46 Posts 4 Posters 19.8k Views 4 Watching
      @therealdb And kudos to you for sharing all of this with the Greater Good.
      *Hubitat C-7 2.5.1.142
      Core 2026.7.4
      MSR: latest-26193-8dd8f854
        I've pushed a couple of fixes, plus my new template for owntracks, that's supporting all the info as attributes.
        This template will create a device that has:
        • a string sensor with the current region
        • a binary sensor that's true when the user is at home
        • locations info via location capability
        • battery info for the device (including percentage and charging status)
        @gwp1 @CATMANV2
          @gwp1 @CATMANV2
          @therealdb Very timely, this. I'm poking at using MQTT/OwnTracks to replace the Home Assistant integration.
          Core 2026.7.4
            @gwp1 I was using my own virtual devices on Vera + some code in my own mqtt consumer, and I'm slowly migrating all of them to native MSR devices. I'm keeping virtual devices on Vera just for dashboard and some other minor automations.
            next on my list: my EV charger and maybe ESPPresence.
              Oh wow. That looks very interesting indeed! Thanks!
                @therealdb I just this week started into ESPresense with my MQTT > Home Assistant > msr.
                Three rooms so far. Also looking to use it at a buddy’s house to trigger garage door when I’m by.
                Core 2026.7.4
                  @gwp1 @CATMANV2
                  @therealdb
                  Thanks so much for this. I seem to have fallen at the first hurdle:
                  I grabbed zip file from Git hub and unzipped it. SCPed the owntracks_sensor.yaml file over to my bare metal Debian Bullseye install.
                  Created reactor/config/mqtt_templates
                  catman@openluup:~/reactor/config$ ls -l
                  total 124
                  -rw-r--r-- 1 catman catman   232 May 26  2022 0-README.txt
                  -rw-r--r-- 1 catman catman   302 May 26  2022 cameras.yaml
                  -rw-r--r-- 1 catman catman   150 May 26  2022 dashboard.json
                  -rw-r--r-- 1 catman catman   399 May 26  2022 local_hass_devices.yaml
                  -rw-r--r-- 1 catman catman   434 May 26  2022 local_hubitat_devices.yaml
                  -rw-r--r-- 1 catman catman  1945 May 26  2022 logging.yaml
                  drwxr-xr-x 2 catman catman  4096 Dec 11 18:00 mqtt_templates
                  -rw-r--r-- 1 catman catman  8960 Jul 19 16:10 notification.yaml
                  -rw-r--r-- 1 catman catman  8959 Jul 19 15:55 notification.yaml.orig
                  -rw-r--r-- 1 catman catman  8963 Jul 19 16:03 notification.yaml.telegram
                  -rw-r--r-- 1 catman catman  8960 Jul 19 17:15 notification.yaml.working
                  -rw-r--r-- 1 catman catman 12221 Dec 11 18:12 reactor.yaml
                  -rw-r--r-- 1 catman catman 11827 Oct 10 18:07 reactor.yaml.change
                  -rw-r--r-- 1 catman catman 11896 May 26  2022 reactor.yaml.orig
                  -rw-r--r-- 1 catman catman 12039 Dec 11 18:01 reactor.yaml.working
                  The file is there
                  catman@openluup:~/reactor/config/mqtt_templates$ ls -l
                  total 4
                  -rw-r--r-- 1 catman catman 3301 Dec 11 18:00 owntracks_sensor.yaml
                  And there is an entry in reactor.yaml:
                          rachel_owntracks:
                            name: "Rachel Location"
                            prefix: rachel
                            topic: iphone
                            uses_template: owntracks_sensor
                            homeRegionName: Home
                  But
                  Obviously something really silly but damned if I can spot it 😞
                  Could the template yaml file have been corrupted?
                  TIA!
                    Are you on the latest version of MQTTController?
                      I am now, thanks!
                      All looking good
                        @therealdb
                        total 124
                        The file is there
                        total 4
                                rachel_owntracks:
                                  prefix: rachel
                                  topic: iphone
                        But
                        TIA!
                        @catmanv2 I'm watching your trials with this and trying to learn from your successes and losses.
                        What do you have configured in the actual iOS OwnTracks app as far as:
                        TrackerID
                        DeviceID
                        UserID
                        I think this is where I'm getting lost. I'm testing with HiveMQ and have the iPhone connecting (phone shows connected) and MSRs MQTTController is connected just fine to HiveMQ - it's just MSR and the iphone that are missing each other.
                          - id: mqtt2
                            enabled: true
                              # Replace IP with that of your MQTT broker below
                              source: "mqtts://7exxxxxxxxxxxxxxx0d0.s2.eu.hivemq.cloud:8883"
                              username: "<username>"
                              password: "<password>"
                              entities:
                                owntracks_iphone14p: #entity ID - must be unique
                                  name: "iPhone14p location" # friendly name
                                  prefix: "iphone14p"
                                  topic: "john_iphone" #the device name of my phone is John iPhone
                                  homeRegionName: "Home"
                        In MQTTController I do see:
                        b893f7a4-2d61-4dc5-ab7f-81dee39e1f8e-image.png ...but that's nowhere the detail I'd expect from @therealdb's template (which is properly placed in the correct location:
                        I am brand new to MQTT so I'm likely missing something horribly obvious.
                        Any guidance is appreciated.
                        Core 2026.7.4
                          TrackerID
                          DeviceID
                          UserID
                            - id: mqtt2
                              enabled: true
                                entities:
                                    prefix: "iphone14p"
                          @gwp1
                          TrackerID is CM
                          DeviceID is catmaniphone
                          UserID is my configured username for my Mosquito server (so should be your Hive username)
                          Because all of my stuff is local I can see the messages being posted to the logs. Not sure if you can do that with your hive set up?
                          At a guess you are not connecting to the Hive server. Does the iPhone app say 'connected'. Can you see Reactor getting messages from the Hive server?
                          I'm not 100% sure that's the right location for the config file. I guess if you're running reactor from /home/reactor/Documents it's right though. Just an odd choice (although Windows is not my thing) !
                            @gwp1
                            TrackerID is CM
                            @catmanv2 yep, configured the Hive user and password and is shows as “connected” in the iOS app. I’ve not found anywhere in their dashboard to verify messages being received into the broker. I’ve not seen anything come in from the broker to msr.
                            I’m running a bare metal install on a RPi. Not a Linux expert so it ended up in an interesting folder structure but it works just fine so re-orging isn’t a priority.
                            Core 2026.7.4
                              @gwp1 That's a Linux setup?! 😉
                              OK, can you read the log from reactor?
                              Also, are you really sure that Reactor is able to connect to HiveMQ?
                                @catmanv2 Back home now.
                                This leads me to believe it's connected to Hive:
                                I see nothing in the logs because a.) not entirely should what it would look like, and b.) there's nothing happening atm.
                                Core 2026.7.4
                                  Hmm, yes tough. I share your suspicion that it's Hive. No interest in firing up Mosquito on your Linux box? Takes about 10 minutes. OK there's an increase in your vulnerability but.....
                                    The docs for MQTTController describe how to enable topic capture, so you can see if you are getting anything at all from Hive (this is probably preferable to turning up the log level in the log file for MQTTController). I'd suggest that as a start. See what, if anything, it's sending at all.
                                    Ref: https://reactor.toggledbits.com/docs/MQTTController/#troubleshooting-and-debugging
                                      I am now, thanks!
                                      All looking good
                                      @catmanv2 I hope you’ll enjoy it as much as I am 🤣
                                        @toggledbits @CatmanV2 Unless I'm just not far enough thru coffee this morning, this is what I see in MSR's mqtt logs and it looks like it's data from my iPhone8 (which I fired up via wifi to use as a test phone.)
                                        2022-12-12T14:02:02.896Z "owntracks/msrmqtt/iphone8" {"_type":"location","acc":35,"alt":10,"batt":100,"bs":1,"conn":"o","inregions":["Home"],"inrids":["adf34c"],"lat":32.94714,"lon":-80.013836,"m":1,"p":101.826,"t":"u","tid":"i8","tst":1670853720,"vac":15}
                                        2022-12-12T14:02:02.998Z "owntracks/msrmqtt/iphone8" {"_type":"location","acc":10,"alt":10,"batt":100,"bs":1,"conn":"o","inregions":["Home"],"inrids":["adf34c"],"lat":32.946934,"lon":-80.013887,"m":1,"p":101.827,"tid":"i8","tst":1670853722,"vac":8,"vel":0}
                                        So why isn't this showing here:
                                        My entity config is:
                                                  prefix: "iphone8"
                                                  topic: "test_iphone"
                                        I feel like I'm just "this close" and I just don't have something aligned properly.
                                        Core 2026.7.4
                                            141.6k
