  4. Running Reactions stuck in waiting from deleted rule
3 Posts 2 Posters 828 Views 2 Watching
    I probably messed things up trying to work around the shutdown timeout for Reactor 22328 when connected to openLuup MQTT server.
    I got a Reaction from a rule stuck in Running Reactions.
    "Stop this reaction" unfortunately does nothing and in my attempt to get rid of them I deleted the rule but they were still there. I downgraded to 22310 to do a clean restart of Reactor, no success. I even tried to rename/edit/delete reaction_queue.json but they are recreated after each restart and I can't get those orphan Reactions to disappear.
    I need some advice from the guru, please.
      You would have to have Reactor stopped (not running) at the moment you attempted to delete reaction_queue.json, otherwise it just recreates it at shutdown/restart. Is that what you did?
        Apparently not, but I did now and everything is back to normal. Thank you!
          160.0k
