  4. Entity sanity check
Entity sanity check
9 Posts 3 Posters 2.2k Views 3 Watching
    Just before I break everything, can someone confirm for me that this should add another binary device with the same proerties?
     - id: mqqt
       enabled: true
          source: "mqtt://192.168.70.249:8883/"
          username: xxxxx
          password: ***********
          entities:
            catman_iphone:
              topic: catmaniphone
              user: catman
              uses_template: owntracks_in_region
              regionName: Home2
            rachel_iphone:
              topic: racheliphone
              regionName: Home
              user: rachel
    With the caveats that her username is "rachel", DeviceID is "racheliphone" and her region is set to "Home"
    TIA!
      This is the way.
        I shall gift you much Baskar
          Fab so I have an entity. I had to make some changes to the Owntracks config so there was no stored message. Time will tell. Thanks for all the help
          • CatmanV2C CatmanV2 has marked this topic as solved on
            @catmanv2 Did the typo in id: cause any issues?
            *Hubitat C-7 2.5.2.135
            Core 2026.10.1
            MSR: latest-26287-0a7107d5
              None at all. As far as I know, this was the id line with the distribution. There's no editing of that required (although with my editing skills, who knows)
              I think the
              id:
              Value can be anything you like, it just shows up in the Controller drop down in the Entities area.
              Could be wrong though
                That's correct. You set the ID. It just needs to be unique in its context*, and alphanumeric only (no punctuation/special characters or Unicode).
                * By "in its context", I mean that if you are supplying an ID for a controller, it must be unique among controllers; if for an entity, it must be unique among entities (for the controller the manages it — it's fine for two controllers to have an entity with the same ID, that's why Reactor uses canonical IDs (the controllerID>entityID form) in most places to disambiguate that similarity.
                @CatmanV2 I note that the ID in your snippet above is "misspelled" (if it's possible to misspell an ID)... mqqt instead of mqtt. This makes no difference, but you did send me to the package files to make sure I hadn't made that typo in the source material (I didn't). If you change it, it will break any rules or reactions you have created for its entities, FYI.
                  @toggledbits thanks for the heads up! Out of curiousity, I assume it's mqtt package files? Lord alone knows what I was doing 😄
                  Thanks as ever!
                    Thanks as ever!
                    @catmanv2 said in Entity sanity check:
                    Yes. There's a sample config in the package, and I had to check it. All extras will be getting sample configs like that, and the documentation will in future likely also be moved or duplicated into the package as well.
                      148.4k
