  4. REST API implementation
Error: Command timeout
This post does not apply to users of Intel/AMD-based systems. If you are using a Reactor image tagged latest-amd64 or stable-amd64, then this post does not apply to you. It also does not apply to bare-metal installs; it's for users of docker images on ARM-based systems only (principally Raspberry Pi hosts, but could be others). After January 15, 2026, I will no longer produce the aarch64-tagged docker image for Reactor. The ARM images will be arm64 for 64-bit operating systems, and armv7l for 32-bit operating systems. For those of you running a container from the aarch64 image today, this will be a relatively simple change: you just need to switch the image used for your docker container to a differently-tagged image. If you are using docker-compose, then this is a relatively simple matter of changing the image line in your docker-compose.yaml file and then stopping (docker-compose down) and restarting (docker-compose up -d) your Reactor daemon. But there's a catch... not all of you can safely just switch from the aarch64 image to the arm64 image. And, you can't just trust the output of uname -m, for example, because this exposes the CPU architecture, but not the word size of the OS running on that CPU. For Raspberry Pi systems, the transition to 64-bit operating systems was long (starting in 2016) and not always obvious — although there was a first "official" 64-bit OS for RPis in 2020, it did not become a default recommendation in the Raspberry Pi Imager until 2021, and then that was only the default for Pi 3/4 systems with >4GB RAM; it was 2022 before it was universally recommended for all 64-bit CPUs regardless of RAM size. Depending on when you first imaged your RPi system and what default you may have been offered/chosen, you could today easily have a 64-bit CPU Raspberry Pi running a 32-bit version of the operating system. Upgrades along the way would not change this; changing it to fully 64-bit requires a full reimage of the system. To establish if your OS is 64- or 32-bit, log in to your Pi and run: sudo dpkg-architecture -q DEB_HOST_ARCH. If the response is arm64 or aarch64, then you are running a 64-bit OS and you should use the arm64-tagged image. If it's anything else, you are running a 32-bit OS, and you should use the armv7l-tagged image. pi@rpi4-1:~ $ sudo dpkg-architecture -q DEB_HOST_ARCH armhf pi@rpi4-1:~ $ uname -m aarch64 pi@rpi4-1:~ $ In the example above, the uname command reports that the CPU is 64-bit architecture (aarch64), which is true for the host on which I ran these commands, but the DEB_HOST_ARCH value is armhf, indicating a 32-bit operating system. This system has to use the armv7l-tagged image. Other systems will have their own ways of determining the word size of the running OS. Since the majority of Reactor users running ARM systems are on Raspberry Pis, I am able to supply the above instructions, but if you happen to have a different ARM system, you'll need to do some web searching to figure out how to expose that information. Or, you can just try the arm64 image, and if it doesn't start up, try the armv7l image. Remember to always back up your system before making any changes. For everyone, please make this change as soon as possible, and if you have any trouble finding a working image, please (1) go back to the current aarch64 image; and (2) let me know in this thread along with as much detail about your host system as you can offer (including the output of the dpkg-architecture command mentioned above).
@toggledbits Do you know if this is related to that PR or is it a change they made in 2025.11.1? [latest-25310]2025-11-11T13:16:24.319Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag with { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.320Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_dag action: { "type": "call_service", "service_data": { "date": (null), "time": "10:45", "datetime": (null), "timestamp": (null) }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_dag" } } [latest-25310]2025-11-11T13:16:24.321Z <HassController:ERR> HassController#hass request 1762866984320<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.321Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "10:45" }) on Entity#hass>input_datetime_vvb_dag failed! [latest-25310]2025-11-11T13:16:24.321Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"10:45","datetime":null,"timestamp":null},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_dag"},"id":1762866984320} [latest-25310]2025-11-11T13:16:24.322Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.322Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 0 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Engine#1 action args: { "time": "10:45" } [latest-25310]2025-11-11T13:16:24.322Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 1 [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass perform x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt with { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.323Z <HassController:INFO> HassController#hass: sending payload for x_hass_input_datetime.set_datetime on Entity#hass>input_datetime_vvb_natt action: { "type": "call_service", "service_data": { "date": (null), "time": "03:00", "datetime": (null), "timestamp": 0 }, "domain": "input_datetime", "service": "set_datetime", "target": { "entity_id": "input_datetime.vvb_natt" } } [latest-25310]2025-11-11T13:16:24.324Z <HassController:ERR> HassController#hass request 1762866984323<2025-11-11 14:16:24> (call_service) failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <HassController:WARN> HassController#hass action x_hass_input_datetime.set_datetime({ "time": "03:00", "timestamp": 0 }) on Entity#hass>input_datetime_vvb_natt failed! [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service call payload: {"type":"call_service","service_data":{"date":null,"time":"03:00","datetime":null,"timestamp":0},"domain":"input_datetime","service":"set_datetime","target":{"entity_id":"input_datetime.vvb_natt"},"id":1762866984323} [latest-25310]2025-11-11T13:16:24.324Z <HassController:INFO> Service data: {"fields":{"date":{"example":"\"2019-04-20\"","selector":{"text":{"multiline":false,"multiple":false}}},"time":{"example":"\"05:04:20\"","selector":{"time":{}}},"datetime":{"example":"\"2019-04-20 05:04:20\"","selector":{"text":{"multiline":false,"multiple":false}}},"timestamp":{"selector":{"number":{"min":0,"max":9223372036854776000,"mode":"box","step":1}}}},"target":{"entity":[{"domain":["input_datetime"]}]}} [latest-25310]2025-11-11T13:16:24.324Z <Engine:ERR> Engine#1 reaction rule-mgb8pfhs:S step 1 perform x_hass_input_datetime.set_datetime failed: [Error] Not a parseable type for dictionary value @ data['date'] [-] [latest-25310]2025-11-11T13:16:24.324Z <Engine:INFO> Engine#1 action args: { "time": "03:00", "timestamp": 0 } [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Resuming reaction Sätt Schema VVB i Home Assistant<AKTIV> (rule-mgb8pfhs:S) from step 2 [latest-25310]2025-11-11T13:16:24.325Z <Engine:INFO> Sätt Schema VVB i Home Assistant<AKTIV> all actions completed.
P
HA 2025.9.4 Supported Yet?
8 Posts 3 Posters 923 Views 3 Watching
    @toggledbits do you have any plans to implement the missing endpoints of the REST API in near future? Especially the rule and ruleset functionality (list/enable/disable etc. as documented) would be really useful. I know there must tons of feature requests and the REST API isn't probably on the top of the backlog, so I'm not holding my breath. But if it's right around the corner on your roadmap, it would be nice to know.
    I'm asking this because I need a clean way to enable and disable certain rules from my custom home automation UI. I don't want to expose the MSR UI to the rest of my family to make sure they don't accidentally mess up with the rules and settings.
    I could use a custom MQTT entity as a dynamic config object containing flags for different rules but it would be a lot cleaner to be toggle the rules thru the REST API.
    br,
    Reactor (Multi-hub) latest-22310-a6da8097
    MQTTController [0.1.22306]
      It's likely that the enable, disable and reset functions would not survive a review of that API prior to implementation. Enabling and disabling rules is not a way to add additional conditional logic to your automations, IMO, and I've stuck pretty firmly to that opinion (at least, I haven't been convinced otherwise to date).
      See also this topic: https://smarthome.community/post/13111
      M 1 Reply Last reply
        @toggledbits said in REST API implementation:
        Actually I don't see enabling / disabling rules as way to add additional conditional logic but merely as a user preference. For example I have a single rule that triggers lounge music playing through Sonos in my toilet whenever the PIR toggles the lights. But since I would like provide other users a possibility to switch off that feature, I would have to be able to disable that particular rule without the MSR UI for the reasons I've explained in my previous post.
        And when I saw the REST API specs, that felt like a proper way to do it.
        I think this post is more about the additional logic or maybe I'm just seeing it in a different light. I kind of think toggling the rules as a core functionality since it's already on the UI. You could do it with additional rules or entity attributes but it just feels more of hack. But maybe it's just me.
        toggledbitsT G 2 Replies Last reply
        • M mgvra
          @mgvra said in REST API implementation:
          Your logic could include, for example, examination of a virtual switch that determines if the rule should be applied at all. This could be part of the triggers for that rule, or a constraint on that rule. This is a very common model. I myself use it for "Party Mode" in my house, to prevent the automatic locking of doors and the "Night mode" from dousing of all the lights that would cause an unwelcome interruption of the merriment.
          • M mgvra
            I see this opening up the proverbial can-o-worms wherein another obscure rule turns off the one you're using to drive something completely unrelated to the first.
            I think of rules as true/false vs on/off (knowing I could be miles away from how Patrick intended lol) and do a very fair amount of "if rule set A is true do <this thing> but if it's false don't even think about it. TV on/off? That rule is true/false and the others just look for those two options. I don't really think it's that far off functionally from what you're hoping to achieve with on/off.
            *Hubitat C-7 2.4.3.158
            *HASS 2025.11.1
            MSR: latest-25323-d340b7d9
              @gwp1 said in REST API implementation:
              Well I don't see it that way. You can already enable/disable the rules from the UI. Adding that same functionality to a different interface (REST API) woudn't open can-o-worms.
              Please correct me if I'm wrong, but if you enable the rule I doesn't mean that it will trigger to true. It just evaluates the rule and if the conditions / constraints are met, it will trigger, otherwise not.
              Of course if at the exact same moment you enable the rule and the conditions are, it will trigger, but that should happen anyway. So if you could do enabling / disabling via the REST API wouldn't it be just like hitting that red/green switch 'remotely'?
              Well I think too. Maybe I was a bit unclear what I meant by toggling the rules. I didn't mean altering the rules evaluation outcome (true/false), just enabling/disabling the evaluation.
                Thanks for your quick response. Well it seems that I have to forget the REST API approach if it's going the get scrapped anyway. I just wanted to know the 'proper' way to go before I have too many rules to refactor. But as you pointed out, it seems that I have to go with the virtual switch / config object while integrating MSR to my existing backend/UI.
                • M mgvra
                  @mgvra I guess my one question is if you just simply ignore the evaluated results of a rule's true/false state isn't that pretty much the same as turning it off?
                  "If a rule turns true/false but no other rule is there to hear it... does it make a sound?" 😉
                  *HASS 2025.11.1
                  • Error: Command timeout
                  • [Solved] Local expression in Rule does not evaluate as they used to do
                    74.3k
                    588
                  • Shelly Wall Display XL
