  4. Action Pace Configuration MSR
Sorry for a hasty post, will update some details later, but the scenario is that I managed to type a wrong password for too many times and had the following users.yaml section: authtrack: max_attempts: 4 within_minutes: 180 # 180 minutes = 3 hrs block_expiration_minutes: 10080 # 7 days At this time I used build 26298. Then noticed there's a new build with a bypass blocking feature (and yes, it said it won't remove existing block). Anyway, went ahead and upgraded to 26318, but the problem now is that UI is not loading at all (page does not answer). This also means that I cannot use "http://reactor_host:port/diag/clear_authtrack?askauth" command to clear the block (or use any other source IP for login). Docker container stays up & running and does not exit. I'll try to dig up some logs, but anything that I could immediately try out (could I delete a particular file for example)? EDIT: some logs [latest-26318]2026-11-17T20:42:32.337Z <Rule:INFO> MSR startup (rule-lculfnhm in Miscellaneous) started [latest-26318]2026-11-17T20:42:32.343Z <httpapi:NOTICE> httpapi#1 HTTP server listening on :::8111 [latest-26318]2026-11-17T20:42:32.347Z <httpapi:INFO> httpapi#1 local docs found in /opt/reactor/docs/html; setting up static service [latest-26318]2026-11-17T20:42:32.354Z <app:NOTICE> Starting WSAPI... [latest-26318]2026-11-17T20:42:32.355Z <wsapi:NOTICE> wsapi: starting version 26298 protocol [latest-26318]2026-11-17T20:42:32.523Z <Engine:INFO> Engine#1 master timer tick, local time "17/11/2026 22:42:32" (TZ offset 120 mins from UTC) [latest-26318]2026-11-17T20:42:32.542Z <Engine:NOTICE> Starting reaction MSR startup<SET> (rule-lculfnhm:S) [latest-26318]2026-11-17T20:42:32.545Z <Notifier:null> Module Notifier v26186 [latest-26318]2026-11-17T20:42:32.545Z <Engine:INFO> MSR startup<SET> all actions completed. [latest-26318]2026-11-17T20:42:32.557Z <Rule:INFO> Rule#rule-lculfnhm reaction rule-lculfnhm:S completed [latest-26318]2026-11-17T20:42:32.558Z <default:null> Module NotifyTelegram v26177
3 Posts 2 Posters 892 Views 2 Watching
  • P Offline
    P Offline
    Pmccraw
    Hello,
    I am using MS-Reactor with a Home Assistant hub running on a Synoogy NAS as well as a VERA Plus hub. So far MS-R works AMAZING! However I have one rule I use when cleaning the house that essentially turns all the lights on to 100% (25+ lights) and it takes sometime for the action to take effect. I noticed it worked slighlty faster when I had the items in a scene on the vera controller Vs. a rule triggered by a virtual switch in MS-R.
    I suspect I could address the issue by increasing the action pace value per the documentation however, I do not know where to edit this setting? Do I just add a line in the MS-R reactor.yaml config file below the VERA controller info that states: "ActionPace: 00500"?
    Please let me know where and how I can adjust he aforementioned setting.
    All the best,
    Phil
    • P Pmccraw
      Hello,
      All the best,
      Phil
      @pmccraw the ActionPace value can go below your source entry, indented at the same level (remember to use spaces, not tabs, for indenting). The value is a delay between tasks in milliseconds, so larger value means more delay (slower pace). The default is 25 (milliseconds).
      • P Offline
        P Offline
        Pmccraw
        Thanks much for the prompt reply, I just tried it and it noticeably improved the execution of the rule.
          163.6k
