  4. Entity is not visible
@toggledbits I pulled the image (well, Watchtower did) and within minutes the whole system went offline. The log looks like it ends with 26143. [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mkahsmgf/26qq82mw-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lqyfljfi/22f8on0t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lsb61rw8/24oenqi2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/rule-lrh58he0:S-1c00gfib-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1c00dylr-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lrh58he0/1nam9w5u-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miuh2qqi/22ls4lql-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1vj8sdfc-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-kwc6rmci/rule-kwc6rmci:S-1qanz01x-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/24lq19p6-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-mk0o8iox/23oy468y-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-miscg2h3/rule-miscg2h3:S-22gmbq1c-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrfjke/238p0old-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-m7ccsso5/re-m7ccsso5-1r0myjxa-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/19nl9wq2-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3xk9t-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ladyja6a/rule-ladyja6a:S-yl3vv5m-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/re-ln7j2nqp-22mx9lzd-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-ln7j2nqp/22mx87c8-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-licneppy/1mzwe7ht-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-ml3194ih/25jqt1j4-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-kxgrg7kf/227hshak-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13ua1p95-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-reactorexmachina/13uagam7-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x4cbv-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-grpvl9oypg/rule-grpvl9oypg:R-134x2fyl-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#re-lscjrws1/238p5c22-cons [latest-26143]2026-05-31T15:23:44.547Z <default:INFO> Closing container Container#Predicate#rule-lbwr0jvq/1xkczf03-cons [latest-26143]2026-05-31T15:23:44.547Z <Structure:NOTICE> Structure Structure#1 stopped [latest-26143]2026-05-31T15:23:44.547Z <app:NOTICE> Closing APIs... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: closing... [latest-26143]2026-05-31T15:23:44.547Z <wsapi:NOTICE> wsapi: disconnecting from "192.168.1.23#82" (1001 service closing) [latest-26143]2026-05-31T15:23:44.548Z <httpapi:NOTICE> HTTP API closing... [latest-26143]2026-05-31T15:23:44.549Z <wsapi:NOTICE> wsapi: server closed [latest-26143]2026-05-31T15:23:44.549Z <httpapi:INFO> HTTP server closed. [latest-26143]2026-05-31T15:23:44.549Z <app:NOTICE> Stopping timers... [latest-26143]2026-05-31T15:23:44.551Z <app:null> Shutdown complete, process ID 1 [latest-26143]2026-05-31T15:23:44.551Z <app:null> Closing logs... [latest-26143]2026-05-31T15:23:44.551Z <default:null> Closing log I can SSH to the VM. Alas, I do not have the previous image for 26143 as I'm a little too quick sometimes on housekeeping.
7 Posts 2 Posters 943 Views 3 Watching
    Trying my damndest to follow the guidelines......
    Reactor latest-22274-24dfd72c
    Intel NUC Debian Bullseye
    Using an online YAML editor I have managed to create a reactor.yaml with an entity that allows Reactor to start (no idea why vi seems to break the yaml)
      - id: mqqt
        enabled: true
          source: "mqtt://192.168.70.249:8883/"
          username: xxxx
          password: xxxx
        entities:
          catman_iphone:
          topic: FCEB043-B975-490E-B051-198473F6A504
          uses_template: owntracks_in_region
          region: "Home"
    My expectation is that this would create a binary sensor. I can see no such sensor.
    Reactor log:
    [latest-22274]2022-10-09T15:13:55.580Z <app:null> Reactor latest-22274-24dfd72c starting on v16.15.0
    [latest-22274]2022-10-09T15:13:55.581Z <app:INFO> Process ID 10567; docker false; platform linux/x64 #1 SMP Debian 4.19.235-1 (2022-03-17); locale en_GB.UTF-8
    [latest-22274]2022-10-09T15:13:55.581Z <app:INFO> Basedir /home/catman/reactor; data in /home/catman/reactor/storage
    [latest-22274]2022-10-09T15:13:55.581Z <app:INFO> NODE_PATH=/home/catman/reactor
    [latest-22274]2022-10-09T15:13:55.583Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8
    [latest-22274]2022-10-09T15:13:55.601Z <app:INFO> Loaded locale en-US
    [latest-22274]2022-10-09T15:13:55.612Z <Capabilities:null> Module Capabilities v22250
    [latest-22274]2022-10-09T15:13:55.659Z <Plugin:null> Module Plugin v21186
    [latest-22274]2022-10-09T15:13:55.663Z <TimerBroker:null> Module TimerBroker v22263
    [latest-22274]2022-10-09T15:13:55.665Z <default:INFO> Module Entity v22258
    [latest-22274]2022-10-09T15:13:55.667Z <Controller:null> Module Controller v22266
    [latest-22274]2022-10-09T15:13:55.668Z <default:null> Module Structure v22123
    [latest-22274]2022-10-09T15:13:55.675Z <default:null> Module Ruleset v21096
    [latest-22274]2022-10-09T15:13:55.675Z <default:null> Module Rulesets v21096
    [latest-22274]2022-10-09T15:13:55.680Z <GlobalExpression:null> Module GlobalExpression v21333
    [latest-22274]2022-10-09T15:13:55.697Z <Predicate:null> Module Predicate v22271
    [latest-22274]2022-10-09T15:13:55.699Z <AlertManager:null> Module AlertManager v22117
    [latest-22274]2022-10-09T15:13:55.701Z <default:null> Module Rule v22265
    [latest-22274]2022-10-09T15:13:55.704Z <GlobalReaction:null> Module GlobalReaction v21333
    [latest-22274]2022-10-09T15:13:55.705Z <default:null> Module Engine v22266
    [latest-22274]2022-10-09T15:13:55.705Z <default:null> Module httpapi v22248
    [latest-22274]2022-10-09T15:13:55.717Z <default:null> Module wsapi v22104
    [latest-22274]2022-10-09T15:13:55.719Z <app:NOTICE> Starting Structure...
    [latest-22274]2022-10-09T15:13:55.723Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
    [latest-22274]2022-10-09T15:13:55.727Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
    [latest-22274]2022-10-09T15:13:55.762Z <TaskQueue:null> Module TaskQueue 21351
    [latest-22274]2022-10-09T15:13:55.763Z <VeraController:null> Module VeraController v22258
    [latest-22274]2022-10-09T15:13:55.866Z <Structure:INFO> Structure#1 loading controller interface mqqt (MQTTController)
    [latest-22274]2022-10-09T15:13:55.869Z <MQTTController:null> Module MQTTController v22144
    [latest-22274]2022-10-09T15:13:55.930Z <MQTTController:INFO> instance topic ident is mqqt
    [latest-22274]2022-10-09T15:13:55.933Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
    [latest-22274]2022-10-09T15:13:55.938Z <DynamicGroupController:null> Module DynamicGroupController v22123
    [latest-22274]2022-10-09T15:13:55.941Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
    [latest-22274]2022-10-09T15:13:55.944Z <SystemController:null> Module SystemController v22257
    [latest-22274]2022-10-09T15:13:55.946Z <Structure:INFO> Starting controller VeraController#vera
    [latest-22274]2022-10-09T15:13:55.947Z <VeraController:NOTICE> VeraController#vera starting
    [latest-22274]2022-10-09T15:13:55.985Z <VeraController:INFO> VeraController#vera loaded mapping ver 22257 rev 3 format 1 notice (none)
    [latest-22274]2022-10-09T15:13:55.990Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
    [latest-22274]2022-10-09T15:13:55.990Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
    [latest-22274]2022-10-09T15:13:56.000Z <Structure:INFO> Starting controller MQTTController#mqqt
    [latest-22274]2022-10-09T15:13:56.001Z <MQTTController:NOTICE> Connecting to broker mqtt://192.168.70.249:8883/
    [latest-22274]2022-10-09T15:13:56.036Z <Structure:INFO> Starting controller DynamicGroupController#groups
    [latest-22274]2022-10-09T15:13:56.041Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
    [latest-22274]2022-10-09T15:13:56.041Z <Structure:INFO> Starting controller SystemController#reactor_system
    [latest-22274]2022-10-09T15:13:56.043Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
    [latest-22274]2022-10-09T15:13:56.081Z <app:NOTICE> Starting HTTP server and API...
    [latest-22274]2022-10-09T15:13:56.083Z <httpapi:NOTICE> Starting HTTP API v1 22248 on http://192.168.70.2
    Anyone comment on what I've done wrong?
    TIA
        - id: mqqt
          enabled: true
            username: xxxx
            password: xxxx
          entities:
            catman_iphone:
            region: "Home"
      Reactor log:
      TIA
      @catmanv2 said in Entity is not visible:
      This is a solid performance.
      If i had to guess, you're indenting with tabs rather than spaces. That would be the first thing I'd look at. No tabs allowed.
      Easy, at least at the first level: your entities section is at the same indent level as config. The entities section is part of config, so it should be indented underneath it. entities: and all of the lines that follow as part of it should be indented two more spaces. As you have it, MQTTController can't even see that section, and that would explain why you're not getting an entity created.
      Should be:
        - id: mqqt
          enabled: true
            username: xxxx
            password: xxxx
            entities:
              catman_iphone:
        Should be:
          - id: mqqt
            enabled: true
              username: xxxx
              password: xxxx
              entities:
                catman_iphone:
        @toggledbits said in Entity is not visible:
        Thanks. I promise I'm not not but I'll just do it in a browser for now 🙂
          - id: mqqt
            enabled: true
              username: xxxx
              password: xxxx
              entities:
                catman_iphone:
                topic: catmaniphone
                region: "Home"
        Everything starts fine. I've hard refreshed the browser.
        Still can't find any entity in either the entities screen or if I try to use 'it' in a rule.
        Clearly I've still done something idiotic, and there's an error in here, but damned if I know what it means?
        [latest-22274]2022-10-09T17:45:15.492Z <Structure:INFO> Starting controller MQTTController#mqqt
        [latest-22274]2022-10-09T17:45:15.493Z <Structure:INFO> Starting controller DynamicGroupController#groups
        [latest-22274]2022-10-09T17:45:15.496Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
        [latest-22274]2022-10-09T17:45:15.496Z <Structure:INFO> Starting controller SystemController#reactor_system
        [latest-22274]2022-10-09T17:45:15.498Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
        [latest-22274]2022-10-09T17:45:15.538Z <Structure:ERR> Structure#1 controller mqqt failed to start: [TypeError]TypeError: Cannot read properties of null (reading 'uses_template')
        [latest-22274]2022-10-09T17:45:15.538Z <Structure:CRIT> TypeError: Cannot read properties of null (reading 'uses_template')
            at MQTTController.start (/home/catman/reactor/ext/MQTTController/MQTTController.js:73:21)
            at Structure.start (/home/catman/reactor/server/lib/Structure.js:346:56)
        [latest-22274]2022-10-09T17:45:15.538Z <MQTTController:NOTICE> MQTTController#mqqt stopping, sending LWT
        [latest-22274]2022-10-09T17:45:15.539Z <MQTTController:NOTICE> MQTTController#mqqt stopping
        [latest-22274]2022-10-09T17:45:15.540Z <app:NOTICE> Starting HTTP server and API...
        [latest-22274]2022-10-09T17:45:15.542Z <httpapi:NOTICE> Starting HTTP API v1 22248 on http://192.168.70.249:8111
        [latest-22274]2022-10-09T17:45:15.545Z <app:NOTICE> Starting Reaction Engine...
        [latest-22274]2022-10-09T17:45:15.545Z <Engine:INFO> Reaction Engine starting
        Cheers
        <edit> per the other thread I've also edited the DeviceID to catmaniphone on the phone and in the reactor.yaml. The log remains the same.
          OK. I just noticed one more error... if I had included more sample data in my last example to you, I would have noticed it earlier...
          All together now... entities: must be indented two spaces from config: (as per my last post), but also everything after catman_iphone: should be indented two spaces from that...
            - id: mqqt
              enabled: true
                username: xxxx
                password: xxxx
                entities:
                  catman_iphone:
                    topic: catmaniphone
                    region: "Home"
          General rule of thumb... if the : is the last character on the line, everything below it will need to be indented.
            I shall try to remember, thanks!
            So I have this:
              - id: mqqt
                enabled: true
                  username: xxxxx
                  password: xxxxx
                  entities:
                    catman_iphone:
                      topic: catmaniphone
                      region: "Home2"
            And in the logs:
            [latest-22274]2022-10-09T20:45:55.083Z <app:null> Reactor latest-22274-24dfd72c starting on v16.15.0
            [latest-22274]2022-10-09T20:45:55.084Z <app:INFO> Process ID 24110; docker false; platform linux/x64 #1 SMP Debian 4.19.235-1 (2022-03-17); locale en_GB.UTF-8
            [latest-22274]2022-10-09T20:45:55.084Z <app:INFO> Basedir /home/catman/reactor; data in /home/catman/reactor/storage
            [latest-22274]2022-10-09T20:45:55.084Z <app:INFO> NODE_PATH=/home/catman/reactor
            [latest-22274]2022-10-09T20:45:55.086Z <app:INFO> Configured locale (undefined); selected locale(s) en_GB.UTF-8
            [latest-22274]2022-10-09T20:45:55.105Z <app:INFO> Loaded locale en-US
            [latest-22274]2022-10-09T20:45:55.113Z <Capabilities:null> Module Capabilities v22250
            [latest-22274]2022-10-09T20:45:55.160Z <Plugin:null> Module Plugin v21186
            [latest-22274]2022-10-09T20:45:55.164Z <TimerBroker:null> Module TimerBroker v22263
            [latest-22274]2022-10-09T20:45:55.166Z <default:INFO> Module Entity v22258
            [latest-22274]2022-10-09T20:45:55.168Z <Controller:null> Module Controller v22266
            [latest-22274]2022-10-09T20:45:55.169Z <default:null> Module Structure v22123
            [latest-22274]2022-10-09T20:45:55.176Z <default:null> Module Ruleset v21096
            [latest-22274]2022-10-09T20:45:55.176Z <default:null> Module Rulesets v21096
            [latest-22274]2022-10-09T20:45:55.181Z <GlobalExpression:null> Module GlobalExpression v21333
            [latest-22274]2022-10-09T20:45:55.194Z <Predicate:null> Module Predicate v22271
            [latest-22274]2022-10-09T20:45:55.197Z <AlertManager:null> Module AlertManager v22117
            [latest-22274]2022-10-09T20:45:55.198Z <default:null> Module Rule v22265
            [latest-22274]2022-10-09T20:45:55.201Z <GlobalReaction:null> Module GlobalReaction v21333
            [latest-22274]2022-10-09T20:45:55.202Z <default:null> Module Engine v22266
            [latest-22274]2022-10-09T20:45:55.202Z <default:null> Module httpapi v22248
            [latest-22274]2022-10-09T20:45:55.214Z <default:null> Module wsapi v22104
            [latest-22274]2022-10-09T20:45:55.215Z <app:NOTICE> Starting Structure...
            [latest-22274]2022-10-09T20:45:55.218Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
            [latest-22274]2022-10-09T20:45:55.221Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
            [latest-22274]2022-10-09T20:45:55.258Z <TaskQueue:null> Module TaskQueue 21351
            [latest-22274]2022-10-09T20:45:55.259Z <VeraController:null> Module VeraController v22258
            [latest-22274]2022-10-09T20:45:55.362Z <Structure:INFO> Structure#1 loading controller interface mqqt (MQTTController)
            [latest-22274]2022-10-09T20:45:55.366Z <MQTTController:null> Module MQTTController v22144
            [latest-22274]2022-10-09T20:45:55.422Z <MQTTController:INFO> instance topic ident is mqqt
            [latest-22274]2022-10-09T20:45:55.425Z <Structure:INFO> Structure#1 loading controller interface groups (DynamicGroupController)
            [latest-22274]2022-10-09T20:45:55.429Z <DynamicGroupController:null> Module DynamicGroupController v22123
            [latest-22274]2022-10-09T20:45:55.432Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
            [latest-22274]2022-10-09T20:45:55.435Z <SystemController:null> Module SystemController v22257
            [latest-22274]2022-10-09T20:45:55.438Z <Structure:INFO> Starting controller VeraController#vera
            [latest-22274]2022-10-09T20:45:55.438Z <VeraController:NOTICE> VeraController#vera starting
            [latest-22274]2022-10-09T20:45:55.477Z <VeraController:INFO> VeraController#vera loaded mapping ver 22257 rev 3 format 1 notice (none)
            [latest-22274]2022-10-09T20:45:55.482Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
            [latest-22274]2022-10-09T20:45:55.482Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
            [latest-22274]2022-10-09T20:45:55.492Z <Structure:INFO> Starting controller MQTTController#mqqt
            [latest-22274]2022-10-09T20:45:55.492Z <MQTTController:ERR> MQTTController#mqqt entity catman_iphone uses_template=owntracks_in_region, template not defined
            [latest-22274]2022-10-09T20:45:55.493Z <MQTTController:NOTICE> Connecting to broker mqtt://192.168.70.249:8883/
            [latest-22274]2022-10-09T20:45:55.527Z <Structure:INFO> Starting controller DynamicGroupController#groups
            [latest-22274]2022-10-09T20:45:55.533Z <DynamicGroupController:NOTICE> Controller DynamicGroupController#groups is now online.
            [latest-22274]2022-10-09T20:45:55.533Z <Structure:INFO> Starting controller SystemController#reactor_system
            [latest-22274]2022-10-09T20:45:55.535Z <SystemController:NOTICE> Controller SystemController#reactor_system is now online.
            [latest-22274]2022-10-09T20:45:55.574Z <app:NOTICE> Starting HTTP server and API...
            [latest-22274]2022-10-09T20:45:55.576Z <httpapi:NOTICE> Starting HTTP API v1 22248 on http://192.168.70.249:8111
            [latest-22274]2022-10-09T20:45:55.579Z <app:NOTICE> Starting Reaction Engine...
            [latest-22274]2022-10-09T20:45:55.579Z <Engine:INFO> Reaction Engine starting
            Still no device. Thanks 🙂
              You need at least version 22260 of MQTTController
                Perfect! Thanks!
                Now to see if it works!
                  128.0k
