  4. Reactor Start - System Crash/Restart
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
7 Posts 3 Posters 1.0k Views 3 Watching
    Hello All -
    I upgraded my OS to Ubuntu 20.04 today and have been regretting it for several hours. I have most of my system up. However, I've found that, when I start Reactor, it panics / reboots my OS. I've included the syslog during startup below. There's a benign message about not finding a Vera device just before the reboot but that's it.
    Needless to say, I've learned my lesson regarding OS upgrades.
    Bare metal Linux / Ubuntu 20.04 (Running inside VirtualBox)
    Reactor Version: stable-22337-1a0a685f
    Dec 30 19:33:46 homeauto03 systemd[1]: Started Multi System Reactor.
    Dec 30 19:33:46 homeauto03 weewx[6592] INFO weewx.restx: Wunderground-RF: Published record 2022-12-30 19:33:46 EST (1672446826)
    Dec 30 19:33:46 homeauto03 node[7240]: Reactor stable-22337-1a0a685f app 22328 configuration from /home/tbully/reactor/config
    Dec 30 19:33:46 homeauto03 node[7240]: NODE_PATH /home/tbully/reactor
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.745Z <app:null> Reactor build stable-22337-1a0a685f starting on v17.9.0
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.746Z <app:null> Process ID 7240 user/group 1000/1000; bare-metal; platform linux/x64 #62-Ubuntu SMP Tue Nov 22 19:54:14 UTC 2022; locale en_CA.UTF-8
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.746Z <app:null> Basedir /home/tbully/reactor; data in /home/tbully/reactor/storage
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.747Z <app:null> NODE_PATH=/home/tbully/reactor
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.764Z <Structure:null> Module Structure v22323
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.765Z <Capabilities:null> Module Capabilities v22283
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.819Z <Plugin:null> Module Plugin v22300
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.827Z <TimerBroker:null> Module TimerBroker v22283
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.831Z <Entity:null> Module Entity v22314
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.835Z <Controller:null> Module Controller v22323
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.847Z <default:null> Module Ruleset v22293
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.848Z <default:null> Module Rulesets v21096
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.854Z <GlobalExpression:null> Module GlobalExpression v21333
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.864Z <Predicate:null> Module Predicate v22305
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.867Z <AlertManager:null> Module AlertManager v22283
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.869Z <Rule:null> Module Rule v22335
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.872Z <GlobalReaction:null> Module GlobalReaction v22320
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.873Z <Engine:null> Module Engine v22320
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.877Z <httpapi:null> Module httpapi v22337
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.886Z <wsapi:null> Module wsapi v22320
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.949Z <TaskQueue:null> Module TaskQueue 21351
    Dec 30 19:33:46 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:46.950Z <VeraController:null> Module VeraController v22325
    Dec 30 19:33:47 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:47.200Z <HassController:null> Module HassController v22334
    Dec 30 19:33:48 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:48.294Z <SystemController:null> Module SystemController v22306
    Dec 30 19:33:48 homeauto03 weewx[6592] INFO weewx.restx: Wunderground-RF: Published record 2022-12-30 19:33:48 EST (1672446828)
    Dec 30 19:33:49 homeauto03 node[7240]: [stable-22337]2022-12-31T00:33:49.110Z <Rule:CRIT> ReferenceError: Can't find entity "vera>device_368" [-]
    Dec 30 19:33:49 homeauto03 node[7240]: ReferenceError: Can't find entity "vera>device_368"
    Dec 30 19:33:49 homeauto03 node[7240]:     at Predicate._evaluateCondition (/home/tbully/reactor/server/lib/Predicate.js:366:27)
    Dec 30 19:33:49 homeauto03 node[7240]:     at Predicate._evaluateGroup (/home/tbully/reactor/server/lib/Predicate.js:748:106)
    Dec 30 19:33:49 homeauto03 node[7240]:     at Predicate._evaluateCondition (/home/tbully/reactor/server/lib/Predicate.js:354:47)
    Dec 30 19:33:49 homeauto03 node[7240]:     at Predicate.evaluate (/home/tbully/reactor/server/lib/Predicate.js:60:37)
    Dec 30 19:33:49 homeauto03 node[7240]:     at Rule._evaluate (/home/tbully/reactor/server/lib/Rule.js:875:54)
    Dec 30 19:33:49 homeauto03 node[7240]:     at async /home/tbully/reactor/server/lib/Rule.js:830:17
    Dec 30 19:33:49 homeauto03 systemd[1]: Stopping Session 14 of User tbully...
    • T tbully
      Hello All -
      I have the logs but can't find a way to upload them. I don't have permissions to upload a file and if I paste it in here it says the post is too large.
      Here's a few pieces:
      [stable-22337]2022-12-31T00:33:46.750Z <app:INFO> Configured locale (undefined); selected locale(s) en_CA.UTF-8
      [stable-22337]2022-12-31T00:33:46.761Z <app:INFO> Loaded locale en-US
      [stable-22337]2022-12-31T00:33:46.887Z <app:NOTICE> Starting Structure...
      [stable-22337]2022-12-31T00:33:46.890Z <Structure:NOTICE> Structure#1 plugin ID influx disabled; skipping
      [stable-22337]2022-12-31T00:33:46.892Z <Structure:INFO> Structure#1 loading controller interface vera (VeraController)
      [stable-22337]2022-12-31T00:33:47.193Z <Structure:INFO> Structure#1 loading controller interface hass (HassController)
      [stable-22337]2022-12-31T00:33:48.290Z <Structure:INFO> Structure#1 loading controller interface reactor_system (SystemController)
      [stable-22337]2022-12-31T00:33:48.297Z <Structure:INFO> Starting controller VeraController#vera
      [stable-22337]2022-12-31T00:33:48.298Z <VeraController:NOTICE> VeraController#vera starting...
      [stable-22337]2022-12-31T00:33:48.304Z <Controller:INFO> VeraController#vera loaded vera capabilities ver 22253 rev 1 format 1
      [stable-22337]2022-12-31T00:33:48.341Z <Controller:INFO> VeraController#vera loaded implementation data ver 22280 rev 8 format 1
      [stable-22337]2022-12-31T00:33:48.341Z <Structure:INFO> Starting controller HassController#hass
      [stable-22337]2022-12-31T00:33:48.341Z <HassController:NOTICE> HassController#hass starting...
      [stable-22337]2022-12-31T00:33:48.343Z <Controller:INFO> HassController#hass loaded hass capabilities ver 22312 rev 2 format 1
      [stable-22337]2022-12-31T00:33:48.354Z <Controller:INFO> HassController#hass loaded implementation data ver 22335 rev 1 format 1
      [stable-22337]2022-12-31T00:33:48.354Z <Structure:INFO> Starting controller SystemController#reactor_system
      [stable-22337]2022-12-31T00:33:48.359Z <Controller:NOTICE> Controller SystemController#reactor_system is now online.
      [stable-22337]2022-12-31T00:33:48.518Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute members
      [stable-22337]2022-12-31T00:33:48.518Z <VeraController:INFO> VeraController: deviceclass room capability sys_group does not provide attribute empty
      [stable-22337]2022-12-31T00:33:48.519Z <HassController:INFO> HassController#hass device mapping data loaded; checking...
      [stable-22337]2022-12-31T00:33:48.520Z <VeraController:NOTICE> VeraController#vera updating capabilities for system entity System#vera>system
      [stable-22337]2022-12-31T00:33:48.525Z <HassController:NOTICE> HassController#hass connecting to ws://192.168.34.17:8123/api/websocket
      [stable-22337]2022-12-31T00:33:48.529Z <app:NOTICE> Starting HTTP server and API...
      [stable-22337]2022-12-31T00:33:48.530Z <httpapi:NOTICE> Starting HTTP API v1 22337 on http://192.168.34.:8111
      [stable-22337]2022-12-31T00:33:48.533Z <app:NOTICE> Starting Reaction Engine...
      [stable-22337]2022-12-31T00:33:48.534Z <Engine:INFO> Reaction Engine starting
      [stable-22337]2022-12-31T00:33:48.534Z <Engine:INFO> Checking rule sets...
      [stable-22337]2022-12-31T00:33:48.539Z <Engine:INFO> Checking rules...```
      [stable-22337]2022-12-31T00:33:49.745Z Rule:INFO Master Closet Motion Battery Low (rule-grp17k28ehz in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.761Z Rule:ERR Rule#rule-grp17k28qlp trigger evaluation failed: [ReferenceError] Can't find entity "vera>device_368" [-]
      [stable-22337]2022-12-31T00:33:49.762Z Rule:CRIT ReferenceError: Can't find entity "vera>device_368" [-]
      [stable-22337]2022-12-31T00:33:49.762Z Rule:INFO Panic Button Battery Low (rule-grp17k28qlp in Battery Checks) evaluated; trigger state changed ((null)), but rule state remains NULL
      [stable-22337]2022-12-31T00:33:49.762Z Rule:INFO Panic Button Battery Low (rule-grp17k28qlp in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.763Z Rule:INFO Office Motion Battery Low (rule-grp17k28znh in Battery Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.763Z Rule:INFO Office Motion Battery Low (rule-grp17k28znh in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.763Z Rule:INFO Upstairs Bath Door Battery Low (rule-grp17k29vsx in Battery Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.763Z Rule:INFO Upstairs Bath Door Battery Low (rule-grp17k29vsx in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.763Z Rule:INFO Upstairs Bath Motion Battery Low (rule-grp17k2abok in Battery Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.763Z Rule:INFO Upstairs Bath Motion Battery Low (rule-grp17k2abok in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.763Z Rule:INFO Upstairs Bath Flood Battery Low (rule-grp17k2am7t in Battery Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.764Z Rule:INFO Upstairs Bath Flood Battery Low (rule-grp17k2am7t in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.764Z Rule:INFO Upstairs Hall Motion Battery Low (rule-grp17k2b0ha in Battery Checks) evaluated; trigger state unchanged (true); rule state remains SET
      [stable-22337]2022-12-31T00:33:49.764Z Rule:INFO Upstairs Hall Motion Battery Low (rule-grp17k2b0ha in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.773Z Rule:ERR Rule#rule-grp17k2iotv trigger evaluation failed: [ReferenceError] Can't find entity "vera>device_543" [-]
      [stable-22337]2022-12-31T00:33:49.773Z Rule:CRIT ReferenceError: Can't find entity "vera>device_543" [-]
      [stable-22337]2022-12-31T00:33:49.773Z Rule:INFO Home Button Battery Low (rule-grp17k2iotv in Battery Checks) evaluated; trigger state changed ((null)), but rule state remains NULL
      [stable-22337]2022-12-31T00:33:49.774Z Rule:INFO Home Button Battery Low (rule-grp17k2iotv in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.774Z Rule:INFO Sump Pump Flood Detected (rule-grp17k301y1 in Flood Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.774Z Rule:INFO Sump Pump Flood Detected (rule-grp17k301y1 in Flood Checks) started
      [stable-22337]2022-12-31T00:33:49.774Z Rule:INFO Rec Room Flood Detected (rule-grp17k30cm0 in Flood Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.774Z Rule:INFO Rec Room Flood Detected (rule-grp17k30cm0 in Flood Checks) started
      [stable-22337]2022-12-31T00:33:49.775Z Rule:INFO Office Flood Detected (rule-grp17k30mqa in Flood Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.775Z Rule:INFO Office Flood Detected (rule-grp17k30mqa in Flood Checks) started
      [stable-22337]2022-12-31T00:33:49.775Z Rule:INFO Laundry Flood Detected (rule-grp17k31kf1 in Flood Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.775Z Rule:INFO Laundry Flood Detected (rule-grp17k31kf1 in Flood Checks) started
      [stable-22337]2022-12-31T00:33:49.775Z Rule:INFO Half-Bath Flood Detected (rule-grp17k31z13 in Flood Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.775Z Rule:INFO Half-Bath Flood Detected (rule-grp17k31z13 in Flood Checks) started
      [stable-22337]2022-12-31T00:33:49.775Z Rule:INFO Upstairs Bath Flood Detected (rule-grp17k327c0 in Flood Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.776Z Rule:INFO Upstairs Bath Flood Detected (rule-grp17k327c0 in Flood Checks) started
      [stable-22337]2022-12-31T00:33:49.776Z Rule:INFO Garage Tilt Sensor Battery Low (rule-grp17k3frdb in Battery Checks) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.776Z Rule:INFO Garage Tilt Sensor Battery Low (rule-grp17k3frdb in Battery Checks) started
      [stable-22337]2022-12-31T00:33:49.782Z Rule:ERR Rule#rule-grp17k3ui8q trigger evaluation failed: [ReferenceError] Entity Vera (vera>system) has no attribute "x_vera_sys.reloads" [-]
      [stable-22337]2022-12-31T00:33:49.782Z Rule:CRIT ReferenceError: Entity Vera (vera>system) has no attribute "x_vera_sys.reloads" [-]
      at Predicate._evaluateCondition (/home/tbully/reactor/server/lib/Predicate.js:373:27)
      [stable-22337]2022-12-31T00:33:49.782Z Rule:INFO LuupReload (rule-grp17k3ui8q in House Reactor) evaluated; trigger state changed ((null)), but rule state remains NULL
      [stable-22337]2022-12-31T00:33:49.783Z Rule:INFO LuupReload (rule-grp17k3ui8q in House Reactor) started
      [stable-22337]2022-12-31T00:33:49.783Z Rule:INFO VeraSecureTriggered (rule-grplg89w7x in House Reactor) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.783Z Rule:INFO VeraSecureTriggered (rule-grplg89w7x in House Reactor) started
      [stable-22337]2022-12-31T00:33:49.783Z Rule:INFO TurnOffPantryLights (rule-grplt8fpma in Basement Reactor) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.902Z <Rule:INFO> Garage Lights Off - After Auto On (rule-grpp2yoxfg in Garage Reactor) evaluated; trigger state unchanged (false); rule state remains RESET
      [stable-22337]2022-12-31T00:33:49.902Z <Rule:INFO> Garage Reactor (rule-492 in Garage Reactor) evaluation complete
      [stable-22337]2022-12-31T00:33:49.902Z <Rule:INFO> Garage Lights Off - After Auto On (rule-grpp2yoxfg in Garage Reactor) evaluation complete
      [stable-22337]2022-12-31T00:33:49.907Z <httpapi:NOTICE> httpapi: listening
      [stable-22337]2022-12-31T00:33:49.921Z <app:NOTICE> Starting WSAPI...
      [stable-22337]2022-12-31T00:33:49.922Z <wsapi:NOTICE> wsapi: starting version 22320
      [stable-22337]2022-12-31T00:33:50.112Z <Engine:INFO> [Engine]Engine#1 master timer tick, local time "12/30/2022, 7:33:50 PM" (TZ offset -300 mins from UTC)
      [stable-22337]2022-12-31T00:33:50.120Z <app:NOTICE> Shutdown signal (SIGTERM) received. Stopping Reaction Engine...
      [stable-22337]2022-12-31T00:33:50.121Z <app:NOTICE> Closing APIs...
      [stable-22337]2022-12-31T00:33:50.121Z <wsapi:NOTICE> wsapi: closing...
      [stable-22337]2022-12-31T00:33:50.121Z <httpapi:NOTICE> HTTP API closing...
      [stable-22337]2022-12-31T00:33:50.121Z <app:NOTICE> Stopping Engine...
      [stable-22337]2022-12-31T00:33:50.128Z <Rule:NOTICE> Turn Off Upstairs Hall Light (rule-grprsxsoqm in UpstairsHall Reactor) stopping
      [stable-22337]2022-12-31T00:33:50.129Z <Rule:NOTICE> Run Hot Water Recirculation (rule-l7ey8s4w in House Reactor) stopping
      [stable-22337]2022-12-31T00:33:50.130Z <Rule:NOTICE> Run Fans (rule-l6pi77c2 in House Reactor) stopping
      [stable-22337]2022-12-31T00:33:50.130Z <Rule:NOTICE> VeraSecureTriggered (rule-grplg89w7x in House Reactor) stopping
      [stable-22337]2022-12-31T00:33:50.329Z <Rule:NOTICE> Half-Bath Flood Detected (rule-grp17k31z13 in Flood Checks) stopped
      [stable-22337]2022-12-31T00:33:50.330Z <Rule:NOTICE> Upstairs Bath Flood Detected (rule-grp17k327c0 in Flood Checks) stopped
      [stable-22337]2022-12-31T00:33:50.417Z <Engine:NOTICE> [Engine]Engine#1 has shut down.
      [stable-22337]2022-12-31T00:33:50.417Z <app:NOTICE> Closing Structure...
      [stable-22337]2022-12-31T00:33:50.418Z <Structure:INFO> Structure#1 Stopping controllers...
      [stable-22337]2022-12-31T00:33:50.418Z <Controller:NOTICE> VeraController#vera stopping
      [stable-22337]2022-12-31T00:33:50.524Z <HassController:NOTICE> HassController#hass stopping
      [stable-22337]2022-12-31T00:33:50.526Z <HassController:WARN> HassController#hass websocket error during open/negotation: [Error] WebSocket was closed before the connection was established [-]
      [stable-22337]2022-12-31T00:33:50.526Z <HassController:WARN> HassController#hass ws error code (undefined)
      [stable-22337]2022-12-31T00:33:50.526Z <HassController:WARN> HassController#hass failed to connect/initialize communication: [Error] WebSocket was closed before the connection was established [-]
      [stable-22337]2022-12-31T00:33:50.527Z <HassController:NOTICE> HassController#hass websocket to ws://192.168.34.17:8123/api/websocket closed during open/negotiation
      [stable-22337]2022-12-31T00:33:50.527Z <Controller:NOTICE> HassController#hass stopping
      [stable-22337]2022-12-31T00:33:50.803Z <Controller:NOTICE> SystemController#reactor_system stopping
      [stable-22337]2022-12-31T00:33:50.811Z <Controller:ERR> Controller SystemController#reactor_system is off-line!
      [stable-22337]2022-12-31T00:33:50.814Z <Structure:INFO> Structure#1 Final data sync...
      [stable-22337]2022-12-31T00:33:50.838Z <Structure:NOTICE> Structure Structure#1 stopped
      [stable-22337]2022-12-31T00:33:50.839Z <app:NOTICE> Stopping timers...
      [stable-22337]2022-12-31T00:33:50.840Z <app:NOTICE> Shutdown complete, process ID 7240
        Sorry for talking to myself. Just trying to relay what I know.
        I tried running it manually and got the following:
        tbully@homeauto03:~/reactor$ npm run deps
        npm ERR! Missing script: "deps"
        npm ERR!
        npm ERR! To see a list of scripts, run:
        npm ERR!   npm run
        npm ERR! A complete log of this run can be found in:
        npm ERR!     /home/tbully/.npm/_logs/2022-12-31T01_15_30_113Z-debug-0.log
        tbully@homeauto03:~/reactor$ NODE_PATH=$(pwd) node app.js
        [stable-22337]2022-12-31T01:15:55.631Z <app:null> Reactor build stable-22337-1a0a685f starting on v17.9.0
        [stable-22337]2022-12-31T01:15:55.632Z <app:null> Process ID 2239 user/group 1000/1000; bare-metal; platform linux/x64 #62-Ubuntu SMP Tue Nov 22 19:54:14 UTC 2022; locale en_CA.UTF-8
        [stable-22337]2022-12-31T01:15:55.633Z <app:null> Basedir /home/tbully/reactor; data in /home/tbully/reactor/storage
        [stable-22337]2022-12-31T01:15:55.633Z <app:null> NODE_PATH=/home/tbully/reactor
        [stable-22337]2022-12-31T01:15:55.651Z <Structure:null> Module Structure v22323
        [stable-22337]2022-12-31T01:15:55.652Z <Capabilities:null> Module Capabilities v22283
        [stable-22337]2022-12-31T01:15:55.709Z <Plugin:null> Module Plugin v22300
        [stable-22337]2022-12-31T01:15:55.716Z <TimerBroker:null> Module TimerBroker v22283
        [stable-22337]2022-12-31T01:15:55.720Z <Entity:null> Module Entity v22314
        [stable-22337]2022-12-31T01:15:55.724Z <Controller:null> Module Controller v22323
        [stable-22337]2022-12-31T01:15:55.734Z <default:null> Module Ruleset v22293
        [stable-22337]2022-12-31T01:15:55.735Z <default:null> Module Rulesets v21096
        [stable-22337]2022-12-31T01:15:55.743Z <GlobalExpression:null> Module GlobalExpression v21333
        [stable-22337]2022-12-31T01:15:55.753Z <Predicate:null> Module Predicate v22305
        [stable-22337]2022-12-31T01:15:55.757Z <AlertManager:null> Module AlertManager v22283
        [stable-22337]2022-12-31T01:15:55.759Z <Rule:null> Module Rule v22335
        [stable-22337]2022-12-31T01:15:55.763Z <GlobalReaction:null> Module GlobalReaction v22320
        [stable-22337]2022-12-31T01:15:55.765Z <Engine:null> Module Engine v22320
        [stable-22337]2022-12-31T01:15:55.769Z <httpapi:null> Module httpapi v22337
        [stable-22337]2022-12-31T01:15:55.783Z <wsapi:null> Module wsapi v22320
        [stable-22337]2022-12-31T01:15:55.845Z <TaskQueue:null> Module TaskQueue 21351
        [stable-22337]2022-12-31T01:15:55.846Z <VeraController:null> Module VeraController v22325
        [stable-22337]2022-12-31T01:15:56.133Z <HassController:null> Module HassController v22334
        [stable-22337]2022-12-31T01:15:57.494Z <SystemController:null> Module SystemController v22306
          I could delete these posts but I won't. In short, I'm an idiot.
          I remembered I have a rule which reboots my Linux host when my weather station goes in to error. Reactor lives on that host. (sigh)
          My fix was to temporarily rename the "reboot" command in the filesystem to something else. Start Reactor (imagine that, no reboot!). Disable the rule. Fix the command back to "reboot" in the FS.
          Happy New Year! (ugh)
            These things happen. It's easy to forget stuff like this sometimes. A couple of suggestions:
            1. Send yourself a notification before you reboot the entire system (with the reason for doing it). Alert, email, cloud service... doesn't matter... just leave yourself a trail of crumbs to follow. It's a good idea to do this before any kind of automatically-triggered aggression against a process or system.
            2. Delay the reboot command by a minute or two in the reaction after that notification. That will give you time to (a) notice the notification and (b) cancel the reaction in the Running Reactions Status panel. You can then go and fix the rule or whatever is triggering it.
            Is there a reason you went to 20.04 instead of 22.04 LTS? The latter will have support through April 2027. If you want to take that step, you can just use do-release-upgrade from 20.04.
            • therealdbT Online
              therealdbT Online
              Been there, done that. I agree with @toggledbits about alerts. I prefer more alerts (I could always ignore them) than black magic routines.
                In my exhaustion (anger? Lol), I mistyped. I’m at 22.04. 🙂
                I do fire an email just before the reboot. I took a break to check emails and wrap up for the day and this is what triggered it for me. If it wasn’t for this, I think I’d still be digging. I send lots of emails, perhaps too many, when different things happen. This is a great idea!
                I have to go look at the rule today. I thought I set a variable on reboot which would only allow one event/reboot. At least I thought about this possibility but I clearly missed something.
                Thanks for the consoling, gents. I’ve appreciated both of your support over the past year as I’ve slowly moved away from Vera to HASS with Reactor being the central rules engine.
                  101.4k
                • Next Release?
