  4. Using Variables in notifications
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
Need help with sequence
11 Posts 5 Posters 1.5k Views 5 Watching
  • C Offline
    C Offline
    Cadwizzard
    wrote on last edited by Cadwizzard
    I'm trying to insert variables into notifications. I've tried
    "message": "Oil Level is {{Oil_Level_V_to_Percent}}"
    Also prefixing {{ with $ and a few other things.
    I get the main body but the variable is missing, i.e "Oil Level Is"
    Could someone please help me send the variable (and to title the notification would be great too)
    Many thanks 🙂
    Apologies
    Hass: v2022.10.4
    MSR: latest-22274-24dfd72c
    The rule :
    PablaP 1 Reply Last reply
    • C Cadwizzard
      Many thanks 🙂
      Apologies
      Hass: v2022.10.4
      The rule :
      @cadwizzard first we’d need to know what home controller you are using and what version of MSR.
        ...and if the variable and action is in a Rule (show it) or a Global Reaction (show it). And show the variable definition, be it rule-based or global.
        • C Offline
          C Offline
          Cadwizzard
          Apologies
          Initial post updated
            wrote on last edited by Pabla
            So when you are testing if the actions work using a variable you have to use the big play button that right under the "Set Reaction" title. As for using said variable you're going to want to use it in this form ${{<variable_name>}}. Since you were likely hitting the play button just for this action that is probably why you werent getting the variable value in your notification.
            As for adding a title it will look like this
              "message": "${{Oil_Level_V_to_Percent}}",
              "title": "<insert title name>"
            C 1 Reply Last reply
              C Offline
              C Offline
              Cadwizzard
              @pabla Thank You!
              I was going wrong with the title by missing the comma in preceding line, I had the rest right and indented the same before I took the code out, as it wasn't working.
              And right again, I had tested the code with ${{content}} but it didn't work - most likely because I used the play button to the right and not above the reaction.
              Really appreciated, i've updated my template I copy from, so that should be notifications sorted for everything now.
              Seperate issue is the value on the sensor flaps up and down by 1% when its close to changing (temperature in the oil tank/expansion) and sends lots of notifications, just need to figure out how to address that. But off topic for this post 🙂
              • C Cadwizzard
                @pabla Thank You!
                @cadwizzard You can use the round function for your variable to round it to whatever decimal point you need. Have a look in reactor docs under expressions -> functions for more info
                  C Offline
                  C Offline
                  Cadwizzard
                  @pabla The issue isn't rounding, the sensor is in Volts, i multiply by 10 to get % for gauges etc, so it's always rounded.
                  The issue is due to temperature and the accuracy of the sensor (ultrasonic), when the oil level is very close to for example 55 and 56% (5.5v/5.6v) and the oil expands, the reading will go from 55 to 56 and then 55 and then 56 over and over due to the tiny variance between the two readings. If that makes sense.
                  I can't set a rule to only track decreasing changes as we also fill up the tank sometimes too 🙂
                    You might consider a bit of time-based hysteresis by using the "sustain for" option in your rule/condition(s). I do this with various things around the house... if the attic humidity is above X% for more than YY minutes, start the dehumidifier, etc. This removes the short-cycling that can occur when a measurement is unstable around a critical point.
                    Also, there are ways previously documented in Reactor for Vera to do things like one-hour averages and moving averages, which can dampen those bounces/drifts. I'm not sure if anyone has done an MSR version of those, but the general approach is the same.
                    therealdbT MikeReadingtonM 2 Replies Last reply
                      therealdbT Online
                      therealdbT Online
                      @toggledbits said in Using Variables in notifications:
                      Speaking of this, I'll surely welcome some recipes somewhere. I'll think a curated list will definitely benefit the community. I think it's fair to link reactor ones as well, since expressions are almost similar.
                        MikeReadingtonM Offline
                        MikeReadington
                        @toggledbits I used something like that to dampen solar panel logic. I am not "legally" allowed to hook up, but I still wanted to play with them. I still have a dumb meter and it's easily possible to end up negative for the month. I used a couple of RIB relays to turn panel groups off if the consumption target for the month was trending under what would be considered believable.
                        (I also turn them off by the driveway entrance sensor logic on the days that I know the meter reader will show up. I don't particularly need an observant reader seeing the meter flying around backward)
                          748
                          3.6k
                          3.2k
                          807
