  4. MQTTController: two brokers?
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
Possible feature request 2?
Copying a global reaction
8 Posts 2 Posters 910 Views 2 Watching
    I'm barely dipping a toe into MQTT and am wondering if MSRs MQTTController can be configured to listen to two brokers?
    ...is that even a thing in MQTT without bridging?
    *Hubitat C-7 2.4.3.177
    Core 2026.1.1
    MSR: latest-26011-c621bbc7
      Just add another instance in the controllers section; be sure to give it a different ID from the existing one.
        @toggledbits Ok, that's what I thought but wasn't positive.
        Will it work with a cloud MQTT broker?
        Core 2026.1.1
          Any broker that is 3.1.1 compliant should work as long as it's accessible.
            @toggledbits I think where I'm falling down is the URL format. I'm testing out HiveMQ to see if I can improve my OwnTracks response time by using MQTT into MSR vs HTTP into HomeAssistant into MSR.
            Log shows me:
            [latest-22337]2022-12-10T14:53:04.155Z <MQTTController:NOTICE> Connecting to broker mqtt://7efxxxxxxxxxxxxxxc4a0d0.s2.eu.hivemq.cloud:8883
            [latest-22337]2022-12-10T14:53:04.373Z <MQTTController:NOTICE> MQTTController#mqtt2 broker offline!
            [latest-22337]2022-12-10T14:53:04.374Z <MQTTController:NOTICE> MQTTController#mqtt2 waiting for auto-reconnect
            The broker is running:
            MQTTController config for this broker is:
                enabled: true
                  # Replace IP with that of your MQTT broker below
                  source: "mqtt://7efxxxxxxxxxxxxxxc4a0d0.s2.eu.hivemq.cloud:8883"
                  username: "<user>"
                  password: "<password>"
            I'm just tinkering for now. I'm remembering the Lobo days (I've yet to find anything that did presence like Lobo did...)
            Core 2026.1.1
              I doubt any cloud broker uses an unencrypted channel. Type mqtts://.... Changing the port alone does not change the communication protocol. You have to be more specific.
              G 2 Replies Last reply
                @toggledbits OY. The difference a single letter can make. Totally glossed over that little detail.
                Connected.
                Thank you, as always!
                Core 2026.1.1
                  @toggledbits In configuring the entity for OwnTracks... completely disregard my prior insanity. I'm finding all sorta good things BY READING ALL THE WORDS in the manual.
                  I'll be out the rest of the day - still just poking at this.
                  Core 2026.1.1
                    877
                    2.0k
                    3.7k
                    3.3k
                    906
