  4. Admin user required for Home Assistant Controller status and reactions
1 Posts 1 Posters 348 Views 1 Watching
    sykong
    Took me a while to realise the issue here. Just want to share to save others the time of trying to figure out what's wrong.
    • Reactor (Multi-hub) stable-22337-1a0a685f
    • Home Assistant 2022.11.5
    Home Assistant integration with non-admin user (access token) will caused the Home Assistant status in Reactor to show as down. Entity info from Home Assistant, however, is being updated. But Reactor is unable to execute any reactions.
    If the user is changed to an admin user in Home Assistant, the status is changed to up and reactions work.
      1.0k
      157.4k
