  4. Error message
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
Error message
16 Posts 4 Posters 3.4k Views 4 Watching
    In this case, no, because the parent rule would have the name, and since the parent rule doesn't exist, there's no way to know what its name is/was.
      May I suggest a way to deep link or search for rules? Sometimes I just look inside the storage files, but something in the ui will definitely be easier.
      • wmarcolinW Offline
        I looked in the reactor/storage/rules directory by the name that appears, and there is no file.
        I looked in the UI Rule Sets folders and there is nothing without a defined name.
        Any other recommendations?
          I would second @therealdb 's ask about a UI-based way to search by the rulename. I realize that can be gleaned from the logs and tied back to the friendly name - just not always convenient to log dive.
            I'm guessing it's a global reaction that is running the (now deleted) rule's reset reaction.
            wmarcolinW 1 Reply Last reply
              Or is it not the name of a group within a rule?
                Nope. Not a group.
                  Nope. Not a group.
                  Since the problem happened again today at the same time, I searched the log for the information, and what I found (line 3) is something that really doesn't make sense to me.
                  [latest-22308]2022-11-17T14:00:02.425Z <Engine:INFO> Turn Off All A/C all actions completed.
                  [latest-22308]2022-11-17T14:00:02.438Z <Engine:INFO> Enqueueing "AC Guest On/Off<RESET>" (rule-kzydesq8:R)
                  [latest-22308]2022-11-17T14:00:02.439Z <Engine:ERR> [Engine]Engine#1 can't queue reaction rule-kzyree85:R, rule rule-kzyree85 not found
                  [latest-22308]2022-11-17T14:00:02.441Z <Rule:INFO> Hard Reset Sun 3am Part I (rule-kxp4v1ly in Datacenter) starting evaluation; because entity-changed System#reactor_system>system
                  [latest-22308]2022-11-17T14:00:02.441Z <Rule:INFO> (14) Ping Internet Fail (rule-kzrvnme5 in Warning) starting evaluation; because entity-changed System#reactor_system>system
                  I don't know if this helps at all? Any actions I can take to generate more research material?
                  Suggestion: would it be possible to put a log reader in Tools? something simple, just open the file and show it on the screen.
                  G 2 Replies Last reply
                  • wmarcolinW wmarcolin
                      @wmarcolin said in Error message:
                      rule-kzyree85
                      Have you queried prior logs to see if the friendly name surfaces? When you look at AC Guest On/Off<RESET> what does it show for the actions to take? The log says that's what's missing.
                      wmarcolinW G 2 Replies Last reply
                        rule-kzyree85
                        @gwp1
                        No, the name only appears on this line, I have already searched through all the logs file, and opened yesterday's, and it is the same message.
                        The rules that are executed before and after this log, are being executed without problem, the actions happen.
                        At 9am, I have a rule that:
                        1. performs a refresh of Life360 users, and looking at the logs it succeeds;
                        2. Then I turn off all the AC in the house, call a Reactions, which performs an OFF command for 5 devices;
                        3. Then I trigger another Reaction to turn off some tomasdas, simple command OFF the device.
                        And as I commented, the rule runs in this interval from 9am to about 9:05am everything is executed.
                        Thanks,
                          rule-kzyree85
                          @gwp1 said in Error message:
                          Does that ruleset have Reactions that might have a missing ruleset within them?
                            @gwp1 That is the correct question.
                              @toggledbits and @gwp1
                              To make sure that this rule that I'm executing is generating the problem, I changed the execution time to 11:00am (16:00:00 LOG), and the error repeated again, so one way to investigate.
                              [latest-22308]2022-11-17T16:20:02.235Z <Engine:ERR> [Engine]Engine#1 can't queue reaction rule-kzyree85:R, rule rule-kzyree85 not found
                              Running each of the steps I found the location of the error.
                              Super thanks for the support and ideas, problem solved.
                              Now, not wanting to minimize my stupidity, @toggledbits this case that is a Reaction used within a Rule, would there be a possibility that Alerts would then show the name? Something like that?
                              This situation was in a way easy to solve, because the rule has daily execution at the same time, thus searching the huge logs by time we could create the search path, now if it was a randomly executed rule it would be much more difficult.
                              Thanks a lot to everyone anyway!
                                Complementing information, this is the mother rule, and that on the second line of the Set Reaction called the Reaction that had the error I presented above.
                                  162.4k
