  4. x_vera_device.failed=true Question
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
Possible feature request?
Time series documentation
7 Posts 2 Posters 717 Views 2 Watching
    I have a couple of HS1DS-Z door sensors (Z-Wave) this issue is newish and hasn't always been a problem with them. I have an MSR rule that will detect any failed devices on the Vera Hub and alert me. For some reason MSR thinks these two door sensors have failed when I think they have not. As they are fully working and operational within Vera.
    Yesterday I unpaired both of them from the Vera controller and added them again to see if that might fix the issue, but I have just seen an alert in MSR about one of these door sensors being failed again.
    Looking at it in the Entities I see this:
    Looking at this devices variables in the Vera UI7 I don't even see a CommFailure variable listed at all for some reason, not sure why.
    So how is MSR deciding the device is failed ?
      arming.state=false
      battery_power.level=0.65
      battery_power.since=1661355061000
      binary_sensor.state=false
      door_sensor.state=false
      x_vera_device.configured=true
      x_vera_device.device_number=202
      x_vera_device.device_type="urn:schemas-micasaverde-com:device:DoorSensor:1"
      x_vera_device.mapped_by="*;device_type=urn:schemas-micasaverde-com:device:DoorSensor:1"
      x_vera_device.mapped_class="door_sensor"
      x_vera_device.parent_device=1
      x_vera_device.room_id="7"
      x_vera_svc_micasaverde_com_HaDevice1.AutoConfigure="-1"
      x_vera_svc_micasaverde_com_HaDevice1.BatteryDate="1661355061"
      x_vera_svc_micasaverde_com_HaDevice1.BatteryLevel="65"
      x_vera_svc_micasaverde_com_HaDevice1.ChildrenSameRoom="1"
      x_vera_svc_micasaverde_com_HaDevice1.CommFailure="1"
      x_vera_svc_micasaverde_com_HaDevice1.CommFailureAlarm="1656854367,1"
      x_vera_svc_micasaverde_com_HaDevice1.CommFailureTime="1661092640"
      x_vera_svc_micasaverde_com_HaDevice1.Configured="1"
      x_vera_svc_micasaverde_com_HaDevice1.FirstConfigured="1661353606"
      x_vera_svc_micasaverde_com_HaDevice1.LastUpdate="1661355061"
      x_vera_svc_micasaverde_com_HaDevice1.ModeSetting="1:;2:A;3:A;4:A"
      x_vera_svc_micasaverde_com_HaDevice1.PollRatings="5.00"
      x_vera_svc_micasaverde_com_HaDevice1.WakeupRatings="5.00"
      x_vera_svc_micasaverde_com_HaDevice1.sl_Alarm="TAMPER_ALARM"
      x_vera_svc_micasaverde_com_HaDevice1.sl_Alarm_updated=1658772103494
      x_vera_svc_micasaverde_com_HaDevice1.sl_BatteryAlarm="0"
      x_vera_svc_micasaverde_com_HaDevice1.sl_BatteryAlarm_updated=1658772103494
      x_vera_svc_micasaverde_com_HaDevice1.sl_TamperAlarm="0"
      x_vera_svc_micasaverde_com_HaDevice1.sl_TamperAlarm_updated=1661355055978
      x_vera_svc_micasaverde_com_SecuritySensor1.Armed="0"
      x_vera_svc_micasaverde_com_SecuritySensor1.ArmedTripped="0"
      x_vera_svc_micasaverde_com_SecuritySensor1.IgnoreTripTime="2"
      x_vera_svc_micasaverde_com_SecuritySensor1.LastTamper="1661355055"
      x_vera_svc_micasaverde_com_SecuritySensor1.LastTrip="1661377232"
      x_vera_svc_micasaverde_com_SecuritySensor1.Tripped="0"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AgiInfo="X"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmType="0x6,0x7,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AlarmVersion="0,1"
      x_vera_svc_micasaverde_com_ZWaveDevice1.AssociationNum="5"
      x_vera_svc_micasaverde_com_ZWaveDevice1.Capabilities="83,156,1,4,7,1,R,B,RS,|48:2,89,90,94,113:4,114,115,128,132:2,133,134,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredAssoc=""
      x_vera_svc_micasaverde_com_ZWaveDevice1.ConfiguredWakeupInterval="86400"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastArr="1661377143,2"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastNnu="1661375951,2"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastReset="1661353599"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastRouteUpdate="1661354768"
      x_vera_svc_micasaverde_com_ZWaveDevice1.LastWakeup="1661377235"
      x_vera_svc_micasaverde_com_ZWaveDevice1.ManufacturerInfo="608,360,360"
      x_vera_svc_micasaverde_com_ZWaveDevice1.NodeInfo="30,59,5a,5e,71,72,73,80,84,85,86,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PlusInfo="1,6,0,12,6,12,6"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PollNoReply="131"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PollOk="2"
      x_vera_svc_micasaverde_com_ZWaveDevice1.PollSettings="0"
      x_vera_svc_micasaverde_com_ZWaveDevice1.SensorBiType="10"
      x_vera_svc_micasaverde_com_ZWaveDevice1.SubscribedAlarms=",0x6,0x7,"
      x_vera_svc_micasaverde_com_ZWaveDevice1.VersionInfo="6,4,5,1,1"
      x_vera_svc_micasaverde_com_ZWaveDevice1.WakeupCapabilities="60,86400,10800,60"
      x_vera_svc_micasaverde_com_ZWaveDevice1.WakeupInterval="86400"
      x_vera_svc_micasaverde_com_ZWaveNetwork1.ConsecutivePollFails="0"
      x_vera_svc_micasaverde_com_ZWaveNetwork1.LastPollSuccess="1661355061"
      x_vera_svc_upnp_org_SwitchPower1.Status="0"
      zwave_device.capabilities="83,156,1,4,7,1,R,B,RS,|48:2,89,90,94,113:4,114,115,128,132:2,133,134,"
      zwave_device.failed=true
      zwave_device.manufacturer_info="608,360,360"
      zwave_device.node_id=147
      zwave_device.version_info="6,4,5,1,1"
      Capabilities: arming, battery_power, binary_sensor, door_sensor, x_vera_device, x_vera_security, x_vera_svc_micasaverde_com_HaDevice1, x_vera_svc_micasaverde_com_SecuritySensor1, x_vera_svc_micasaverde_com_ZWaveDevice1, x_vera_svc_micasaverde_com_ZWaveNetwork1, x_vera_svc_upnp_org_SwitchPower1, zwave_device
      Actions: arming.arm, arming.disarm, x_vera_device.set_variable, x_vera_security.trip, x_vera_security.untrip, x_vera_svc_micasaverde_com_HaDevice1.AllowPairing, x_vera_svc_micasaverde_com_HaDevice1.Poll, x_vera_svc_micasaverde_com_HaDevice1.Reconfigure, x_vera_svc_micasaverde_com_HaDevice1.Remove, x_vera_svc_micasaverde_com_HaDevice1.SetPollFrequency, x_vera_svc_micasaverde_com_HaDevice1.StressTest, x_vera_svc_micasaverde_com_HaDevice1.ToggleState, x_vera_svc_micasaverde_com_SecuritySensor1.SetArmed, x_vera_svc_micasaverde_com_ZWaveNetwork1.AddNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.BackupDongle, x_vera_svc_micasaverde_com_ZWaveNetwork1.DownloadNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.HealNetwork, x_vera_svc_micasaverde_com_ZWaveNetwork1.PollAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.PutByte, x_vera_svc_micasaverde_com_ZWaveNetwork1.ReconfigureAllNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.RemoveNodes, x_vera_svc_micasaverde_com_ZWaveNetwork1.SendData, x_vera_svc_micasaverde_com_ZWaveNetwork1.SetPolling, x_vera_svc_micasaverde_com_ZWaveNetwork1.SimulateIncomingData, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNeighbors, x_vera_svc_micasaverde_com_ZWaveNetwork1.UpdateNetwork, x_vera_svc_upnp_org_SwitchPower1.SetTarget, zwave_device.debug, zwave_device.heal, zwave_device.interview, zwave_device.poll, zwave_device.reconfigure, zwave_device.refresh, zwave_device.remove_failed, zwave_device.replace_failed, zwave_device.reset_meters, zwave_device.set_config, zwave_device.set_location, zwave_device.set_name, zwave_device.set_value
        Just spotted "x_vera_svc_micasaverde_com_HaDevice1.CommFailure="1"" in that output above. Yet I cannot see that in the Vera UI7 web GUI for this device in its variables. Also I do not have that red banner that says "Can't detect device". As far as Vera looks the device looks to be all OK and working fine.
        Obviously that variable should be 0 not 1.
          This is the device variables in Vera UI7
            Just create the CommFailure variable on the Vera using the service ID given with a value of 0. That variable should exist for all Z-Wave devices, so if it isn't there, it either got deleted somehow (corruption?) or its a bug in the device handler (on the Vera).
              Looking on another different device I made a note of these:
              CommFailure - urn:micasaverde-com:serviceId:HaDevice1
              CommFailureTime - urn:micasaverde-com:serviceId:HaDevice1
              CommFailureAlarm - urn:micasaverde-com:serviceId:HaDevice1
              Then on one of the problematic Door contact sensors I added the new services.
              Now under its Variables tab I see them:
              I will monitor and see if CommFailure goes back to 1 ?
                The issue isn't that CommFailure was 0 or 1, it was that it wasn't there at all. That suggests it may have existed at some point with value 1, then disappeared, leaving the attribute value on the MSR side stuck (because it had no variable from Vera to use to change it). It's possible the Vera device handler has a bug and instead of setting 0 when the device is configured, it sets it to blank, which as of a couple of firmware versions ago, deletes the variable rather than setting it to an empty value. Having now created it manually, if it later disappears, that would confirm this theory -- something in the firmware is removing for some reason (or worst case, there's user_data corruption). In any case, CommFailure should always exist for Z-Wave devices, so something isn't right there, but of course, no chance that it would be researched or fixed these days. The Vera firmware thread has been long dead, no updates have been published, and questions and requests are left unanswered; I have my doubts that anyone with the knowledge (and will) is still there. Everyone's busy filling the holes in the new firmware (now four years since the acquisition).
                  94
                  3.5k
                  3.1k
                  419
                • Self test
