  4. Neural TTS with Sonos & Hubitat
1 Posts 1 Posters 627 Views 2 Watching
    My migration from Vera to Hubitat is almost ready, only Sonos & Visonic (alarm system) remain on Vera. Hubitat has a Sonos integration, but it lacks neural voices for TTS so I've been looking for an alternative solution.
    @a-lurker hinted that there's a mqtt version for Sonos so I went that route and installed Docker containers for both sonos2mqtt and sonos-tts-polly. It turned out that I won't need mqtt for this at all, and I can utilize Hubitat's integration and just use the latter container for Polly.
    Did create a separate user on AWS only for TTS usage (there's an access right called "AmazonPollyReadOnlyAccess") and configured key, secret & cache in the container. Then I made the following test rule / reaction in MSR:
    So if anyone else has the same (or similar) setup, here's one way to achieve neural TTS with Sonos.
      149.5k
