  4. OpenWeatherMap not providing any data
4 Posts 3 Posters 752 Views 3 Watching
    I configured OWM Weather on MSR (latest-22257-dd9b9271), created an account with OWM, generated an API key, put the key in the yaml file, and I’ve waited over a day now. OWM Weather shows as up on the the Controller Status widget.
    I’ve tried to create a trigger or constraint to use the data, and nothing is really showing up.
    I only have a free subscription with OWM, but I was expecting some data.
    Is this expected behavior (i.e., still in development), or do I do more configuration other than the .yaml file?’
    I still am able to pull Weather data through Dark Sky in my Vera plus controller, however, I know that will no longer work at some point.
    • T tamorgen
      CrilleC Online
      CrilleC Online
      @tamorgen The actual weather data is not provided by the OWM Weather Entity. The data is in the Entity named by your location.
      Go to Entity page and select controller OWM Weather to list all entities associated with it and you'll find it.
        @crille
        Thanks Crille, that makes sense!
        • T tamorgen
          @crille
          @tamorgen I can assure you that OWM does work very well with MSR. I am not using the reactor.yaml config, however. I call to OWM with a ruleset that populates multiple variables. I do this for OWN, Apple Sky, and Ambient (from my own wx station's API.)
          *Hubitat C-7 2.5.2.135
          Core 2026.10.1
          MSR: latest-26287-0a7107d5
            148.4k
