  4. iPhone location or alternative.
54 Posts 6 Posters 21.5k Views 6 Watching
    Looks like it's an overall thing. I've just checked the two devices on OpenLuup. Both of them are reporting 'No Devices for this account, check network/credentials'
    They can been seen on Find my. The user and pass are correct. Logs
    2022-10-07 17:54:39.684   luup_log:55: IPhoneLocator: iCloud refused access, Check credentials ?
    My logs only go back to yesterday but this appears consistent since then.
    (I know I'm not sticking to the posting guides but I'm not actually asking for help simply confirming that it seems rather bust)
      I see @amg0 has an account but also has never posted. The code hasn't been updated for some years. I'll have a poke at some of the settings (on the phone) but I'm not hopeful....
        Final note I suspect: My device checked in 1707 05/10/2022 BST and has not checked out since
        Mrs C's device checked out 0800 05/10/2022 BST and never checked in, although she came home at about 1800 that night (it was our wedding anniversary so we're pretty clear on that)
        So that narrows down the window a chunk....
        • MikeReadingtonM Offline
          MikeReadington
          @CatmanV2 Well, at least I know it was not just me. I knew this day was coming because he had said something in August when it was broken that he didn't know if it was fixable because of Apple's API. I am thinking they kicked everything that did not use 2FA authentication.
          @therealdb I set up Owntracks on Hubitat because it was easy, and I could play with it. Looks like it is very flexible. How hard is it on the battery? I realize mileage will vary a lot on this, but that was a feature I liked about the iPhone locator app. It ran using Apple's "Find My" that was already running on the phone. It's slow to update, but if I needed to know where the phone was, I would force a poll of location from the app. Since I started refining my logic in MSR I have been using manual polling almost exclusively. Thanks again for the point in this direction.
            MikeReadington
            Something of note from OwnTracks with iOS.
            "Why do location publishes sometimes seem to cease to work?
            Here's what happens:
            If the app goes into Background, the connection is disconnected because the app cannot maintain the TCP connection in background.
            If you bring the app back into foreground, the app will re-connect.
            When a location change is recorded (no matter if manual, significant, move or region mode), a message is prepared and an attempt to connect to the broker is started. If there is an error, connect will be retried after 2, 4, 8, ..., 64, 64, .... seconds until it succeeds.
            BUT...
            If the application is in background or is sent to the background, retries are restarted eventually - depending on iOS' background execution model about every 10 minutes.
            With automatic modes switched off, even when bringing the app to foreground, no new location updates are generated."
              @mikereadington said in iPhone location or alternative.:
              Quite quite possible
                BUT...
                @mikereadington and this precisely explains the issues I saw. And makes perfect sense (I'm engaged with a company that is developing an a for iOS and Apple's restrictions and what happens when an App backgrounds (read 'is stopped') are quite severe.
                Taking this, and my own recent experience into account, I don't think Owntracks is going to be viable. In fact, given the limitations from Apple I'm not sure anything is going to be viable for a geofence 😞
                  iOS has a background system to preserve battery life. It’s designed to be reliable and to not impact battery life. If you define your zones (I have home and office) at the very same moment you’ll cross the boundaries, a message is sent. I’m on my 2nd year with the system and never missed a bit. I also have a Bayesian sensor to detect if I’m connected to WiFi, and this is used as a second factor to confirm I’m home. But generally speaking, the entry/exit is totally demanded to OwnTracks.
                  CatmanV2C G 2 Replies Last reply
                    @therealdb It is indeed so designed, but that's not what I am seeing in terms of behaviour. Of course I may have misconfigured it on my phone so I am happy to be corrected!
                    (but I'll probably bug you for help) 😉
                    But not right now
                      @CatmanV2 I concur with @therealdb here, I've been using the OwnTracks on iOS via the Hubitat app integrations and it works well. I also use, as a secondary, a Home Assistant integration called iCloud3 which mitigates the 2FA issues you found with iPhone Locator. I've seen no noticeable battery issues (once I had iC3 configured correctly.)
                      @toggledbits got me into OwnTracks when he had his Logo trial up and running.
                        Well I fully expect to be wrong 🙂 I know that Geolocation is one of the use cases that Apple permit (or at least tolerate) in their process (and it's documented in the Owntracks literature as well as being the workaround for our devs.
                        I strongly suspect I fubarred the config somewhere (possibly as basic as not allowing full location services, for example). I had a crack this morning and I have the phone claiming it's connected, and reactor claiming it's connected (yay)
                        I need to get the entity installed but that's another day
                          Trying to follow the posting guidelines.....
                            - id: mqqt
                              enabled: true
                                source: "mqtt://192.168.70.249:8883/"
                                username: xxxxx
                                password: xxxxx
                                entities:
                                  catman_iphone:
                                    topic: FFCEB043-B975-490E-B051-198473F6A504
                                    uses_template: owntracks_in_region
                          Claims to be valid YAML in https://yamlchecker.com/
                          But when I add the last 4 lines to my reactor.yaml msr will not start:
                          Reactor log stops:
                          [latest-22274]2022-10-08T17:32:39.316Z <Engine:NOTICE> [Engine]Engine#1 has shut down.
                          [latest-22274]2022-10-08T17:32:39.316Z <app:NOTICE> Closing Structure...
                          [latest-22274]2022-10-08T17:32:39.317Z <Structure:INFO> Structure#1 Stopping controllers...
                          [latest-22274]2022-10-08T17:32:39.317Z <VeraController:NOTICE> VeraController#vera stopping
                          [latest-22274]2022-10-08T17:32:39.321Z <VeraController:ERR> Controller VeraController#vera is off-line!
                          [latest-22274]2022-10-08T17:32:39.366Z <MQTTController:NOTICE> MQTTController#mqqt stopping, sending LWT
                          [latest-22274]2022-10-08T17:32:39.366Z <DynamicGroupController:NOTICE> DynamicGroupController#groups stopping
                          [latest-22274]2022-10-08T17:32:39.369Z <DynamicGroupController:ERR> Controller DynamicGroupController#groups is off-line!
                          [latest-22274]2022-10-08T17:32:39.369Z <SystemController:NOTICE> SystemController#reactor_system stopping
                          [latest-22274]2022-10-08T17:32:39.371Z <SystemController:ERR> Controller SystemController#reactor_system is off-line!
                          [latest-22274]2022-10-08T17:32:39.372Z <Structure:INFO> Structure#1 Final data sync...
                          [latest-22274]2022-10-08T17:32:39.379Z <Structure:NOTICE> Structure Structure#1 stopped
                          [latest-22274]2022-10-08T17:32:39.379Z <app:NOTICE> Stopping timers...
                          [latest-22274]2022-10-08T17:32:39.380Z <app:NOTICE> Shutdown complete, process ID 27723
                          As soon as I replace the original version of reactor.yaml
                            - id: mqqt
                              enabled: true
                                username: xxxx
                                password: xxxx
                          Everything springs to life.
                          I can't see an error in my syntax. Do I need to have the region in there (although I've tried both with and without)
                          It's going to be something obvious / stupid but hopefully I'm learning at least a little
                          TIA
                              - id: mqqt
                                enabled: true
                                  username: xxxxx
                                  password: xxxxx
                                  entities:
                                    catman_iphone:
                            Reactor log stops:
                              - id: mqqt
                                enabled: true
                                  username: xxxx
                                  password: xxxx
                            TIA
                            @catmanv2 the logs are not complaining, so maybe the error was written before.
                            values are escaped with " in the docs, give it a try (ie: "catman_iphone" and topic: "FFCEB043-B975-490E-B051-198473F6A504")
                              Tried
                                entities:
                                      catman_iphone:
                                        regionName: Home
                              and
                                entities:
                                      "catman_iphone":
                                        regionName: Home
                              With no discernible difference
                                Tried
                                  entities:
                                        catman_iphone:
                                          regionName: Home
                                and
                                  entities:
                                        "catman_iphone":
                                          regionName: Home
                                @catmanv2 Topics for me are not UUIDs, but rather the content of the Device ID field in the Identification section of the configuration. This is a value you set, not a value determined by OwnTracks. That's Android. I no longer have an Apple device I can use for this.
                                        owntracks_patrick_home_template:
                                          name: "Patrick Home Template"
                                          topic: phrs21
                                          regionName: Home
                                  MikeReadington
                                  Thanks for all of the input.
                                  For whatever reason I am having the same spotty relationship with OwnTracks that @CatmanV2 has. One minute I think it's solved, the next minute it's missed a trigger.
                                  With the success others have had, including @gwp1 with the same method of deployment, I must have something wrong. I'll keep working on it as time permits.
                                  Thanks again
                                    Thanks again
                                    @mikereadington iPhone or Android?
                                      MikeReadington
                                      @catmanv2 iPhone. I just returned home and it got a location trigger, but it was far from an instant trigger. The phone was in sleep for at least 30 minutes before I crossed the perimeter, and I would say the delay was in the area of 45 seconds.
                                        45 seconds I can live with, personally but might not be right for your use case. (My fence is about 5km out)
                                        The thing I'm struggling with right now is testing it. I think I need to cross the fence. Logically I make the region much smaller for testing purposes but other issues at work today.
                                        G MikeReadingtonM 2 Replies Last reply
                                          @catmanv2 testing OwnTracks can be accomplished by changing from substantial to move in the app and then, well, moving.
                                            1.0k
                                            157.6k
