["media_player"]
                        x_hass.state="standby"
                        x_hass_attr.available=true
                        x_hass_attr.bluetooth_list=[]
                        x_hass_attr.connected_bluetooth=null
                        x_hass_attr.friendly_name="Office Echo"
                        x_hass_attr.is_volume_muted=false
                        x_hass_attr.last_called=true
                        x_hass_attr.last_called_summary=""
                        x_hass_attr.last_called_timestamp=1660318076357
                        x_hass_attr.media_content_type="standby"
                        x_hass_attr.media_position_updated_at="2022-08-12T16:05:58.870619+00:00"
                        x_hass_attr.source="Local Speaker"
                        x_hass_attr.source_list=["Local Speaker"]
                        x_hass_attr.supported_features=56253
                        x_hass_attr.volume_level=0.15
                        Capabilities: av_repeat, av_transport, media_navigation, muting, power_switch, toggle, volume, x_hass, x_hass_media_player
                        Actions: av_repeat.repeat_all, av_repeat.repeat_off, av_repeat.repeat_one, av_repeat.set_repeat, av_repeat.set_shuffle, av_repeat.shuffle_off, av_repeat.shuffle_on, av_transport.fast_forward, av_transport.pause, av_transport.play, av_transport.rewind, av_transport.stop, media_navigation.next_chapter, media_navigation.next_media, media_navigation.next_track, media_navigation.previous_chapter, media_navigation.previous_media, media_navigation.previous_track, muting.mute, muting.set, muting.toggle, muting.unmute, power_switch.off, power_switch.on, power_switch.set, toggle.toggle, volume.decrease, volume.increase, volume.relative, volume.set, volume.set_db, x_hass_media_player.clear_playlist, x_hass_media_player.join, x_hass_media_player.media_next_track, x_hass_media_player.media_pause, x_hass_media_player.media_play, x_hass_media_player.media_play_pause, x_hass_media_player.media_previous_track, x_hass_media_player.media_seek, x_hass_media_player.media_stop, x_hass_media_player.play_media, x_hass_media_player.repeat_set, x_hass_media_player.select_sound_mode, x_hass_media_player.select_source, x_hass_media_player.shuffle_set, x_hass_media_player.toggle, x_hass_media_player.turn_off, x_hass_media_player.turn_on, x_hass_media_player.unjoin, x_hass_media_player.volume_down, x_hass_media_player.volume_mute, x_hass_media_player.volume_set, x_hass_media_player.volume_up
                        • N Offline
                          N Offline
                          Hi, just playing around this topic with Alexa and I share it:
                          Example that works:
                          Still no lucky to play with "random" announce.
                          This example not work:
                          -Docker on Synology NAS
                          -HASS Docker 2026.8.1
                          -ZWaveJS-UI 11.22.3
                          -Update 16/08/2026
                          • N noelab
                            Example that works:
                            #32
                            @noelab ciao! I randomize them in Reactor. Just use this:
                            messages[ floor( random() * len( messages) )
                            where messages is a local variable like this:
                            "Bentornato a casa",
                            "Casa, dolce casa!",
                            "Ciao!",
                            N 1 Reply Last reply
                              "Ciao!",
                              N Offline
                              N Offline
                              @therealdb said in TTS in MSR?:
                              "Ciao!",
                              Grazie! and thanks to @toggledbits for the new dark theme, also my eyes are happy!
                              -ZWaveJS-UI 11.22.3
                              -Update 16/08/2026
                                158.3k
