Reactor stable-23344-5aad7754 app 23344 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.516Z <app:null> Reactor build stable-23344-5aad7754 starting on v16.15.1 [stable-23344]2024-02-28T21:57:49.517Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [stable-23344]2024-02-28T21:57:49.517Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [stable-23344]2024-02-28T21:57:49.517Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [stable-23344]2024-02-28T21:57:49.696Z <Structure:null> Module Structure v23172 [stable-23344]2024-02-28T21:57:49.698Z <Capabilities:null> Module Capabilities v23331 [stable-23344]2024-02-28T21:57:49.780Z <Plugin:null> Module Plugin v22300 [stable-23344]2024-02-28T21:57:49.790Z <TimerBroker:null> Module TimerBroker v22283 [stable-23344]2024-02-28T21:57:49.794Z <Entity:null> Module Entity v22353 [stable-23344]2024-02-28T21:57:49.866Z <Controller:null> Module Controller v23069 [stable-23344]2024-02-28T21:57:50.030Z <default:null> Module Ruleset v22293 [stable-23344]2024-02-28T21:57:50.031Z <default:null> Module Rulesets v22146 [stable-23344]2024-02-28T21:57:50.066Z <GlobalExpression:null> Module GlobalExpression v23211 [stable-23344]2024-02-28T21:57:50.581Z <Predicate:null> Module Predicate v23093 [stable-23344]2024-02-28T21:57:50.595Z <AlertManager:null> Module AlertManager v22283 [stable-23344]2024-02-28T21:57:50.600Z <Rule:null> Module Rule v23107 [stable-23344]2024-02-28T21:57:50.614Z <GlobalReaction:null> Module GlobalReaction v22324 [stable-23344]2024-02-28T21:57:50.617Z <Engine:null> Module Engine v23339 [stable-23344]2024-02-28T21:57:50.635Z <httpapi:null> Module httpapi v23058 [stable-23344]2024-02-28T21:57:50.680Z <wsapi:null> Module wsapi v23172 [stable-23344]2024-02-28T21:57:50.789Z <TaskQueue:null> Module TaskQueue 21351 [stable-23344]2024-02-28T21:57:50.790Z <VeraController:null> Module VeraController v23109 [stable-23344]2024-02-28T21:57:50.971Z <HassController:null> Module HassController v23344 [stable-23344]2024-02-28T21:57:51.716Z <DynamicGroupController:null> Module DynamicGroupController v22313 [stable-23344]2024-02-28T21:57:52.253Z <SystemController:null> Module SystemController v23331 i18n: missing en-US language string: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. [stable-23344]2024-02-28T21:57:52.256Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:42) at new SystemController (/opt/reactor/server/lib/SystemController.js:29:9) at /opt/reactor/server/lib/Controller.js:101:37 Trace: The version of nodejs you are using ({0}) is now end-of-life, and so is deprecated for use with Reactor. Please upgrade nodejs to {2}.{3} or higher as soon as possible; the current LTS version is recommended. Releases of Reactor produced after {1} will not run under this version of nodejs at all. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at /opt/reactor/app.js:381:140 [stable-23344]2024-02-28T21:57:59.313Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:114:54) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:87:50) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:67) at Function.getInstance (/opt/reactor/server/lib/Data.js:37:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:507:100) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:538:47) at new Rule (/opt/reactor/server/lib/Rule.js:378:47) at Function.getInstance (/opt/reactor/server/lib/Rule.js:387:36) at /opt/reactor/server/lib/Engine.js:263:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:468:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:126:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1117:370 at processTicksAndRejections (node:internal/process/task_queues:96:5)I’ve tried using “latest-amd64” and it does not work either. The logs show similar json input error.
Reactor latest-24057-e9add9f5 app 24052 configuration from /var/reactor/config NODE_PATH /opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.466Z <app:null> Reactor build latest-24057-e9add9f5 starting on v20.10.0 [latest-24057]2024-02-28T22:27:30.522Z <app:null> Process ID 1 user/group 0/0; docker; platform linux/x64 #69057 SMP Fri Jan 12 17:02:28 CST 2024; locale (undefined) [latest-24057]2024-02-28T22:27:30.522Z <app:null> Basedir /opt/reactor; data in /var/reactor/storage [latest-24057]2024-02-28T22:27:30.522Z <app:null> NODE_PATH=/opt/reactor:/opt/reactor/node_modules [latest-24057]2024-02-28T22:27:30.667Z <Structure:null> Module Structure v23172 [latest-24057]2024-02-28T22:27:30.673Z <Capabilities:null> Module Capabilities v23331 [latest-24057]2024-02-28T22:27:30.780Z <Plugin:null> Module Plugin v22300 [latest-24057]2024-02-28T22:27:30.787Z <TimerBroker:null> Module TimerBroker v22283 [latest-24057]2024-02-28T22:27:30.791Z <Entity:null> Module Entity v22353 [latest-24057]2024-02-28T22:27:30.796Z <Controller:null> Module Controller v23069 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Ruleset v22293 [latest-24057]2024-02-28T22:27:30.811Z <default:null> Module Rulesets v22146 [latest-24057]2024-02-28T22:27:30.821Z <GlobalExpression:null> Module GlobalExpression v23211 [latest-24057]2024-02-28T22:27:30.890Z <Predicate:null> Module Predicate v23093 [latest-24057]2024-02-28T22:27:30.958Z <AlertManager:null> Module AlertManager v22283 [latest-24057]2024-02-28T22:27:31.027Z <Rule:null> Module Rule v24057 [latest-24057]2024-02-28T22:27:31.033Z <GlobalReaction:null> Module GlobalReaction v22324 [latest-24057]2024-02-28T22:27:31.036Z <Engine:null> Module Engine v24023 [latest-24057]2024-02-28T22:27:31.042Z <httpapi:null> Module httpapi v24057 [latest-24057]2024-02-28T22:27:31.216Z <wsapi:null> Module wsapi v24057 [latest-24057]2024-02-28T22:27:31.296Z <TaskQueue:null> Module TaskQueue 21351 [latest-24057]2024-02-28T22:27:31.297Z <VeraController:null> Module VeraController v24050 [latest-24057]2024-02-28T22:27:31.365Z <HassController:null> Module HassController v24048 [latest-24057]2024-02-28T22:27:31.659Z <DynamicGroupController:null> Module DynamicGroupController v22313 [latest-24057]2024-02-28T22:27:31.668Z <SystemController:null> Module SystemController v23331 [latest-24057]2024-02-28T22:27:31.673Z <Controller:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at /opt/reactor/server/lib/Controller.js:464:51 at Array.forEach (<anonymous>) at SystemController._restoreEntities (/opt/reactor/server/lib/Controller.js:458:36) at new Controller (/opt/reactor/server/lib/Controller.js:45:43) at new SystemController (/opt/reactor/server/lib/SystemController.js:237:9) at /opt/reactor/server/lib/Controller.js:101:37 [latest-24057]2024-02-28T22:27:38.845Z <app:CRIT> SyntaxError: Unexpected end of JSON input [-] SyntaxError: Unexpected end of JSON input at JSON.parse (<anonymous>) at IndividualFileStrategy.getDataObject (/opt/reactor/server/lib/IndividualFileStrategy.js:51:45) at DelayWriteCacheStrategy.getDataObject (/opt/reactor/server/lib/DelayWriteCacheStrategy.js:89:49) at Container.getDataObject (/opt/reactor/server/lib/Container.js:69:65) at Data.getInstance (/opt/reactor/server/lib/Data.js:45:179) at Rule.getRuleStates (/opt/reactor/server/lib/Rule.js:515:101) at Rule.getConditionState (/opt/reactor/server/lib/Rule.js:546:47) at new Rule (/opt/reactor/server/lib/Rule.js:371:47) at Rule.getInstance (/opt/reactor/server/lib/Rule.js:380:36) at /opt/reactor/server/lib/Engine.js:828:53 i18n: missing en-US language string: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. Trace: HomeAssistant on {0:q} may be an unsupported version. The reported version ({1}) has not been certified/tested with this version of Reactor and may cause errors. You must either modify your HomeAssistant install, or see if an update to Reactor has been made available. at _T (/opt/reactor/server/lib/i18n.js:614:37) at AlertManager.addAlert (/opt/reactor/server/lib/AlertManager.js:128:25) at HassController.sendWarning (/opt/reactor/server/lib/Controller.js:197:36) at /opt/reactor/server/lib/HassController.js:1133:374 at process.processTicksAndRejections (node:internal/process/task_queues:95:5)How do I fix this?
@therealdb
Thanks so much for this. I seem to have fallen at the first hurdle:
I grabbed zip file from Git hub and unzipped it. SCPed the owntracks_sensor.yaml file over to my bare metal Debian Bullseye install.
Created reactor/config/mqtt_templatescatman@openluup:~/reactor/config$ ls -l total 124 -rw-r--r-- 1 catman catman 232 May 26 2022 0-README.txt -rw-r--r-- 1 catman catman 302 May 26 2022 cameras.yaml -rw-r--r-- 1 catman catman 150 May 26 2022 dashboard.json -rw-r--r-- 1 catman catman 399 May 26 2022 local_hass_devices.yaml -rw-r--r-- 1 catman catman 434 May 26 2022 local_hubitat_devices.yaml -rw-r--r-- 1 catman catman 1945 May 26 2022 logging.yaml drwxr-xr-x 2 catman catman 4096 Dec 11 18:00 mqtt_templates -rw-r--r-- 1 catman catman 8960 Jul 19 16:10 notification.yaml -rw-r--r-- 1 catman catman 8959 Jul 19 15:55 notification.yaml.orig -rw-r--r-- 1 catman catman 8963 Jul 19 16:03 notification.yaml.telegram -rw-r--r-- 1 catman catman 8960 Jul 19 17:15 notification.yaml.working -rw-r--r-- 1 catman catman 12221 Dec 11 18:12 reactor.yaml -rw-r--r-- 1 catman catman 11827 Oct 10 18:07 reactor.yaml.change -rw-r--r-- 1 catman catman 11896 May 26 2022 reactor.yaml.orig -rw-r--r-- 1 catman catman 12039 Dec 11 18:01 reactor.yaml.working
The file is there
catman@openluup:~/reactor/config/mqtt_templates$ ls -l total 4 -rw-r--r-- 1 catman catman 3301 Dec 11 18:00 owntracks_sensor.yaml
And there is an entry in reactor.yaml:
rachel_owntracks: name: "Rachel Location" prefix: rachel topic: iphone uses_template: owntracks_sensor homeRegionName: Home
Obviously something really silly but damned if I can spot it
Could the template yaml file have been corrupted?
TIA!
Are you on the latest version of MQTTController?
@catmanv2 I'm watching your trials with this and trying to learn from your successes and losses.
What do you have configured in the actual iOS OwnTracks app as far as:
TrackerID
DeviceID
UserID
I think this is where I'm getting lost. I'm testing with HiveMQ and have the iPhone connecting (phone shows
connected
) and MSRs MQTTController is connected just fine to HiveMQ - it's just MSR and the iphone that are missing each other.- id: mqtt2 name: MQTT HiveMQ enabled: true implementation: MQTTController config: # Replace IP with that of your MQTT broker below source: "mqtts://7exxxxxxxxxxxxxxx0d0.s2.eu.hivemq.cloud:8883" username: "<username>" password: "<password>" entities: owntracks_iphone14p: #entity ID - must be unique name: "iPhone14p location" # friendly name prefix: "iphone14p" topic: "john_iphone" #the device name of my phone is John iPhone uses_template: owntracks_sensor homeRegionName: "Home"
In MQTTController I do see:
...but that's nowhere the detail I'd expect from @therealdb's template (which is properly placed in the correct location:I am brand new to MQTT so I'm likely missing something horribly obvious.
Any guidance is appreciated.
@gwp1
TrackerID is CM
DeviceID is catmaniphone
UserID is my configured username for my Mosquito server (so should be your Hive username)Because all of my stuff is local I can see the messages being posted to the logs. Not sure if you can do that with your hive set up?
At a guess you are not connecting to the Hive server. Does the iPhone app say 'connected'. Can you see Reactor getting messages from the Hive server?
I'm not 100% sure that's the right location for the config file. I guess if you're running reactor from /home/reactor/Documents it's right though. Just an odd choice (although Windows is not my thing) !
@catmanv2 yep, configured the Hive user and password and is shows as “connected” in the iOS app. I’ve not found anywhere in their dashboard to verify messages being received into the broker. I’ve not seen anything come in from the broker to msr.
I’m running a bare metal install on a RPi. Not a Linux expert so it ended up in an interesting folder structure but it works just fine so re-orging isn’t a priority.
The docs for MQTTController describe how to enable topic capture, so you can see if you are getting anything at all from Hive (this is probably preferable to turning up the log level in the log file for MQTTController). I'd suggest that as a start. See what, if anything, it's sending at all.
Ref: https://reactor.toggledbits.com/docs/MQTTController/#troubleshooting-and-debugging
@toggledbits @CatmanV2 Unless I'm just not far enough thru coffee this morning, this is what I see in MSR's mqtt logs and it looks like it's data from my iPhone8 (which I fired up via wifi to use as a test phone.)
2022-12-12T14:02:02.896Z "owntracks/msrmqtt/iphone8" {"_type":"location","acc":35,"alt":10,"batt":100,"bs":1,"conn":"o","inregions":["Home"],"inrids":["adf34c"],"lat":32.94714,"lon":-80.013836,"m":1,"p":101.826,"t":"u","tid":"i8","tst":1670853720,"vac":15} 2022-12-12T14:02:02.998Z "owntracks/msrmqtt/iphone8" {"_type":"location","acc":10,"alt":10,"batt":100,"bs":1,"conn":"o","inregions":["Home"],"inrids":["adf34c"],"lat":32.946934,"lon":-80.013887,"m":1,"p":101.827,"tid":"i8","tst":1670853722,"vac":8,"vel":0}
So why isn't this showing here:
My entity config is:
owntracks_iphone8: #entity ID - must be unique name: "iPhone8 location" # friendly name prefix: "iphone8" topic: "test_iphone" uses_template: owntracks_sensor homeRegionName: "Home"
I feel like I'm just "this close" and I just don't have something aligned properly.
Yes, your configuration of
prefix
andtopic
don't make a string that matches what is being received. Based on what it is coming in and how those fields template configuration are used,prefix
should bemsrmqtt
andtopic
should be justiphone8
.Conspicuous give-away: your
test_iphone
value doesn't appear in the topic or payload of what you're receiving.@therealdb this may need a bit more documentation, since the relevance of
prefix
andtopic
aren't immediately clear (at least, not to me) without looking at the template itself and seeing how they are used, and likely the phone configuration as well (i.e. describe how configuration fields on the phone may appear in the final event topic). -
I believe @toggledbits has it (unsurprisingly)
@toggledbits I was just updating
prefix
when your response came in. Here's where I am now:entities: owntracks_iphone8: #entity ID - must be unique name: "iPhone8 location" # friendly name prefix: "msrmqtt" topic: "iphone8" uses_template: "owntracks_sensor" homeRegionName: "Home"
My template is in reactor/config/mqtt_templates which is where @therealdb directs. Do I need to modify the
uses_template:
@gwp1 Are you getting an error that the template
owntracks_sensor
doesn't exist? -
@toggledbits I am not receiving any errors.
Just not seeing anything populate the entity.
Is it something to do with the entity name by any random chance?
Then there's nothing wrong with
uses_template
.I'll make the same comment/question to you that I made to @CatmanV2 earlier in this same thread: you're on the latest MQTTController, right?
@toggledbits MQTTController-22326 (double-checked the
CHANGELOG.md
)EDIT: ...which I now see is a version behind. You snuck one in on me. Updating to MQTTController-22340.
