  4. Help. Installing Reactor on Home Assistant.
TL;DR: Format of data in storage directory will soon change. Make sure you are backing up the contents of that directory in its entirety, and you preserve your backups for an extended period, particularly the backup you take right before upgrading to the build containing this change (date of that is still to be determined, but soon). The old data format will remain readable (so you'll be able to read your pre-change backups) for the foreseeable future. In support of a number of other changes in the works, I have found it necessary to change the storage format for Reactor objects in storage at the physical level. Until now, plain, standard JSON has been used to store the data (everything under the storage directory). This has served well, but has a few limitations, including no real support for native JavaScript objects like Date, Map, Set, and others. It also is unable to store data that contains "loops" — objects that reference themselves in some way. I'm not sure exactly when, but in the not-too-distant future I will publish a build using the new data format. It will automatically convert existing JSON data to the new format. For the moment, it will save data in both the new format and the old JSON format, preferring the former when loading data from storage. I have been running my own home with this new format for several months, and have no issues with data loss or corruption. A few other things to know: If you are not already backing up your storage directory, you should be. At a minimum, back this directory up every time you make big changes to your Rules, Reactions, etc. Your existing JSON-format backups will continue to be readable for the long-term (years). The code that loads data from these files looks for the new file format first (which will have a .dval suffix), and if not found, will happily read (and convert) a same-basenamed .json file (i.e. it looks for ruleid.dval first, and if it doesn't find it, it tries to load ruleid.json). I'll publish detailed instructions for restoring from old backups when the build is posted (it's easy). The new .dval files are not directly human-readable or editable as easily as the old .json files. A new utility will be provided in the tools directory to convert .dval data to .json format, which you can then read or edit if you find that necessary. However, that may not work for all future data, as my intent is to make more native JavaScript objects directly storable, and many of those objects cannot be stored in JSON. You may need to modify your backup tools/scripts to pick up the new files: if you explicitly name .json files (rather than just specifying the entire storage directory) in your backup configuration, you will need to add .dval files to get a complete, accurate backup. I don't think this will be an issue for any of you; I imagine that you're all just backing up the entire contents of storage regardless of format/name, that is the safest (and IMO most correct) way to go (if that's not what you're doing, consider changing your approach). The current code stores the data in both the .dval form and the .json form to hedge against any real-world problems I don't encounter in my own use. Some future build will drop this redundancy (i.e. save only to .dval form). However, the read code for the .json form will remain in any case. This applies only to persistent storage that Reactor creates and controls under the storage tree. All other JSON data files (e.g. device data for Controllers) are unaffected by this change and will remain in that form. YAML files are also unaffected by this change. This thread is open for any questions or concerns.
33 Posts 6 Posters 8.6k Views 6 Watching
    alminsk
    Good afternoon. I want to connect Reactor to HA. HA is installed on Proxmox. Proxmox is installed on a Beelink U59 PRO mini PC. Studied the installation instructions ( https://reactor.toggledbits.com/docs/Installation / ) but I didn't understand how to do it (I'm a weak linux user). Help, give detailed instructions on how to install MSR.
    Reactor is a cool plugin, I use it on VeraPlus, but gradually I want to switch to HA.
      The instructions are pretty specific. We could probably help you more if told us what you were stuck on/not getting, which installation method you were going to try, and what OS is installed on your Proxmox VM. If you installed HassOS (one step for both an OS and Home Assistant) on your Proxmox VM, I probably can't help you; maybe someone with experience using HassOS can chime in. My experience is that it's too locked down and you can't install anything on it, but someone may have figured out something else.
      But tell us what you installed in the Proxmox VM first, and how you got Home Assistant installed and running.
        alminsk
        Good afternoon. You're right. I did the installation of the Virtual Machine Home Assistant OS in proxmox using Proxmox Helper Scripts ( https://tteck .github.io/Proxmox / )
        Here is the version of my system
        Here is the script that I installed in proxmox
        You say that you will not be able to install Reactor on the Home Assistant OS VM. What should I do then? I'm ready to reinstall HA. Which version is better to install and in what way? To be able to work with Reactor.
          alminsk
          Thank you for responding. I will be grateful for any help.
          • A alminsk
            @alminsk FWIW, Home Assistant docs recommend a dedicated system to run Home Assistant.
            *Hubitat C-7 2.4.3.177
            Core 2026.1.1
            MSR: latest-26011-c621bbc7
              OK. Unfortunately, that's probably the install about which we know the least, but it has been done successfully, as documented in this post and those that follow. The idea is to install Portainer in HassOS, and once that's done, you will be able to pull and install Reactor (MSR) as a docker container managed by Portainer.
              https://smarthome.community/post/8937
                alminsk
                Thanks for the answers.
                I am only at the beginning of the path and can completely reinstall everything. Which version of Home Assistant do you recommend to install so that Reactor would work without problems. And in what way.
                I will be very grateful for detailed instructions or for a link to the instructions.
                  I would install Portainer as done under the HassOS you already have running, per the other linked (above) thread, and then you can install Reactor using the available docker images and the information also provided by that thread.
                  • I Offline
                    I Offline
                    iRobot
                    When portainer is installed on HassOS, this is considered as a not supported HA install. This could give some trouble updating in the future.
                    Since you are using proxmox, I would make 2 virtual machines.
                    One to install HA using the HassOS script you have. And the other to install docker and portainer on which you can install MSR as explained by toggledbits.
                    This way you can also use docker for all other sort of projects which are not related to HA without interfering with it.
                      alminsk
                      Thanks everyone. So I will try to do so. Docker has already been installed as a second virtual machine. And how to properly install MSR in it.
                        alminsk
                        Installed in HA Porter through the integration of "HA Add-ons by alexbelgium" . Installed MSR in the Portainer and launched it. It started. But I can't log in to the Reactor web interface.
                          alminsk
                            You need to publish Reactor's port (8111).
                              alminsk
                              I am publishing a port (:8111) But for some reason it is not displayed. What I'm doing wrong 😞
                                alminsk
                                I saw errors in the logs. But I do not know what they mean.
                                  alminsk
                                  And for some reason the status is "unhealthy"
                                    I don't know/use Portainer, but you didn't show your Volumes tab. Did you create a directory for your config and data and bind it, per the installation instructions?
                                      alminsk
                                        alminsk
                                        Maybe I'm not choosing the right network?
                                        I have it like this now:
                                          That volume binding doesn't look right to me. Again, I'm not a Portainer user, but I would think that the path /var/reactor would be mentioned as related to the binding, since this is what Reactor is using internally within the container. It looks like you may have copied something from the Home Assistant configuration, but that's not right. I bet the /mnt/data/supervisor/homeassistant directory does not even exist in your new VM, because Home Assistant is not installed in that VM. You can't copy-paste/borrow from the Home Assistant configuration and get a successful Reactor configuration; different products, different configuration requirements. The Reactor installation instructions for docker show in the examples a Reactor data directory simply created in a regular user home directory. This is what you want. That directory (e.g. /home/username/reactor) should be bound to /var/reactor in the container.
                                          Your network configuration is also suspect/incorrect. Again, it looks like you copied from Home Assistant's instructions, rather than using the Reactor instructions. The network mode is typically "host". If that doesn't work, you can try "bridge".
                                          Can any of the Portainer+Reactor users please chime in here with some help for this user? Screen shots would be helpful. @black-cat @Fanan @vezinpi ...
                                          • Next Release?
